Old 09-28-2015, 02:12 PM   #183
dssence
Drives: Toyota FT/MT 86
It IS tied to the ECU and car keys via the immobilizer. The car will not start after cluster swap unless you take it to the dealer and the cluster is programmed to the immobilizer.
Wow I supposed it had something to do with the ECU. Is that simple doing it myself , the car dealer is so stupid over here Id rather prefer doing it myself. The inmobilizer does have an eeprom within the gauge cluster itself? so I will have to clone the gauge cluster data into the new one ? basically?
Can you point me towards a thread or guide about this. I'd be grateful
dssence is offline   Reply With Quote
Old 09-28-2015, 02:18 PM   #184
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
You'd probably be the first one... let us know how it goes :P
Pwolf is offline   Reply With Quote
Old 09-28-2015, 02:23 PM   #185
dssence
Guys can you make me a HUGE favor. Would you take a close up picture of the gauge cluster, those of you who got it handy already dissasembled. I've been checking some pics and it's a matter of reading the contents of the EEPROM chip on the gauge cluster.
That could be easily made with an eeprom flasher and flashing it back to the spare gauge cluster wanting to be replaced.
So I need those close up pictures to locate where the eeprom chip is, what kind the eeprom chip package is soic, plcc etc. And the manufacturer of the eeprom chip also.
Thanks. If It's as simple as that it's a piece of cake.
Old 09-28-2015, 07:01 PM   #186
Slammedsteve
Drives: 2013 Asphalt Fr-s,91 240sx missle
What size are the hvac twist bulbs? t5?
Slammedsteve is offline   Reply With Quote
Old 12-11-2015, 08:09 AM   #187
Amir Ghadiri
Amir Ghadiri's Avatar
Question for you all since you seem to be more knowledgable than me on the topic. I have my cluster out and taken apart, and would like to disable a few lights (TPMS, CEL, ABS, TC...). Can I just desolder and remove the LED's, or will that cause a problem? For example, on my excursion when the airbag light was burnt out, it would beep 5x repeatedly every hour.
Thanks guys
Amir Ghadiri is offline   Reply With Quote
Old 12-11-2015, 10:07 AM   #188
Pwolf
Pwolf's Avatar
No idea... Only one way to find out... let us know how it goes :P
Old 12-11-2015, 10:47 AM   #189
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Thanks guys
Just put electrical tape over them. Easiest way with no threat of anything going wrong.
Old 12-11-2015, 02:00 PM   #190
xFury
xFury's Avatar
Drives: '16 Scion FR-S - Oceanic
So the only way to change the LED is to solder them back on is that correct?
xFury is offline   Reply With Quote
Old 12-11-2015, 02:01 PM   #191
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Yeah
Old 01-25-2016, 05:20 PM   #192
KoB14
Drives: 2016 Scion FR-S "Asphalt"
Originally Posted by Acree View Post
Thank you! There's a link to my build thread in my signature.
How did you get your screens blue? I'm kind of worried to order some of the stuff I've seen
KoB14 is offline   Reply With Quote
Old 01-25-2016, 07:58 PM   #193
ort895
ort895's Avatar
Really want to do this, i think the frs white led look is more clean.
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 01-26-2016, 10:40 AM   #194
Mazikowski
Should just be a matter of replacing the LEDs that illuminate the screen with blue ones.
Mazikowski is offline   Reply With Quote
Old 01-27-2016, 11:07 AM   #195
KoB14
That's what I thought, but from what I've seen everybody has used transparent blue vinyl
Old 01-27-2016, 12:28 PM   #196
Beechnut87
Drives: White 2015 Series Blue BRZ SC
That would be awesome if it could be that simple, I would pay someone to do the scary part of resoldering everything
Sent from my SM-N910P using Tapatalk
Beechnut87 is offline   Reply With Quote
Gauge Cluster on FRS tonytduc Scion FR-S / Toyota 86 GT86 General Forum 16 07-24-2017 09:56 PM
BRZ cluster gauge swap? InYOHface Cosmetic Modification (Interior/Exterior/Lighting) 31 03-25-2017 06:31 PM
WTB gauge cluster Basti Want-To-Buy Requests 3 04-09-2014 02:54 PM
Gauge cluster mod? kALMIGHTY Scion FR-S / Toyota 86 GT86 General Forum 8 11-27-2013 10:59 PM
Want to try a gauge cluster experiment with me? stockysnail Northwest 2 04-12-2013 10:57 AM
