Old 11-20-2015, 02:24 PM   #659
celek
Resident Gear Head
celek's Avatar
Yeah I know my P3Cars gauge displays Temp from the OBDII port. Pressure could also be monitored to ECU as well but in most cases its for the dummy light.
Some cars like Honda use Oil pressure to monitor and activate the vtaaaaaks in the ECU! I have not dug too deep into our cars yet in wiring
celek is offline   Reply With Quote
Old 11-20-2015, 02:52 PM   #660
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Originally Posted by GT86_PRAGUE View Post
Does anyone know if it is safe to remove stock oil pressure switch? I need a place where to put analog oil temp sensor. I have extra oil pressure in galley plug. I also have Perrin oil cooler and I am not a fan of putting another oil plate.
So, is the stock oil pressure sender just for the dummy light or is it used by ECU to anything else? Can I remove it without consequences?
I found some threads here where people removed it, but I just want to be sure.
Thanks.
The one close to the oil filter is the temp.
The one on the left (from the front) is the oil pressure switch. It is not a fail safe switch. Literally unplugging it and tucking the line will not cause the light to come on.
It sends no information to the ECU.
I unplugged mine and tucked the wire harness to feed oil to a turbo. It works fine. I unscrewed the switch and removed it completely. 1/8 NPT thread for the fitting into the engine.
The gallery plug to the left and in front of the A/C compressor is the place to put a real oil pressure sender for a gauge / standalone if you are so inclined.
Analog temp will work fine off that front port though.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
GT86_PRAGUE (11-22-2015), Xuningshen (11-20-2015)
Old 11-20-2015, 06:49 PM   #661
twag4
Drives: frs
Originally Posted by Nigelr32 View Post
The FA20 has two switches on the oil gallery. either one measures temp and one measures pressure, or one is the light and one is pressure. The stock ECU definitely reads oil pressure, not sure about oil temperature.
Our cars in USA have no way from the factory to measure oil pressure. They do measure oil temperature. We have an oil pressure switch that simply illuminates a dummy light for pressure below 4psi if memory serves me correctly
twag4 is offline   Reply With Quote
Old 11-21-2015, 07:12 AM   #662
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
I based my answer on my belief that people buy those dash mounted gauges which give multiple info, including oil pressure.They stick in the airvent and plug into the OBD11 connector.
Edit:- I was wrong. Sorry about that!!
Nigelr32 is offline   Reply With Quote
Old 01-20-2016, 05:38 AM   #663
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
So will this resolve our issue with oiling?
http://www.ft86club.com/forums/showthread.php?t=99093
crazyfrenchbiker is offline   Reply With Quote
Old 01-20-2016, 06:06 AM   #664
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Well, the king pdf has the element tuning car pictured. I would expect that these bearings are part of the solution. How much power for how long? I'd just call element and let them build it for you.
Old 01-20-2016, 07:17 AM   #665
crazyfrenchbiker
Hot Lava 6MT
I am hopeful that this, along with the Reimax gear will fix all issues.
I'd love to call Element and have them build my motor, but I've been trying to give them my money for about a month and it is next to impossible to get them to call me back. Friends have similar experiences. I'm sure they do great work, they are just too busy to do mine.
The Following User Says Thank You to crazyfrenchbiker For This Useful Post:
EAGLE5 (01-20-2016)
Old 01-20-2016, 07:32 AM   #666
FRS Justin
Drives: 2013 Asphalt FRS
I can get you a motor, or ask for Phil or leave a message for him he will call you back, he is a super cool dude I spend hours on the phone with him.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
RavioliG (09-01-2017)
Old 01-20-2016, 08:54 AM   #667
crazyfrenchbiker
Hot Lava 6MT
I've got my motor situation sorted now. I've spoken to Phil before, he just never answers the phone and voicemails are rarely returned.
FRS Justin (01-20-2016)
Old 01-20-2016, 02:02 PM   #668
Flowers help. I hear Phil's partial to orchids but that's just a rumor.
Old 01-20-2016, 02:15 PM   #669
EAGLE5
Dismember
EAGLE5's Avatar
Others can build engines. I would just grill them about the build, tolerances, part choice, and especially oiling. If they have not built and blown up a few fa20s they probably won't do a good job.
Old 01-20-2016, 02:26 PM   #670
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
That's what made me pretty happy about choosing Moto-East for mine. Close enough to drive to, one of my drivers from work delivered my motor to the for me for free. They did 3 FA20s at the same time as mine, DIT from a WRX (that blew before the first scheduled oil change) and 2 NA ones. Plenty of others under their belt, and Mike and I had talk extensively on parts before hand.
Mine was the first Reimex gears they had seen I believe, but they now recommend them with builds.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
-Phil (01-20-2016)
Old 01-20-2016, 03:07 PM   #671
Luckrider
Luckrider's Avatar
@Moto-Phil, since you like the post. The car needs just 75 more miles before I can change the oil and beat on it. The oil cooler and bigger pump has made cold weather warm-ups get the oil up to temp way faster. I can't wait to pull that to redline this weekend.
Old 01-20-2016, 04:27 PM   #672
-Phil
Drives: Rb25 neo brz
Let us know how it goes!
-Phil is offline   Reply With Quote
The Following 4 Users Say Thank You to -Phil For This Useful Post:
2013GTRNate (02-23-2016), CxG (01-22-2016), Luckrider (01-20-2016), zuldajin (02-07-2016)
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 03:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 06:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 01:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-18-2013 12:24 AM
