Old 01-12-2016, 09:57 AM   #127
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Do you have a v3 now? And need the updates to get up & running?
Or are you holding out for 2015/16 ECU compatibility?
If you are holding out, you don't have to. The v3 Pro kit (without the F.E.) can be installed on any existing FR-S or BRZ; RHD/LHD/MT/AT from 2012 to current. You'll just have to use an alternative tuning solution.
Scott@HKSUSA is offline   Reply With Quote
Old 01-12-2016, 12:23 PM   #128
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I like the looks/performance of your kit here Scott. I've already got a mishimoto oil cooler mounted on my car and would like to know if it interferes with this install. The lines are routed differently (under drivers side headlight) so that's not an issue, but the cooler is mounted front and center with about a 4-5 inch gap in front of the radiator. Any idea if it will work? Couldn't tell from the installation instructions.
B T is offline   Reply With Quote
The Following User Says Thank You to B T For This Useful Post:
zeal86 (01-12-2016)
Old 01-12-2016, 01:44 PM   #129
Scott@HKSUSA
That's right about where our IC is. The radiator angles rearward towards the bottom and our IC is vertical so the gap increases the further down you measure but I'm pretty sure the IC occupies the same space.
Just took these if they help any:
Old 01-14-2016, 12:06 PM   #130
B T
Thanks for the pics, it's kind of hard to tell. I know there's a several inches of space between the cooler and the radiator. I haven't been able to find a good sideview outside of the mishi install video. Whats the radiator core dimensions and how far does the bottom/top sit off of the radiator?
Old 01-15-2016, 10:54 PM   #131
zeal86
zeal86's Avatar
Drives:
I'm looking at the same setup as you... at least the Mishimoto oil cooler and HKS v3 combo. I was also curious about the modifications I would have to do to accommodate both.
Here is a pic I found in the current Super Street mag for reference. ** Not Mishimoto oil cooler **
__________________________________________
projekt zeal86 build
zeal86 is offline   Reply With Quote
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
B T (01-24-2016), CxG (01-17-2016)
Old 01-20-2016, 02:58 AM   #132
Futaba
Futaba's Avatar
Drives: GT86
What's the price of this kit in Japan? Wouldn't mind going FI eventually and this looks like the way to go.
Futaba is offline   Reply With Quote
Old 01-24-2016, 11:13 AM   #133
B T
Looks to me like it may require a custom bracket for mishimoto mounting to the front bumper causing it to shift more to the left hand side (American driver side) and slightly farther forward. The lines to the oil sandwich plate may also need to be shortened.
Old 02-10-2016, 12:02 PM   #134
CxG
Drives: Pearl White '13 ZN6
Does anybody know if we can use/buy the tuner part separately and use it to remove CEL lights without going forced induction. I want to buy the header and front pipe but don't want to buy the supercharger until I have more track time with car. Unfortunately it seems that if I bought the exhaust components I'd have to go ecu tek to remove the CEL meaning I wouldn't have to buy the tuner version of the supercharger kit. The thing is that despite the tuner parts limitations I like the fact that it can double as a display gauge keeping the interior cleaner with the amount of gauges needed. Just curious is all.
Sent from my D5803 using Tapatalk
CxG is offline   Reply With Quote
Old 02-10-2016, 12:05 PM   #135
CxG
Originally Posted by Yobiwan View Post
V1(100mm) & V3(110mm) use usual 5 bolt pulley and upgradable
there is 5 bolt adapter between supercharger & 5 bolt pulley.
HKS sells in aftermarket are 5 bolt pulley.
it's caculated impeller speed table for HKS s/c kit.
V2 V1 V3
90mm100mm110mm
300045236 40712 37011
400060314 54283 49348
500075393 67854 61685
600090471 81424 74022
650098011 88210 80191
7000105550 94995 86359
7100107058 96352 87593
7200108566 97709 88826
7300110073 99066 90060
7400111581 100423 91294
Can anybody translate impeller speed into a peak boost number for the different pulleys on the V3 kit?
Old 02-14-2016, 12:14 PM   #136
eggncheese
Drives: 2013 Ultramarine Scion FRS MT
OFT?
eggncheese is offline   Reply With Quote
Old 02-14-2016, 07:14 PM   #137
CxG
Originally Posted by eggncheese View Post
OFT?
Are you saying oft does the same thing in allowing you to monitor information like the HKS unit? Can it be easily tuned for flex fuel kits with ethanol content sensors? I thought it was only good with the SBD kit.
Old 02-15-2016, 02:29 PM   #138
Calum
That Guy
Drives: 2013 asphalt FRS MT
OFT is a tuning platform. What you do with it is up to you, but as long as you know what you're doing it should have no problem tuning this kit or any other.
I have no idea if it can take advantage of a flex fuel sensor.
The Following User Says Thank You to Calum For This Useful Post:
CxG (02-15-2016)
Old 02-15-2016, 11:36 PM   #139
eggncheese
No idea about the flex fuel sensors, but it displays a great deal of data coming from the obd2 port.
http://www.ft86club.com/forums/showthread.php?p=1842501
If you're looking for to measure boost and ethanol levels I believe you'll need separate guages.
The Following User Says Thank You to eggncheese For This Useful Post:
CxG (02-15-2016)
Old 02-26-2016, 01:14 PM   #140
kehvynh
kehvynh's Avatar
Drives: 2015 BRZ Limited
Any updates for 2015+ with the flash editor?
kehvynh is offline   Reply With Quote
supercharger help... sosick Forced Induction 25 08-16-2013 12:02 AM
HKS GT Supercharger Evasive Motorsports Forced Induction 48 02-08-2013 07:21 PM
ETA on TRD Supercharger? frsinpa Forced Induction 18 01-11-2013 11:09 AM
supercharger? but by who? carbonBLUE Forced Induction 14 11-02-2012 11:10 PM
HKS GT Supercharger Kit BPAuto Forced Induction 18 10-27-2012 04:11 PM
