| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Oil Cooler
first of all, I am looking at the Mishimoto oil cooler. though, I have looked it up on this forum and have seen a big thread with a failure and in it was mentioned a few other failures, but I haven't been able to dig up more information about those other failures. I also noticed that Mishimoto updated their sandwich adapter plate recently so I'm assuming that those earlier leaking problems were fixed, such as leaking from the small hex screws in the side of the adapter plate. does anyone have any inputs on the most recent Mishimoto oil coolers (I believe the sandwich adapter plates are now gold)? and for the ones that installed the Mishimoto cooler, did you screw into the undertray as well or did you just use the top clips to hold it?
next, I have a few questions about installing the oil cooler. I noticed in the Perrin instructions, it says to prime the cooler after install (which seems normal) but none of the other instructions I looked at mentioned this crucial step (I'm assuming they think you know what you're doing). however, my BRZ has the push start button and I just want to confirm if it's the same process to crank the engine by double tapping the start button to ON, then hold down the gas pedal and hold the start button to crank? I would assume it's no different than with a car with a key, but I just want to make sure. also, since I am looking to get the thermostatic cooler, would priming the cooler even work if the engine isn't up to temperature since the thermostat only opens up at around 185F? or would I have to drive the car up to temp, then quickly install the oil cooler? as for the oil inside the cooler, would I have to manually empty it out by disconnecting the lines to get rid of the old oil? or would the amount inside the cooler not really matter compared to the 5.5 quarts inside the engine? I'm assuming that if you don't manually empty out the cooler every now and then, the old oil inside would be mixing with the newer oil and perhaps bring down the usable life of the total oil? and finally, is there anything else I need to be aware of maintenance-wise after installing the cooler aside from checking for leaks every now and then? and anything specific to pay attention to when installing the oil cooler? from what I've seen, it looks to be pretty straight forward.
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
sorry for another poorly laid out crude answer from Go_a_way1 but I think I got all your questions. Anymore quote me or you can always PM me too. |
#3 | |
#4 | |
Not Bаnned Anymore
I did use the "self tapping" (yeah they are not self tapping lmao) screws as well cuz its not gona hurt anything. I like that the mishimito has a bigger core vs prrin. But they are both quality kits. If you fear the bumper gap an oil cooler is not for you. You will get bumper gap the second you take your bumper off and it only seems to get worse the more I take mine off. |
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Clipdat (01-19-2016) |
#5 | ||
Drives: 2013 Subaru BRZ
We have 4 different sandwich plate options at the moment. Our non-thermostatic unit is silver, and we have three thermostatic plates which are gold. ¾ of these feature two NPT ports. You’ve asked two questions that are quite common with our direct-fit oil cooler customers. Priming: Priming is not 100% necessary although it can be done if you so choose. Oil pressure should make its way through the system in a matter of seconds, so dry-start wear on bearings should not be an issue. Draining The Cooler: Assuming you follow normal oil change intervals, draining fluid from the cooler/lines should not be necessary. Some old fluid will remain in the system and will mix with the new fluid added during the exchange. If you are insistent upon removing all fluid, the cooler can be removed and drained along with the oil lines. The installation process is relatively simple for our kit. We have an installation video on our site that is easy to follow and provides step-by-step guide for the process. Maintenance should not be any more involved than without the cooler. Just check the fittings for tightness after installation(we have torque specs on our site), and check them during each oil change. Let me know if I can answer any additional questions regarding our kit. Thanks -John Quote:
![]() Once oil is warmed up to thermostat temperature (185°), the pin is pushed outwards and blocks off the oil bypass port. This forces oil to pass through the lines and cooler. ![]() Interesting that you decided to remove the thermostat during winter as this is the primary season for its need. By retaining it, oil will bypass the cooler until optimal temperatures are reached, allowing the fluid to warm as quickly as possible. Once up to operating temperature, fluid will move through the lines and cooler. Thanks -John |
| The Following 4 Users Say Thank You to Mishimoto For This Useful Post: |
#6 |
after installation and starting up the car, how long should I expect for the oil cooler lines to fill up with oil (if the oil pressure and actual oil is not the same)? unless I am supposed to add in the extra .65 quart before the first start? if I add in the extra oil, would it cause the engine to be overfilled before the oil cooler is at full oil capacity? I know you mentioned that the cooler lines are closed off until it reaches 185F so would that affect how fast the cooler and lines fill up after installation?
#7 | |
Not Bаnned Anymore
#8 | |
| The Following User Says Thank You to ryoma For This Useful Post: | go_a_way1 (01-19-2016) |
#9 |
Not Bаnned Anymore
Trust me the @Mishimoto kit works as advertised and the install is super easy. If you were local I would do it for you.
| The Following User Says Thank You to go_a_way1 For This Useful Post: | Ultramaroon (01-20-2016) |
#10 | |
Sent from my VS986 using Tapatalk
| The Following User Says Thank You to ryoma For This Useful Post: | Ultramaroon (01-20-2016) |
#11 | |
Not Bаnned Anymore
it pissed everywhere before I ran back around and shut my car off haha. I am really surprised no one else jumped in to contribute in this thread lolEdit: I guess I am your personal oil cooler pro lmao!! |
#12 | |
Drives: 2013 Scion FR-S Asphault
| The Following 2 Users Say Thank You to g0odspeed For This Useful Post: | go_a_way1 (01-20-2016), Ultramaroon (01-20-2016) |
#13 |
Flooring the throttle before and during cranking triggers flood-clearing mode. Fuel is completely cut. No need to disconnect anything. Great feature. I use it for extra peace of mind after every oil change.
One of these days I'll get to installing my oil cooler. Gotta buy it first.
#14 | |
| Oil Cooler Set Up – DIY? | toraider | Engine, Exhaust, Transmission | 25 | 08-12-2015 07:59 AM |
| Oil Cooler | Wyattkb | Want-To-Buy Requests | 0 | 02-22-2015 01:27 AM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 06:46 PM |
| Best oil cooler | whitefrs | Engine, Exhaust, Transmission | 4 | 02-22-2013 12:36 AM |
