Old 01-13-2016, 04:46 AM   #29
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
[ame="http://www.amazon.com/Mini-Inline-Desiccant-Dryer-Filter/dp/B00W7XHT52"]Amazon.com: 1/4" Mini Inline Desiccant Air Dryer / Filter 2 Pack (Made in USA): Automotive[/ame]
ineedyourdiddly
Old 01-13-2016, 09:10 AM   #30
PECK
Drives: 2015 Scion FRS
Originally Posted by cf6mech View Post
Nitrogen is the only thing filled in commercial aircraft tires for a reason......yes its better i.e.......less effected by heat and cold cycling pressure changes....less abnormal tire wear....yes its the only thing I would put in my tires if I had the choice.....thats the catch though.....1...im not going to be seeking a dealership anytime I want tires serviced....2 Im not going to buy/rent bottles.....so pure air it is....
Costco uses nitrogen to fill the tires they sell. Free fill to if your a member.
Sent from my SM-T530NU using Tapatalk
PECK is offline   Reply With Quote
The Following User Says Thank You to PECK For This Useful Post:
cf6mech (01-13-2016)
Old 01-13-2016, 10:13 AM   #31
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
H20 molecular bonds in the tire can be broken by temperature changes.
Then the individual 0 and H molecules take up more space than they did before.
Today I learned that I can separate water into H2 and O molecules just by doing burnouts.
/sarcasm
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
humfrz (01-13-2016), Tcoat (01-13-2016), Ultramaroon (01-13-2016)
Old 01-13-2016, 10:24 AM   #32
They are also aircraft. If anybody here is stressing their tires to the level of aircraft take off and landing and consistently driving at temperatures as low as they are at altitude then I would love to see the build. There is zero advantage to nitrogen filled tires in your normal street driven car. This has been proven time and time again.
justatroll (01-13-2016), mdm (01-13-2016)
Old 01-13-2016, 10:34 AM   #33
mdm
not a twin owner
mdm's Avatar
Drives: 2016 Veloster Turbo DCT
Trying to imagine an FRS that weighs 100 tons and makes an abrupt stop from 170 mph to 0.
mdm is offline   Reply With Quote
The Following User Says Thank You to mdm For This Useful Post:
Tcoat (01-13-2016)
Old 01-13-2016, 10:37 AM   #34
Or hits 300MPH for a 1/4 mile or so and then suddenly removes that pressure.
Be quite the car.
mdm (01-13-2016)
Old 01-13-2016, 11:31 AM   #35
NOHOME
Drives: RAVEN
The green valve stem caps are put on there to let service personnel know that you are gullible enough to pay for such a scam. Or at least set up for the "Conversation" that you must maintain your tires with pure nitrogen so that they can relieve you of more $$$.
God help you if you should ever get some "Air" mixed in with your Nitrogen!
Someone needs to make the agnostic version of this cap.
NOHOME is offline   Reply With Quote
The Following User Says Thank You to NOHOME For This Useful Post:
Tcoat (01-13-2016)
Old 01-13-2016, 11:53 AM   #36
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Totaled
Scenic Driver is offline   Reply With Quote
Old 01-13-2016, 12:25 PM   #37
g e
I am seeing nitrogen filled tires as an add-on line item at many car dealers, including my Subaru dealer. They didn't have that when I bought my BRZ from them late 2013.
Refuse to pay it.
g e is offline   Reply With Quote
Old 01-13-2016, 12:43 PM   #38
strat61caster
So many places do it for free it's not automatically a marker for an idiot.
Have heard stories about foolish service people refusing to air up a customers tires because they are green capped and they don't have nitrogen and it would be dangerous to mix the two.
They do, it's a black plastic one, and they're way lighter than the fancy little metallic ones.
Definitely not worth paying any money for it.
ineedyourdiddly
Tcoat (01-13-2016)
Old 01-13-2016, 01:50 PM   #39
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Me too.......
YIKES, does that mean that the old air in my tires contains free hydrogen ... ??
What if it ignites, will my tires blow up .....
When I let air out of my tires, should I not have an open flame in the area ... ??
Should I put fresh air in my tires every now & then .. ??
I wonder if there is free hydrogen in my farts?
Braces is offline   Reply With Quote
The Following User Says Thank You to Braces For This Useful Post:
Tcoat (01-13-2016)
Old 01-13-2016, 01:58 PM   #40
mdm
not a twin owner
mdm's Avatar
Science says there is. http://gut.bmj.com/content/32/6/665.long
Tcoat (01-13-2016)
Old 01-13-2016, 01:59 PM   #41
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
Refuse to pay it.
I bought this car used. It's a 2013FRS. Maybe at one point someone did use nitrogen, but I won't. If I have to use my compressor at home to top a tire, where will the Nitrogen come from? I'll stick with air. Now maybe when I took it to Toyota they indeed did put Nitrogen in them, though I didn't see that on the slip
RichardsFRS is offline   Reply With Quote
The Following User Says Thank You to RichardsFRS For This Useful Post:
Tcoat (01-13-2016)
Old 01-13-2016, 07:32 PM   #42
mav1178
mav1178's Avatar
So I am gullible enough to pay for such a scam, even though the car came with it from the factory when I took delivery of it?
Just because it doesn't work for you doesn't mean it doesn't work for others. Nitrogen-filled is just a marketing thing, but if someone went through the trouble of using only nitrogen in their air compressors, it just means the air will have less moisture and more stable air pressures that don't fluctuate as much when temperatures change.
-alex
Tcoat (01-13-2016)
Topped off coolant with Prestone radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 12-13-2015 10:14 PM
Replacement windshield with "green tint/green shade" extrashaky Scion FR-S / Toyota 86 GT86 General Forum 11 07-07-2014 12:02 PM
Anybody have a lead on custom fitted car covers and seat covers for the FR-S? Grateful Dave Cosmetic Modification (Interior/Exterior/Lighting) 17 08-27-2012 10:41 AM
CBS FRS at Green Toyota Integratedfool Great Lakes 0 06-25-2012 01:24 PM
