#71 |
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
As Matt said, better flow for high HP, plus ext. type use a faster reacting "plunger" style valve that can vent off pressure more rapidly than the flapper door inside the turbo. Therefore the tuner can set it up to build boost harder/quicker/longer and stop it with immediacy, rather than having to start opening the wastegate before max boost is reached due to the latency of internal flapper door response time.
| The Following User Says Thank You to killboy For This Useful Post: | ChrisD (01-06-2016) |
#72 | |
Drives: Scion FR-S
valve springs are pretty cheap and relatively simple to change out. as for rods, i found that skunk2 makes H beams for less than $400 for the set. i picked up a set of those while i had my engine out. hope that helps |
#73 |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
E85 its good stuff. Honestly I would look into ordering 55 gallon drums of the stuff and run a flex fuel kit for hooning haha
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#74 |
Drives: blue - Cosworth SC stage 3.0
these guys sell it
http://www.trackstuff.co.uk/VP%20E85%20Racing.htm £4 a litre mind and yes you can run a flex fuel sensor to accurately judge the amount of Ethanol in the fuel and then add spark appropriately via custom maps vs the flexfuel sensor output its good stuff but pricey |
| The Following User Says Thank You to Matt@Cosworth For This Useful Post: | ChrisD (01-06-2016) |
#75 |
Junior
Drives: a car
This is what honing and balancing your engine is all about...correct? Im assuming when you have an engine built buy someone they deburr it.
#76 |
Some builders may do this ....some may not......
you pay your money and takes your choice |
| VIDEO GUIDE - Installing Boost/Vaccuum/Oil Pressure/AFR Gauges | The Sentinel | DIY (Do-It-Yourself) Guides | 3 | 04-25-2016 04:43 PM |
| WV: 04 STI Low miles Built 400+ AWHP 33K on chassis 1500 on engine $25K | dakjones | Cars for Sale/Trade | 6 | 09-03-2014 08:05 PM |
| Anyone has Stroked and Built FA Engine yet ? | Whitigir | Engine, Exhaust, Transmission | 11 | 03-14-2014 05:31 PM |
| Boost Pressure Leak Tester | whitefrs | Forced Induction | 32 | 02-18-2014 02:51 PM |
| What is the best turbo for a fully built engine scion frs | SUB-ZERO | Forced Induction | 41 | 09-18-2013 06:41 PM |
