Old 01-02-2016, 03:53 PM   #15
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by 8R6 View Post
if you do only vinyl and wrap the roof, the hole area will still be visible as that part will "sink" in compared to the rest of the roof. plus the vinyl will be so thin that if anything scratches it or even if theres enough air pressure, it'll puncture and make a hole.
Very true, the only logical thing I could think of to prevent that would be cut a piece of metal or some material to fit snug in the hole with jb weld, 3m glue or some sort of adhesive then vinyl over it and just keep putting vinyl on when the old vinyl wears out. But personally I think a shark fin follows the body lines way way better. This "antenna delete" comes off as something that will leak and cause problems later on in the cars life.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Cole (01-02-2016), stevesnj (01-02-2016)
Old 01-02-2016, 06:11 PM   #16
stevesnj
stevesnj's Avatar
I used waterproof outdoor silicone around the hole perimeter in case water seeps through the adhesive.
My 2016 Build thread
Old 01-02-2016, 06:14 PM   #17
FRSBRZGT86FAN
I'm talking 2-3 years out, with a constant barrage of water and wind like on a highway at 60+ mph or something it will eventually wear away, most outdoor silicone aren't meant for that....
Old 01-02-2016, 06:16 PM   #18
stevesnj
stevesnj's Avatar
Ah k...well the silicone isn't exposed to the outside elements just temp. If it fails I'll just try something else.
Old 01-02-2016, 09:50 PM   #19
jadewbj
jadewbj's Avatar
Get a circle of metallic blue vinyl cut just big enough to cover it. They make thicker vinyls that won't be an issue as far as durability. Will be much less noticible.
jadewbj is offline   Reply With Quote
The Following User Says Thank You to jadewbj For This Useful Post:
***NEW***Beatsonic Version 2 Sharkfin Antenna FT-86 SpeedFactory Cosmetic Modification (Interior/Exterior/Lighting) 29 03-27-2016 05:32 PM
FS: Beatsonic Sharkfin Antenna - Sterling Silver/Argento FDA9 (Version 2) chermo12 Canada Classifieds 3 06-02-2015 09:45 AM
"86" Dash Plaque - VG Shark fin antenna - Hot Lava seven Interior Parts (Incl. Lighting) 3 04-17-2013 12:24 AM
VG Shark fin antenna - Hot Lava - "86" Dash Plaque seven Exterior Parts (Aero, Lighting, Etc.) 1 04-17-2013 12:24 AM
1st 86 Final Gift : Carbon look Coin Tray badge, Plaque, FR-S Book, CNC Aluminum Box MarkRacerX Interior Parts (Incl. Lighting) 3 12-14-2012 01:30 PM
