#3375 |
Drives: 2015 Raven FRS
| The Following User Says Thank You to Lunatic For This Useful Post: | CSG Mike (01-02-2016) |
#3376 | |
Drives: WRB BRZ
Currently running E85 and at my favourite track (Phillip Island), I have starvation after only 6 laps from a full tank. If I run back to back sessions, I have starvation in pretty much every corner. I'm trying to avoid going to a surge tank, which seems to be the default option in Australia. |
#3377 | |
- Denso - Magnets ![]() The question is, what is the actual *cause* of your starvation? |
#3378 | |
Drives: WRB BRZ
Thanks!
My understanding (based entirely on reading this forum) is that it is caused by the siphon on the left side of the car sucking in air once the fuel has sloshed to the right side. Should the Hydramat be installed to connect to this siphon? This makes sense to me, because I only have problems at higher fuel levels (above 3/4's of a tank) at turn 12 of Phillip Island: Apex speed is around 160km/hr (~100MPH) and I usually experience starvation straightening out at roughy 175km/hr (~110MPH) You can sort of see it in this video, right before I shift to 5th. [ame="https://www.youtube.com/watch?v=in_H5UULhqg"]Phillip Island - 2015 10 30 - Fuel starvation issues Subaru BRZ - YouTube[/ame] If this will solve the problem, I will go ahead and order everything. |
#3379 | |
Are you NA? What fuel pump are you on? |
#3380 | |
Drives: WRB BRZ
All stock fuel pump, running E85 and NA. Running either NT01's or Hankook Z221 mediums. There are at least two others who are reporting the same problem. My thought was that 3/4 tank was the point where there is just enough room for the fuel to move away from the pickup for a second, to take in a little air. I haven't opened my fuel tank to know how true that is though. Could it be that E85 is too much for the stock fuel pump in these conditions? |
#3381 |
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Did CSG release their tire results? The last time I was on track my PSS were getting greasy half way through 25 minute sessions and I'm trying to decide what to use for a dedicated HPDE set with a bit of autocross duty
#3382 | |
Drives: 86 GT
Left corners only, Right corners are cherry so I cant see the pump being the issue. It gets worse when i step up from z222 RS3s to z221 TD softs. I even ghetto rigged a second fuel pump on the siphon side of the tank to force fuel into the siphon hose to fill the cup where the original pump sits. (this was all in the tank. nothing external) This seemed to work for one session then had the same issue again on the next few sessions. (probably the ghetto setup) I have been speaking to people who have made something but no exact details yet. I wont be doing any more track days unless this issue is fixed. example video the hydromat idea on the siphon side makes sense though. may give that a try if other avenues don't work out. Last edited by uncivilised; 01-04-2016 at 02:04 AM. |
#3383 | |
While we're always running different tires, it's not for the expressed purpose of comparison to determine a "best" tire. Most tires have an ideal circumstance, that doesn't always suit everyone's needs/preferences/style/etc. |
#3384 | |
Have you ever logged fuel pressures? |
#3385 | |
Drives: WRB BRZ
Although I can't imagine it would shown anything other than the fuel pressure dropping, considering how much worse the same symptom gets as the fuel level gets lower. Just speculation though without data. |
#3386 |
Drives: 2013 BRZ Limited M/T
Anyone recall the location of a thread that did a oil viscosity vs oil pressure comparison? I want to say it was by CSG, GSpeed or Velox.
#3387 | |
http://www.ft86club.com/forums/showthread.php?t=91820
2022 BRZ Build 2013 FR-S Build |
#3388 | |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
