| Member's Car Journals Car journals by our members. |
#29 |
#30 | |
Drives: DGM
Looking forward to any updates you have on the wheel wells as I'm considering doing this since I'll be upgrading the sound system. |
#31 |
Site Moderator
Drives: ichi 86 Project
This is freaking awesome read!!! Keep up the great work!
#32 | |
I only ran into a few problems on the doors. 1. For the Styrofoam insert on the doors, I didn't realize I would have a problem there. I simply cut a straight line from the bottom up about 6 inches (centered between the two clip holes) to allow it to "spread" as it got pushed inwards. 2. I also had some fitment issues where the door switch harness clips to the door frame (about 6 inches above the speaker). There are two holes there (one for the door panel and one for the wire harness). In my pics I only have one hole cut. I ended up cutting two separate holes.. but it was very tight.. so I ended up just cutting one large hole there instead of two separate holes. 3. I also noticed the wiring for the door light was way shorter on my driver door. I originally had my MLV/CCF mirrored right and left, but I had to cut a different slot on the left door. 4. I cut about another inch off the entire bottom, closer to the actual clips/holes. Thanks!! It's been fun
| The Following 3 Users Say Thank You to kberkel For This Useful Post: |
#33 |
FRS610
Drives: Scion- Frs
is there anyway you might produce the cluster hood? I'm super interested in that design! keep up the good work
FRS 10-series- OFT,OFH,PerrinOP, Tanabee Fp.Perrin MAF intake,Cusco strut bar,Grimspeed tool tray, invidia Q300, Full JL Audio sound system, YO speed plaque.
Instagram: FRS610 "Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous #maverick# |
#34 |
I picked up a new material. Another member suggested polyurethane rather than vinyl, so I bought some. It is much softer than the vinyl, and actually behaves a lot like real leather when you fold it.
It's the bottom left. The top is my previous material, the bottom right is OEM GM vinyl. ![]() ![]() Working on a gauge hood right now, hoping it turns out awesome The only downside is tape doesn't like sticking to it, so I spend much more time using pins on all my corners to keep them aligned when I go to sew.If it works out.. I want to do a french seam on the molded dash piece.. then I plan to sell a bunch of my parts already wrapped with the previous material: - Padded gauge hood, molded dash trim, vent rings Last edited by kberkel; 12-19-2015 at 04:55 PM. |
| The Following User Says Thank You to kberkel For This Useful Post: | olsonpg (12-20-2015) |
#35 |
The Fail Boat
Drives: CWP S.B.
Kevin's Random DIY (upholstery, fiberglass, etc.)
Just found this thread! Subbed 😍 keep up the good stuff. Maybe I can finally get the JDM/EDM armrest I want cuz all my stitches in the car is blue....watch & learn. >.>
Please do that next! Sent from my iPhone using Tapatalk |
#36 |
Working on the new material. So far I think it looks fantastic stitched up. I will do everything with this material from now on.
![]() You can see on the old one in the background, I'm having problems with too much bulk where the seam wraps around. Usually you can just "float" the material, but it still becomes visible at the edge. Or you can cut the overlapped area before you top stitch. I might just pad these pieces since it makes it feel great. I will finish that next week. Also tried out a flat felled seam with the old material. Looks pretty cool to me: ![]() Also working on a two piece dash with french seams. That that one should look cool
#37 |
do you know if this material will encounter fade from the sun over time?
#38 |
Drives: 13 GBS BRZ
I think you might need one of those tools that thins the material. Cant remember what its called but using it on the edges should help to make it lay flat.
Edit: Something like a wood planer is what I'm thinking of. |
#39 | |
http://www.yourautotrim.com/fusionblack.html Almost twice as long UV testing compared to the boating vinyls.. but the cluster hood would reach 1000 hours of UV rather quickly. I imagine no color fade. |
#40 |
The Fail Boat
Drives: CWP S.B.
#41 | |
Generally, instead of folding the flaps on the backside and top stitching through those, I could cut close to the blind seam and then the top stitch only goes through one layer. Not as strong, but in this application, doesn't matter. |
#42 |
Working on a 2-piece dash piece.
![]() My template is the outline for the blind seam.. then I have to draw the seam allowance. I do it with a tiny template, inch by inch. ![]() Here's with all the double-sided tape applied. I still use about 5-6 pins on each corner just to make sure the sew line is perfectly lined up since the tape won't hold. ![]() The corners on the outer piece need to expand, so they must stretch to meet the inner piece.. this is why the tape is on the inner piece (since the inner piece does not stretch or bend while I sew the blind seam). I'll then line all the edges up.. sew the blind seam.. then work on getting all the edges flattened so I can top seam them. |
| The Following User Says Thank You to kberkel For This Useful Post: | olsonpg (01-02-2016) |
| R.I.P. Sprint car driver Kevin Ward Jr. hit by Tony Stewart | Floggin Tires | Off-Topic Lounge [WARNING: NO POLITICS] | 89 | 08-08-2015 03:07 AM |
| Elite Eight: Kevin Ware of Louisville has his leg snap in half... (GRUESOME) | Dizz1e | Off-Topic Lounge [WARNING: NO POLITICS] | 9 | 04-01-2013 08:42 PM |
| Kevin Brown | Paul_S | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 03-20-2013 06:39 PM |
| OEM Upholstery | ExWhyZer0 | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 12-25-2012 02:21 PM |
| Kevin's BRZ | kgc | Member's Car Journals | 13 | 09-19-2012 03:39 PM |
