Old 12-22-2015, 06:59 PM   #1
ScoobySubie14
Drives: 2013 Subaru brz limited
Issues with door adjar light
After searching i noticed the trunk release tab was very sensitive but after checking it and making sure it was very secure the light still comes on. i have checked all sensors (doors as well) and the latch itself. if any one has some input it would be greatly apprciated
ScoobySubie14 is offline   Reply With Quote
Old 12-22-2015, 07:30 PM   #2
Oh, ol humfrz has a simple solution to most problems .... but, they usually don't work .....
I suggest you spray a bit of WD-40 or silicone spray in the trunk latching mechanism and open and shut the trunk several times, to see if will loosen up the switch.
Tcoat (12-22-2015)
Old 12-22-2015, 08:02 PM   #3
ScoobySubie14
simple solutions are usually the best. has this been a know problem with the twins?
The Following User Says Thank You to ScoobySubie14 For This Useful Post:
Tcoat (12-22-2015)
Old 12-22-2015, 10:48 PM   #4
Not that I know of.
If the lubricant doesn't work, you may consider taking off the plastic cover over the latch assemble and see if you can manually trigger the switch.
OR, you could "fix" it by the hillbilly method and simply place a piece of electrical tape over the indicator light .......
Oh yes, make sure you have the car door closed when you are back there messing with it and looking through the back window to see if the light will go off. And NO, I'm NOT going to tell you how I know that .....
Tcoat (12-22-2015)
Old 12-23-2015, 01:09 AM   #5
ScoobySubie14
Not that I know of.
we have all been there! ill find out tomorrow thanks
humfrz (12-23-2015)
Door open light rosol16 Issues | Warranty | Recalls / TSB 6 11-22-2015 01:42 PM
Fog light issues *SME please chime in* thatfilipinoguy Cosmetic Modification (Interior/Exterior/Lighting) 5 10-09-2015 08:52 PM
Interior Dome Light Issues Mongo Issues | Warranty | Recalls / TSB 3 03-19-2014 05:52 PM
Courtesy Door Light Help Zero90 Cosmetic Modification (Interior/Exterior/Lighting) 5 03-16-2014 09:53 AM
pioneer issues and door lights Cayden_BRZ CANADA 5 11-07-2012 07:10 PM
