Old 12-18-2015, 03:55 PM   #141
kwest.papajohns
Drives: red frs
Skip barber racing school = best mod you'll ever do on a car
heel toe downshifting all day
kwest.papajohns is offline   Reply With Quote
Old 12-18-2015, 04:09 PM   #142
extrashaky
Drives: 2014 BRZ Limited
Who seriously uses a spanner?
Anybody with a set of tools.
Spanner = British for "Wrench"
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
86kahl (12-18-2015), FLYFISHR (12-18-2015)
Old 12-18-2015, 04:13 PM   #143
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Originally Posted by FLYFISHR View Post
Just to throw a spanner into the works �� What about all that wear and tear on the throw out bearing by coasting with the clutch pedal depressed?
I never hold on the clutch, unless it's nearly "go time", or if I need to be on alert for some reason. Otherwise, any neutral action is done by being in neutral.
pushrod is offline   Reply With Quote
Old 12-18-2015, 04:20 PM   #144
extrashaky
Originally Posted by Celica00 View Post
How many RPMs of give do you have when you blip? for example if I wanted to downshift into 4th and ideally that would be perfect at 4,000 RPM. Could it still feel somewhat smooth at 3,800-4,200 RPM? When practicing this, my biggest hang up is revving correctly. This could also mean i'm doing it too slowly
Stop thinking about it and just do it. If you're thinking about it, you'll miss the timing so that even if you match the revs perfectly to where you wanted them, the transmission input won't be turning at that speed any more, so it won't match after all.
When I was learning to rev match, I had to change the way I thought about it. Instead of worrying about the exact RPM to hit, I started thinking of the transmission input speed as a hook moving down and the engine RPM as a ring. Then I just used the accelerator pedal to toss that ring up there so that it hooked on the transmission speed. If I tossed it too hard or too soft, it wouldn't work.
If you were playing a ring toss game in real life, you wouldn't sit there trying to calculate the speed of the ring and the speed of the hook and the distance between them and the wind direction and velocity. You'd just toss it up there and miss. Then you'd adjust by feel until you tossed it just right to catch on the ring. Soon you'd be able to do it every time.
Ring toss in a car is the same, except that the hook is moving a different speed in each gear. So downshifting into 4th takes a lower toss of the ring, while going into 2nd takes a higher one. You just keep tossing those engine RPM up onto the transmission by feel, and eventually you'll just do it without thinking about it.
The Following User Says Thank You to extrashaky For This Useful Post:
Celica00 (12-18-2015)
Old 12-18-2015, 05:09 PM   #145
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
Who seriously uses a spanner? Who are you, Chewbacca?
It's just an expression/saying
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
The Following User Says Thank You to FLYFISHR For This Useful Post:
Ultramaroon (12-18-2015)
Old 12-18-2015, 05:14 PM   #146
extrashaky
The US version of that saying is "wrench in the works." As culturally isolated as us Amurkins are from the rest of the world, it's not surprising some of us wouldn't know it unless we watched a lot of Doctor Who.
Old 12-18-2015, 05:25 PM   #147
c4lvinnn
Drives: Toyobaruion
This.
It's all by feel. too many variables to give you an specific "amount" of blip, especially depending on your deceleration rate.
c4lvinnn is offline   Reply With Quote
Old 12-18-2015, 05:56 PM   #148
stugray
Drives: 2013 GBS BRZ Limited
And "Adjustable Spanner" is actually much more descriptive than "crescent wrench".
Now don't get me started on Al-U-Mini-um.
The brits version of the pronunciation is actually correct for the element Aluminium. (funny spell checker is trying to 'fix' my spelling right there...)
However the alloy that we are all familiar with is pronounced Al-oo-Min-um in Murica.
Old 12-18-2015, 06:12 PM   #149
pushrod
Benched 86lb
pushrod's Avatar
The alloy, or any alloy?
Old 12-18-2015, 06:27 PM   #150
Old 12-18-2015, 08:34 PM   #151
Spell checker want's to change about 10% of what I type. It really, really hates colour.
Ultramaroon (12-19-2015), _Kodiak (04-05-2020)
Old 12-18-2015, 08:51 PM   #152
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
or anything with iser or yser
analyse, nope analyze
recognise nope recognize
Think americans just felt bad for the z being used so little.
also it's pronounce ""zed" not "zee"
fumanchu1 is offline   Reply With Quote
The Following 4 Users Say Thank You to fumanchu1 For This Useful Post:
FLYFISHR (12-18-2015), Tcoat (12-18-2015), Ultramaroon (12-19-2015), _Kodiak (04-05-2020)
Old 12-19-2015, 12:36 AM   #153
Soooo... it's working properly.
Tcoat (12-19-2015)
Old 12-19-2015, 12:43 AM   #154
Well it seems to believe I is a 'Murican.
kr-s is colorblind
Show us your Custom Roll Cage or Roll Bar and Harness Setup Black Tire Tracking / Autocross / HPDE / Drifting 27 02-13-2015 10:59 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 09:33 PM
Has anyone actually seen any of the Cusco roll bar / roll cages installed? xenocharger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 06-03-2013 07:54 PM
Car rattle at neutral. IloveBaldEagles Issues | Warranty | Recalls / TSB 3 12-23-2012 07:55 PM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 06:44 PM
