Old 12-16-2015, 05:45 PM   #211
mrk1
Drives: Sterling BRZ Ltd
Yes when I wrote 33% i was referring to volume sorry I didnt specify, by weight its 36%
To cite my source, Nitrous Oxide High-Performance Manual by Trevor Langfield. Trevor owns the UK based Wizard of NOS company.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 12-16-2015, 06:08 PM   #212
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
BRB getting more popcorn
Rapiddan45 (12-16-2015)
Old 12-16-2015, 06:10 PM   #213
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Only if you bring enough to share with the rest of class
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
go_a_way1 (12-16-2015)
Old 12-16-2015, 06:14 PM   #214
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Don't worry I got lots
The Following 2 Users Say Thank You to go_a_way1 For This Useful Post:
Apoc (12-17-2015), Toyarzee (12-16-2015)
Old 12-16-2015, 06:21 PM   #215
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Pretty much.
I'm at the dyno and flashing takes forever. I wish EcuTek had live tuning
Perhaps we can get a free Motec like all the other free parts on the car /sarcasm
you can get a kind of live tuning with ecutek
if you use a 0.5 to 4.5V power supply and feed it into the rear O2 sensor plug and then assign a custom map to apply an offset to the parameter you want say spark timing with 0.5V its -10 degrees and 4.5V its + 10 degrees fro example then its case of turning the power supply up and down to offset your spark
and then use the mode switch to assign other parameters to your rear o2 so you can use it to map cam timign, gdi timing etc
Matt@Cosworth is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
Andew727 (12-22-2015), CSG Mike (12-16-2015)
Old 12-16-2015, 06:24 PM   #216
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by shiumai View Post
the atoms are not the same atomic weight. oxygen is 16, and nitrogen is 14.007. if you take 14.007+14.007+16 = 44.014. then take 16/44.014, you get .364, which is 36.4%.
Interesting and very plausible. I assume its a liquid state at this percentage I don't know. The reason I ask is other sources such as NX Express and even good old Wikipedia have it at 33%. Not arguing I sincerely don't know this answer.
Edit:
The weight of the molecules will change according to temperature and state of molecules. (Gas vs Liquid)
Source Purdue University chemistry dept.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 12-16-2015, 06:29 PM   #217
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Here's a link i found - by weight:
http://www.noswizard.com/nos-technic..._nitrous_oxide
shiumai is offline   Reply With Quote
Old 12-16-2015, 06:35 PM   #218
CSG Mike
CSG Mike's Avatar
Chemical state does not change composition.
Nitrous itself is 33% oxygen by molarity, or 36% oxygen by mass.
Thing is, you can't displace all atmospheric air with N2O.
FRS Justin (12-16-2015)
Old 12-16-2015, 06:36 PM   #219
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
If nothing else I'm learning a shit ton about nitrous
Freeman is offline   Reply With Quote
The Following 4 Users Say Thank You to Freeman For This Useful Post:
#maverick# (12-17-2015), Bach415 (02-15-2016), go_a_way1 (12-16-2015), Special_K (12-16-2015)
Old 12-16-2015, 07:04 PM   #220
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Originally Posted by new2subaru View Post
For sure! I don't mind threads that go off track.
+1 to that and that!
Old 12-16-2015, 07:35 PM   #221
FRS Justin
I agree 100% but whatever is replaced will have a higher o2 content and still raise the cylinder charge o2 percentage in the given volume.
710whp
Old 12-16-2015, 07:48 PM   #222
totopo
Drives: 370z
On further retrospect... molarity is what is important, not weight, since it is a gas. Furthermore N20 disassociates in the cylinder (it requires high T), not the manifold.
So let's say you ran on 1 atm of pressure of PURE NOSS!!!!Z!!11! (/s). In effect, since each mole of N20 dissociates into half a mole of 02, that would equate to 50% atm partial pressure of 02.
So depending on your mixture of air vs N20 it would be somewhere between 20 and 50% effective 02.
edit (because math is fun!!!): 100% N2O would be 7.35 PSI of O2. To get that much with FI, given 20% of O2 in air you would need 2.5 atm worth of air, so an extra 1.5 atm of boost, which equals 22 PSI of boost!!!! just from the oxygen alone!
totopo is offline   Reply With Quote
The Following User Says Thank You to totopo For This Useful Post:
Old 12-16-2015, 07:58 PM   #223
FRS Justin
Very nice now lets talk about a wet shot of nitrous using E85 on a 4 cyl direct port system @55psi using jets 20 fuel and 41 N2o
710whp
Old 12-16-2015, 08:13 PM   #224
AJPG
Drives: 22RE, FA20, 4G63
I should also add, while we're at it, that I've personally witnessed bent/broken rods on 100% NA, 100% stock engines.
Does that mean stock engines also need rods?
Correlation does not mean causation.
Water?
AJPG is offline   Reply With Quote
kill brain cells, not facts
FlexFuel and Facts Shiv@Openflash Software Tuning 74 05-07-2025 05:28 AM
Anyone Else? Hearters Blowing when off. Kiske Issues | Warranty | Recalls / TSB 7 04-09-2014 06:22 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 04:29 PM
Supra Blowing Up radroach Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2013 10:14 PM
Facts you may or may not know about your GT86/BRZ/FR-s FiRStsc10n Scion FR-S / Toyota 86 GT86 General Forum 41 07-09-2013 04:05 PM
