#239 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
This appears to prove your point
If I say yes, will that make you think I understand?
#240 |
Drives: FT86
Stoic ratio for petrol mixture is 14.7 parts air to 1 part fuel.
Stoic ratio for e85 mixture is 9.8 parts air to 1 part fuel. The O2 sensor does not know how much air or fuel you started with. It only knows oxygen levels left in the spent charge. The O2 sensor reports in terms of lambda. If the lambda value is 1.0, the fuel is burned optimally, and started with the right mix. Whether you start with gas at 14.7:1 or e85 at 9.8:1, the lambda will be the same at the O2 sensor. The ECU recalibrates the lamda value to read AFR for petrol that what you see in logs. The fact that your running straight petrol or E85 does not matter to sensor and the ECU will try to still target stoic if you set the "afr" to 14.7. The fuel trims will easily adjust for E10 All they really do in E85 tunes fueling wise is adjust the injector scaling so you don't run huge trims like 25% |
#241 |
Drives: FR-S Whiteout
Here's a short article about afr's for flex fuel.
http://ethanolpro.tripod.com/id213.html AFR to Lambda calculator: http://www.wallaceracing.com/air-fuel-lambda.php Should come in handy while dialing your fuel tables.
Intent > Content
cowardice is the mother of cruelty. |
#242 |
Drives: Scion FRS
@KoolBRZ what changes did you have to make to PFI BRZ and DI fuel pressure to get the LTFT back to where it was before the new PFI DI surface?
#243 | |
Drives: FT86
Seems arround the 5% mark , i moved by PI injector scalar (injector scaling brz in romraider) down 3% which increased port fueling 3%, Did not touch th di pressures ect figured it was easier to match the port to the di than the other way round |
| The Following User Says Thank You to steve99 For This Useful Post: | thambu19 (12-14-2015) |
#244 | |
That and a bit more
I'm using custom AVCS mapping, so my trims are going to be off until I re-scale my MAF to suit. I'm making the major changes first, then worrying about fuel trims last, so long as they are trimming richer from lean. That way if it applies the trims to Open Loop it will only make it richer, which is much safer than applying lean trims to Open Loop. I'm also experimenting with large cell groups of -.001 compensations to the closed group compensation tables. It had been running too rich at low loads with less power and worse economy. It's also more unsafe to run rich in Closed loop, because it applies those trims to Open loop. I'm finding out it has more power at Stoich in the low load areas of .3 through .6, and from 1600 RPM's through 2800. I'm using more increased Tip-in instead, to compensate for low-load throttle changes. More power, and more economical.
![]() Last edited by KoolBRZ; 12-14-2015 at 10:51 AM. Reason: I actually changed the closed loop numbers to negative, just didn't want to do another pic. |
| The Following User Says Thank You to KoolBRZ For This Useful Post: | thambu19 (12-14-2015) |
#245 |
Drives: Scion FRS
Thanks! I am about to try the PFI DI map. Wanted to make sure my baseline is good before I did that. I have a Takeda intake so have to work on some MAF scaling and get trims and OL AFR correct before messing with PFI ratios. I am starting with the scaling @steve99 had posted
#246 |
Remember, it is far far better to make it leaned out in Closed loop, so it applies richer trims in Open loop. You can make up the fuel needed to accelerate with added Tip-in, and if you really need to accelerate, you'll be in Open loop anyway. I'm beginning to think that the entire closed loop should be Stoich. I'm going to try this out today. I left the temp comp tables alone, I still think they are necessary.
#247 | |
Drives: Toyota 86
#248 |
100% Stoich doesn't work. It bogs down after every shift. Went back to tune with Stoich between 1600 and 2800, from.2 to.6 load, and that runs well. @ztan, what minor changes to CL transition did you make?
#249 |
Drives: UK GT86
Reducing or setting the open loop delay counters to 0 really seems to help. I've seen plenty of people suggest to set them to zero.
.: Stealth 86 :.
#250 | |
Drives: Scion FRS
Going slightly rich (very slightly) in the order of 0.95 lambda will give excellent drive feel but ofcourse at cost of FE. OEMs tune the FAR to get best catalytic conv efficiency. So the FAR can vary from lean to rich depending on speed/load and this is engine specific so I cant tell you how it works for FA20. Going CL too long can dip into Scavenging region and it can confuse the O2 sensors causing engine to run rich to compensate for it. |
#251 |
Drives: Scion FRS
My car feels flat all the way to 2.2K rpm. I may go back to OEM cam timings below 2K and follow it up with going 100%DI with some additional spark timing. Right not the IAM =1 all the time so I am sure there is some potential for extra spark timing.
I have seen people get scared by seeing some -0.5 deg knock retard. In the world I work half a degree of spark retard is nothing at below WOT conditions. At WOT ofcourse you dont want a lot of spark pull out but upto a degree is okay as it doesnt change the numbers so much. |
| The Following User Says Thank You to thambu19 For This Useful Post: | steve99 (12-14-2015) |
#252 |
PI 0% better for AT's?
I've been playing around with straight DI, and for an AT it shifts better and accelerates better. Knowing it is limited in the higher rpms and loads I made a map of solid 20% PI, then using the thresholds to limit it, I limited PI to 0% up to 2000 rpm, and out to 1.0 load. I made a pic of the table, above, and the effective percentages, below.
| FR-S Gear Ratio Comparison | SpeedR | Engine, Exhaust, Transmission | 36 | 02-25-2016 09:34 AM |
| Best pistons to use and Comp ratio? | Fabron757 | Forced Induction | 36 | 02-05-2014 03:21 PM |
| Rear End Ratio | White64Goat | Engine, Exhaust, Transmission | 6 | 07-07-2012 11:37 PM |
| FR-S to BRZ Ratio | MannyO | New England | 11 | 03-08-2012 02:23 AM |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 02:40 AM |
