| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#29 |
Replying to my self here, but even of the caliper offset was off, they could have machined the rotor or ran a spacer between the rotor and hub to make it functional if not correct.
#30 |
Drives: race cars
those calipers look like they could be tapped on the other side to ensure the proper piston is on the leading edge, and the bleeder was still on top...
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below. http://fecompetition.wordpress.com/ https://www.facebook.com/FECompetition |
#31 |
Drives: Rx7
Wondering if GRB Spec C are the 6 piston brembo ??
#32 |
ft86club resident b-boy
Drives: Yamaha R3, moonslate 2018 GT Black
4 pot according to text.
#33 |
Drives: Attitude
#34 |
Looks like HKS Kansai put on some GVB brakes for the BRZ
#35 |
#36 | |
Drives: 2013 Scion FR-S, 1993 Lexus SC300
From the picture, and what other pictures I could find, it looks like they are already tapped. The caliper appears to be merely plugged on the non-bleeder side. Might be as easy as simply swapping the bleeder and plug. |
#37 |
Drives: race cars
Even if it's not drilling an tapping a hole is not hard work. Granted u will want to make sure it is done right considering its your brakes. But pressurize air and some grease on the bit should keep metal shavings out of the caliper.
#38 |
Drives: DGM BRZ Limited
Spending that much money on a brake upgrade is a bit much, but then again it covers the front and rear?
I did a Brembo conversion on my sentra. Cost was about $1000 total. Calipers on the front were $200/side. The rears were cheaper. Then rotors were $30/side, and pads are $200 a set from the dealer. I got some cheaper ones, in a factory grade for $35-40. Spending $5k on a brake system is ludicrous. The STI Brembos may not be that great on the STI, but take away 500lbs and they should be more than sufficient for the lightweight BRZ/FRS. I'm running generic pads/rotors on this 400hp sentra and track days are not an issue, though I only drive about 7/10. I'm not a cheap bastard by any means, but it seems like their kit is overpriced by about $3000 at least! |
#40 |
Az to Nm to Az
Auto Produce out of Osaka. Been around for years. 441,000Y at an exchange rate of 79.48 Yen to the USD = $5548.56 That's just outrageous for this car and plain unnecessary.
#41 | |
Don't want to intrude on the discussion guys but I have a 6 piston Wilwood setup sitting at the shop to fit
![]() Quote:
#42 |
At least on the pic of the GReddy car it looks like there's a pipe plug on the opposite side of the bleeder screw. It looks like they're swappable, and if not, it's already been mentioned that they wouldn't be that hard to drill/tap for one. I just get worried seeing the pic of that one red 86 in Japan with a big rusted groove in the rotor; either they installed them incorrectly or the setup just plain doesn't work. I tried contacting GReddy directly to get more info but they never replied.
Won't be a swap that I'll be considering any time soon! The stock brakes in the FR-S/BRZ are fantastic, I found out yesterday!
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
| Brembo BBKs Announced | oneday | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 82 | 06-11-2014 11:51 PM |
| Stock caliper model? | skoodge | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-31-2012 09:41 PM |
| Those Brembos, fixed caliper? Or not? [Patent inside!] | madfast | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 155 | 12-08-2011 03:06 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
