Old 11-22-2015, 09:51 PM   #267
Originally Posted by jcw99 View Post
I was just reviewing that stuff in one of my textbooks about the role of the check valve in the clutch master cylinder and your explanation is better than the book's. I've been looking for my binder with my notes from manual transmission and driveline class for the last week and still haven't run across it.
Old 11-27-2015, 11:49 AM   #268
jcw99
Drives: swp mt '14 brz premium
Smile finally did most of it
Went up to my buddy's on Tuesday and adjusted the clutch rod maybe 2 turns ? Then we installed the slave cylinder. It was getting dark when we finished and I felt better about the clutch but was in a hurry to pick up my daughter so didn't notice it that much at first. Got in the car on Wednesday morning and noticed the difference in the resistance of the pedal immediately. Also, I noticed the engagement point was closer to the floor and much more predictable. I can now adjust my seat the way I want to instead of having it way back in order to accommodate the long throw of the factory adjustment. What an improvement I think I'm going to turn the rod just a wee bit more today. Thanx to everybody who's posted on all these clutch-related threads, especially Ultramaroon, Koji, and Jonnyrocket. Next week we're going to install the MTEC clutch spring. I'll post back with the results.
jcw99 is offline   Reply With Quote
The Following User Says Thank You to jcw99 For This Useful Post:
Ultramaroon (11-28-2015)
Old 11-28-2015, 08:47 AM   #269
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Try removing the spring completely before you try the MTEC. That's free, may give you what you're looking for, and I'm sure a lot on here would like to know if this is worth doing for those of us without the spring.
xxBrun0xx is offline   Reply With Quote
The Following User Says Thank You to xxBrun0xx For This Useful Post:
Old 11-29-2015, 02:38 PM   #270
jcw99
I'll drive it without the spring and then install it later and let you know the difference.
xxBrun0xx (11-30-2015)
Old 11-30-2015, 02:47 PM   #271
Cybmx
Drives: 2016 Hyperblue Brz
hmm, just tried to order the part from Autozone, but upon checkout it seemed to be unavailable to purchase anymore...
Cybmx is offline   Reply With Quote
Old 11-30-2015, 03:00 PM   #272
Wow. Try the NAPA part. It's better quality anyhow.
Or, *cough* you could just use the older wrong part number like the one I have installed. Works just fine.
Cybmx (11-30-2015)
Old 11-30-2015, 08:47 PM   #273
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Yup, I've been using the "wrong" one too.
No issues, what, maybe a year in?
The Following User Says Thank You to continuecrushing For This Useful Post:
Ultramaroon (11-30-2015)
Old 11-30-2015, 10:05 PM   #274
Yeah, It's a smidge shorter and the banjo fitting has to be oriented outside the guide. I watched it for a couple months. No worries.
Old 12-28-2015, 03:59 PM   #275
dalton328
Drives: 2015 FR-S
Hey guys, I recently did this swap. After a little over a week of driving I can say that this new slave is exactly what the car needed. Shorter and stiffer throw on the clutch with a decisive engagement point. I highly recommend this swap to anyone considering it. The only change I would offer is that you use a rubber hose fitted on the bleeder nipple, and bottle filled with brake fluid when bleeding the clutch. It will make it much more difficult to reintroduce air into the line if you are new to bleeding hydraulic lines. Using a flare nut wrench will also help as it won’t fall off in the tight space.
Much thanks to Ultramaroon and everyone else in this thread for the research.
dalton328 is offline   Reply With Quote
The Following 3 Users Say Thank You to dalton328 For This Useful Post:
jcw99 (12-28-2015), LenA (12-30-2015), Ultramaroon (12-29-2015)
Old 12-28-2015, 05:53 PM   #276
jcw99
I agree 100% with your post and welcome to the forum.
Old 12-29-2015, 02:00 AM   #277
Hey guys
Oh, hey! Welcome!
Old 12-30-2015, 04:20 PM   #278
dalton328
Drives: 2015 FR-S
Thanks for the warm welcome. I'm hoping to try the Mtec clutch spring like most others suggest in this thread soon. Maybe after my wallet recovers from Christmas lol
Old 12-30-2015, 05:34 PM   #279
Eldari
Drives: BRZ Limited
Just ordered the slave cylinder at Napa, they said they will have it by 9am tomorrow. They couldn't seem to locate the washers using the subaru number or find anything equivalent. Any suggestions? Is it just a generic washer?
Is there any reason to swap the clutch line other than aesthetics? I could hold off a few days while I wait for a steel braided clutch line from amazon I guess if it's just for looks. Otherwise I could have the cylinder installed tomorrow night if I pick it up after work...
Eldari is offline   Reply With Quote
Old 12-30-2015, 10:28 PM   #280
dalton328
Drives: 2015 FR-S
I just used a generic brake line washer. I don't think most parts stores would regularly stock those kinds of oem parts. If you can't find anything at napa, I know autozone had the washers another user posted in store when I visited.
http://www.autozone.com/brake-system...er/773866_0_0/
clutch line, slave cylinder
Clutch Engagement Improved! enjoyminutemaid Engine, Exhaust, Transmission 53 11-07-2018 07:31 PM
Can steering feel, tactility, be improved? Without sacrificing adjustability? Trettiosjuan Suspension | Chassis | Brakes -- Sponsored by 949 Racing 101 08-16-2016 09:14 PM
Aftermarket Clutch Master and Slave? Yruyur Engine, Exhaust, Transmission 5 07-27-2013 11:22 AM
Hate the feel of the clutch FRSGeek Engine, Exhaust, Transmission 18 07-10-2013 02:24 PM
Clutch feel? Shit Luck Engine, Exhaust, Transmission 5 04-21-2013 06:32 PM
