#99 | |
Drives: FR-S Whiteout
At -5 from full stiff it would skip off the bumpstop or "wallow", but no jolt. (And yes, of course I know these dampers are not designed for circuit driving....) At -1 from full stiff it would no longer skip off the bumpstop or "wallow" mid corner. I'm sure if I took the turns harder it will eventually get down to the bumpstops. The ride quality at -1, while firmer, was still pretty damn comfortable. Makes me wonder whether if the japanse spec Flex-Z and A offer more damping for a more "sportier" ride with the same spring rates. Curious, how much damper stroke is offered in your Flex-A dampers?
Intent > Content
cowardice is the mother of cruelty. |
#100 |
Drives: GT86
Flex A damper stroke front/rear is 93/96.5 mm (from Tein UK)
With motion ratios that becomes at the wheel approx 98/129mm respectively. Fairly normal numbers for a double adjustable lowering coilover, from which you would usually need to substract the height of a compressed bump stop so the Flex A is still quite good... From my calc with the weight of the car on the 6/6 springs, the rears sit in the middle of damper stroke which is good, but the fronts sag more than 60%... |
#101 | |
Drives: Satin White BRZ Limited
#102 |
Drives: 2014 GT86
shattered memory: Zs WILL be better then stock. At DD, and slightly at track, but don't expect miracles, more track focused or higher end offerings on track will outperform it there. So if you pit them against stock, i'd say go for it, at their price they are good. But if you had them in mind for lot of autox/track racing with very grippy tires .. there are better fitting offerings out there.
| The Following User Says Thank You to churchx For This Useful Post: | shattered_memory (11-24-2015) |
#103 | |
Edit: just some background on who developed these dampers. They are specialist who develop race wining suspension for many platforms for race teams around the world including some very well known JDM companies and not some self proclaimed "wise man" on the Internet that "knows everything". Along with the help of a current race technician working for Ferrari (FSC), who also owns a BRZ and runs the same suspension on his car, developed these dampers that I'm currently testing. Y'all can listen and buy into his BS, but I'm done dealing with this troll.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 11-24-2015 at 02:37 PM. |
#104 | |
#105 | |
I had his set to -2.5 f and 2.0r, with about a 18mm drop and 5~8mm rake. I was pretty impressed with these $800 dampers.
Intent > Content
| The Following 2 Users Say Thank You to solidONE For This Useful Post: | CxG (07-26-2017), shattered_memory (11-24-2015) |
#106 | |
Intent > Content
#107 | ||
If you're going past being critically damped on compression to prevent bottoming out, you have a setup error. Yes, you can indeed prevent the compression event from happening by preventing the spring from compressing, so that the force is, instead, transmitted to the chassis. That is , however, exactly what the suspension is NOT supposed to do. The suspension is there to absorb the road force on the car, not pass it on. The real fix, is to properly set up the ride height, so that you are no longer bottoming out the damper over bumps, when the damping is critical (or slightly past critical if you want to play it safe). Side note: maxed damping on the Z is fully useable, but not very comfortable for street driving. You don't have to have a harsh ride to get good handling, but it comes with the territory for any sub-2k damper. |
#108 |
Drives: GT86
So got the springs today and installed them right away.
New Swift spring is green also (they only fit Teins?), nice touch. 178mm instead of 150mm, 7kg instead of 6kg. ![]() Also measured front damper stroke, it is approx 80mm. So 13mm went missing, a good look under the dust boot reveals an very small rubber bump stop, about a third in height of a regular coilover bumpstop... ![]() so much the better considering how the HBS works (see above), but also even more important to get sufficient bump travel before you hit it. Which with the above spring (7kg gives 8mm more) and exactly 7mm preload, bump travel increases 15mm from approx 22mm on the shock (before hitting the above) to approx 37mm, quite a difference! As you can imagine with the increased rate also, the load needed to touch the final bump stop is a lot higher now. As planned, I removed one collar and the springs sits on on the two remaining ones straight on the wheel carrier. Car is about -30mm in front from stock. ![]() Went for a pretty serious drive doing most types of driving and roads, and now the Flex A are exactly as I hoped for. Front and rear feel much more balanced. Played with damping adjustments, only needed to turn the front 1 click firmer compared to the 6kg spring to get it to my liking (now 6/7 clicks front/rear from full firm). The bridge jump felt much calmer and undramatic at 50mph compared to the RCE yellow where one would bounce of the bumpstops and get launched a bit. I dared to increase speed to 56mph but then it started to bottom out just a bit, still less eventful than the RCE yellow. A clear improvement in (bump) performance driving. Also the dreaded reference speed bump. Where before it would very noticeably bottom out at 16mph (with the 6kg spring), now at the same speed it was uneventful. I increased speed to 21mph where it just started to bottom out. Like for like, I estimate the speed went up 6mph (15mph to 21mph), a big increase percentage wise. I didn't feel like going faster, it's the kind of speed that starts to feel unnaturally high for a lowered car. Also on back roads, I feel I can push on as much as I like without getting the distinct impression that front bump stroke is limiting the car, and front and rear seem to hit the HBS at the same time. And in other less bumpy circumstances, it still rides a lot better than the stock dampers. So more peformance, better ride, and yet it sits as low as I'd dare (-30/-25 fr/re from stock). All in all very pleased now with the (modded for my chosen rideheight) Flex A, a real upgrade!
| The Following 4 Users Say Thank You to Trettiosjuan For This Useful Post: |
#109 |
@Trettiosjuan ^ 6/7 click out? Now I'm really curious if these are valved differently than the Flex-Z. When I tested at -5 it still felt quite soft without riding like a boat. And of course the slight bottoming of the rear to the bumpstops cornering at speed. Also the difference between -5 to -1 from full stiff was not very large on the car I tested.
Did you swap out the springs on all 4 corners? Edit: Okay looking a few pages back you stated that these are the Euro/Jap-spec and not the US-spec dampers. So I'm assuming these provide a bit more damping force especially on the compression side.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 11-25-2015 at 07:49 PM. |
#110 |
Drives: GT86
Sorry, 6 clicks front from full firm in front, 7 rear. Corrected in previous post. Recommended is 8/8(Non-US)
Don't know about other people using a wide range of setting on their shocksI always end up strongly prefering one single setting, often close or spot on recommended setting, irrespective the driving done. 1 click out I feel, more than two either way and it feels awful. Like that on KW (different platform) and these. No idea about the Z... Non rebuildable, perhaps different? No just in front, rears are original and without preload. |
| The Following User Says Thank You to Trettiosjuan For This Useful Post: | solidONE (11-25-2015) |
#111 |
Very cool! Glad you were able to get them to how you like them with the 7k/6k combo. If only they published the force vs velocity chart of the different specs. I have a feeling I'm right about the compression damping difference, due to the shittier roads in the US compare to the rest of the developed world.
Intent > Content
#112 | |
Drives: 2013 FR-S Argento
Also, an unrelated topic, but I thought I'd ask here since there's activity: noise - how is noise on these for everyone? Dead quiet? This topic has been discussed in several threads. Some say 'normal' some say 'abnormal'. Installed my set, they're not Flex A's, but they're the slightly older 'street flex' models. Front right had some noise, tightened the top nut and all good. Rear top nuts were tight, had noise, took them off and checked again, they are tightened at or beyond torque specs (didn't loosen and re-tighten them). Reinstalled and I still get a metallic clunk over bumps/potholes, just like others mention. Not loud or really worrying, but it's certainly there. On second install greased the lower mounts too. Springs have slight preload, everything that I can think of is tightened to spec. Long story short - is this really normal or is something broken? Do I need to disassemble the rear hats? It kind of bugs me... |
| Tein Flex A and Z!!! | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 05-24-2016 04:44 PM |
| Tein Flex Z | Bigmaxy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-27-2015 04:22 AM |
| WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 04:12 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
| FS: Tein Flex Coilover | Jade 86 | Brakes, Suspension, Chassis | 43 | 06-15-2013 10:35 PM |
