Old 11-23-2015, 12:16 PM   #15
wheelhaus
wheelhaus's Avatar
What specifically does the TSB fix/change?
Old 11-23-2015, 12:32 PM   #16
On mine they just had to change the weather strip and lifters since it already had the newer switches. I understand that some of the older ones had a different switch installed as well but do not know what was changed in them.
I did not take it in originally for freezing but for the squeal when it was wet. They did both the window/door TSBs and the squeal went away and I had no issues with it freezing. Well, no issues that would not have happened with any other car at any rate since if there is enough ice no window will work right.
wheelhaus (11-23-2015)
Old 11-23-2015, 05:43 PM   #17
Originally Posted by BlueSky View Post
@Tcoat saves the day again !
Yaaaaaaaaaaaaa.......................
Old 11-23-2015, 05:45 PM   #18
@ichitaka05
Another for the FAQ
"My windows froze and now don't work. What do I do?"
Old 11-23-2015, 09:05 PM   #19
@ichitaka05
Another for the FAQ
First you reboot...oh wait...never mind, that's my day job....
KR-S (11-23-2015)
Old 11-23-2015, 09:13 PM   #20
Kickn' it old school
Dadhawk (11-24-2015), KR-S (11-23-2015), Sportsguy83 (11-24-2015)
Old 11-23-2015, 09:32 PM   #21
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
@ichitaka05
Another for the FAQ
Delete system32. That will resolve all issues, guaranteed.
The Following 2 Users Say Thank You to KR-S For This Useful Post:
Dadhawk (11-24-2015), Tcoat (11-23-2015)
Old 11-24-2015, 09:45 AM   #22
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Some fellow IT in the house
BlueSky is offline   Reply With Quote
The Following User Says Thank You to BlueSky For This Useful Post:
Tcoat (11-24-2015)
Old 11-24-2015, 10:31 AM   #23
Well....
http://www.ft86club.com/forums/showthread.php?t=97653
Old 11-24-2015, 10:49 AM   #24
BlueSky
BlueSky's Avatar
LOL I remember reading that thread before
can't believe that worked !
I actually had a similar issue with my 95 Honda prelude
the rear tails would constantly stay on, I would have to pull the fuse every night just so it wouldn't drain
one day I unhooked the battery and it fixed it, should of tried that first being I am IT
Old 12-09-2016, 12:41 PM   #25
yam86
Happy to see other 86's
yam86's Avatar
Drives: FR-S 10 Series
This just saved my life today! My driver side window couldnt go up I panicked a bit for security reasons.
Thanks a lot.
Canadian winter really sucks
yam86 is offline   Reply With Quote
The Following User Says Thank You to yam86 For This Useful Post:
Tcoat (12-09-2016)
Old 12-09-2016, 01:00 PM   #26
Thanks a lot.
One post. Two lives saved!
gramicci101 (12-09-2016), Tectoniic (12-09-2016), yam86 (12-09-2016)
Old 02-07-2022, 03:20 PM   #27
Wingnutt
Drives: Pearl White 2014
I'm stuck having this problem except.. the fix isn't working for me .
The drivers side window is stuck DOWN
the passenger window won't move using the drivers side switch but will work with the passenger side switch.
The drivers side motor clicks when I push the button down but when I hit UP its silent, no response.
I've been fighting this for hours and no luck.
Wingnutt is offline   Reply With Quote
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 03:14 PM
Window Visor and Frozen Window TSB tinma Cosmetic Modification (Interior/Exterior/Lighting) 9 05-19-2015 02:51 AM
Window Visors and Frozen Window TSB tinma CANADA 0 06-17-2014 03:07 PM
Window Scratched by Window Motor / Lifter? tomkozski Issues | Warranty | Recalls / TSB 22 05-31-2014 08:25 AM
squeaky window due to window rubbing against rubber at the top tracerit Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 08-10-2013 06:34 AM
