Old 11-20-2015, 07:46 PM   #309
celek
Resident Gear Head
celek's Avatar
Originally Posted by solidONE View Post
Any thought about necking down the intake ports for increased intake velocity? Or has that been discussed already?
On my to do list once I hot tank these heads and get them to the flow bench in 2 forms. Bone stock and the second set just cleaned up then add putty to see if I can get some velocity.
celek is offline   Reply With Quote
The Following 5 Users Say Thank You to celek For This Useful Post:
Hawk77FT (11-20-2015), Lonewolf (11-23-2015), sato (11-20-2015), Slysdexia (11-20-2015), solidONE (11-20-2015)
Old 11-20-2015, 08:27 PM   #310
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
This thing is going to be sooo sweet!
Intent > Content
Old 11-20-2015, 10:30 PM   #311
stevo585
Drives: White 2014 BRZ
Originally Posted by Dr Speed View Post
I was going to reference some of the EJ25 builds that average about 210rwhp on full N/A builds, bored, oversized pistons, cams, ported heads, headers etc.
Engine/Power Modifications:
EJ251 bored over 100mm
Wiseco 12:1 pistons/rings
EJ257 crank/rods/oil pump
ACL RACE series bearings, std clearances.
EJ251 SOHC heads, ported by owner, stock valve sizes
Delta 3000 grind cams
EJ253 (AVLS) valve springs
06 2.5i intake manifold (big plenum/big runner)
70mm Ford throttlebody
440cc injectors
LinkPlus G1 standalone engine management
TWE prototype longtube header
2.5" aluminum non catted exhaust
2.5" DNA spiralflow muffler
^^^ All this got the owner 204 rwhp on a built 2.5L
The FA20 does not = EJxxx. The combustion camber design is much better and it has DI those alone are very significant and something the aftermarket cant really help.
Id bet money the OP hits 250whp+ especially on e85.
stevo585 is offline   Reply With Quote
Old 11-21-2015, 12:08 AM   #312
MattHoffman
Drives: BRZ Limited
i broke that with 3500$.. just saying. but then again my car is just like 1000 other brzs this will be one of a kind for sure
MattHoffman is offline   Reply With Quote
The Following User Says Thank You to MattHoffman For This Useful Post:
celek (11-23-2015)
Old 11-21-2015, 01:09 AM   #313
Dr Speed
Drives: Red
Originally Posted by sato View Post
Old post: NA 2.5 RS breaking 300hp back in 2005...
http://www.rs25.com/forums/f5/t36040...300-na-hp.html
Sent using tapatalk
Fail. 300hp is a crank horsepower estimate, actual dyno in link is for 235whp and appears to be STD numbers not SAE numbers. No smoothing factor listed... Undoubtedly the car made 215-220ish rwhp SAE
Dr Speed is offline   Reply With Quote
The Following User Says Thank You to Dr Speed For This Useful Post:
DocWalt (11-21-2015)
Old 11-21-2015, 06:51 PM   #314
stevo585
Oh a I agree this is has very low hp/$ ratio. I would not do it myself. A simple super charger kit as you mentioned is more cost effective.
Old 11-23-2015, 10:16 AM   #315
celek
Resident Gear Head
celek's Avatar
This is not the point to the build. Anyone can put FI on this car in fact thousands have already, or swapped in an engine. If you have never driven a built all motor car it is exhilarating. Additionally ask the FI guys how many transmissions they have gone through. The build is following the original grassroots AE86 origin.
The Following 19 Users Say Thank You to celek For This Useful Post:
86 South Africa (11-23-2015), 8R6 (12-04-2015), akyp (11-24-2015), Bykov (02-21-2016), Cole (11-25-2015), CxG (11-23-2015), DocWalt (11-23-2015), FRS Justin (12-15-2015), GT86_PRAGUE (12-10-2015), JDM4E (11-23-2015), JoeeStacks (12-14-2015), Marco_86 (11-30-2015), Mr.Impreza (11-23-2015), new2subaru (11-24-2015), number1Tango (11-27-2015), Phantobe (11-23-2015), sato (11-23-2015), skye67 (07-04-2016), SuperTom (08-25-2018)
Old 11-23-2015, 10:59 AM   #316
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Mr. Tsuchiya-san..NA build
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
The Following 4 Users Say Thank You to Mr.Impreza For This Useful Post:
BRZeer (11-24-2015), CxG (11-23-2015), hmong337 (11-24-2015), Tonypepatone (11-25-2015)
Old 11-23-2015, 11:22 AM   #317
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
celek (11-23-2015), CxG (11-23-2015), Lonewolf (11-23-2015)
Old 11-23-2015, 04:09 PM   #318
stevo585
I know the point of your build is to be different and travel the path not taken. My point is still valid though but its your car and the results will be interesting.
FI guys do go through trannys but not until your over 400+ whp or so. A lot of guys local to me have not broke trannys with power in the 500+ range, thus some of it is driving habits.
I think we can all agree a mild FI build in the 250-325 whp range is going to pretty reliable.
Old 11-23-2015, 05:08 PM   #319
aaguirre123
Drives: sti 2012 sedan
if the average 210 whp that you quoted is accurate then Celek's build is promising because the increased displacement to 2.3 fa20 motor will have a higher whp due to fr-s/brz are rear wheel drive cars. I am assuming of course that the N/A engines that you mentioned are installed in an AWD cars.
my predicted assumption of higher HP result was based on youtube video, by /DRIVE, of Crawford stating that for the same turbo the EJ made 360hp vs. FA20 made 430hp. that's a 19.44% difference. if we apply the 19.44% on 210whp, that's 251whp.
am I correct on my assumption? I sure hope Crawford is not blowing smoke.
440cc injectors
aaguirre123 is offline   Reply With Quote
Old 11-23-2015, 05:29 PM   #320
swarb
Nope. FI and NA are two different ball games. EJ vs FA20 is very much like FA20 vs F20C(s2000 engine), guess who wins by almost the exact same margin?
Old 11-23-2015, 06:34 PM   #321
aaguirre123
Originally Posted by swarb View Post
Nope. FI and NA are two different ball games. EJ vs FA20is very much like FA20 vs F20C(s2000 engine), guess who wins by almost the exact same margin?
comparing performance difference between an I4 to H4 2 liter engines? that's how you want to show that you are correct? that's how you want to argue your point of view? what a ninny.
Old 11-23-2015, 06:35 PM   #322
Dr Speed
Drives: Red
no that was rwhp in my build. You are bench racing. Math and reality are not necessarily the same thing, and a manufactuer is more likely to inflate numbers for marketing, advertising and sales. Also Turbo potential hp figures vs N/A number potential is not equal. I'd divide your 19.44% by 2 or more realistically.
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 06:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 10:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 08:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 10:48 AM
