#85 |
Drives: 2022 BRZ Limited
#86 | |
nowadays GM and Ford makes a lot faster sports cars with a considerably lower price tag than those European sports cars including : M4, S4, AMGs ..etc.. my friend who owns both Camaro SS 1LE and a supercharged Miata gets similar lap times in our local tracks and swears that the 1LE has a similar turn in and handling response ..many people say the same for the GT-R, maybe because it has huge/sticky 305/30/19 tires all around and the cutting edge spool valve suspension that is used in F1 cars
#87 | |||||
Time Traveller
Upgrading just about any $26k car with OEM selected LSD, shocks, brakes, wheels, tires and aero is going to improve the cars' dynamics and performance pretty drastically. Just the tires, dampers, or springs alone will reflect marked measurable gains (that's why people upgrade them at all). Specifically in the Everyday Driver video, both guys speak of how the Launch Edition MX-5 is lacking dynamically in comparison to either 86 they tested. This is very much a different result than we've seen with the Clubsport edition MX-5's tested by R&T and C&D. Plainly, upgrading a Miata with $6k in mods has made enough of an improvement to sway journalists opinions. IMO that contrast is what makes the Everyday Driver video so relevant. True, even I admit to repeating my point, however this repetition is a reaction. Like I said, every time the $6k difference in cost from Miata base to Miata Clubsport is attempted to be swept under the rug, I have every right to bring it back up. If people stop trying to minimize that fact, I'll have no need to mention it. The fact that some have attempted to repeatedly minimize that much money in upgrades is what really blows my mind. Quote:
Also I flat out disagree with the notion that the upgraded Bilstein's and likely the springs too are a minor difference. A well tuned and damped suspension adds traction under all conditions which improve both driver confidence and lap times. Lastly, with all due respect, please don't try to speak for anyone but yourself. Using "we" instead of "I" doesn't bolster your point at all. You seem like a knowledgeable person. Even if I don't agree with some of your opinions, I'd listen to them even if they came just from you. |
#88 | |
Drives: 13 Hot Lava, 01 Miata, 09 Outback
A Camaro weighs an entire Lotus 7 more than a Miata. I can't deny the appeal of a V8 grumble. I get it. I'm not putting down the cars or the people who drive them - just not my preference. Some guys like girls with round bottoms, some guys prefer busty ladies. There's no real right or wrong preference there. -Justin |
#89 | |
Time Traveller
| The Following 2 Users Say Thank You to DAEMANO For This Useful Post: | glamcem (11-03-2015), strat61caster (11-03-2015) |
#90 | ||
Drives: 2019 MX-5 RF GT-S, 2002 Miata LS
You can find specs on the stock spring rates for past generations, so I figure it's only a matter of time until we know what the ND has. Actually, I went back and checked that thread: http://forum.miata.net/vb/showpost.p...3&postcount=71 The Sport (and presumably GT) rates were measured at 156/80, and the Club at 150/100, and I assume that's lb/in. The measurements were taken by two different people with probably different equipment, so likely the front rates are the same and it's the rears that have gotten 20% stiffer or thereabouts. That makes sense given Mazda's commentary that they changed the springs instead of the rear sway bar. Quote:
) shocks, I dunno. I wouldn't mind being proven wrong if ever a journalist decides to test both, might make my decision of which trim to get a little easier.
| The Following 2 Users Say Thank You to Entroper For This Useful Post: | DAEMANO (11-03-2015), strat61caster (11-03-2015) |
#91 | |
Time Traveller
The 20% increase in rear spring rate is dynamically significant in that it was probably added to balance the handling of what was likely an initially understeering base MX-5 (assuming that the base MX-5 was setup to initially understeer as most road cars are). This would make the Miata feel more crisp on it's turn in and also more controllable with just the throttle. All base 86's now share this handling trait (minor initial understeer) since the FR-S was matched to the BRZ rates in 2014. This initial understeer is considered more safe on the street, but less desirable for spirited driving. It can be dialed out in many ways adding front end mechanical grip is one. Todd noted this when speaking about some of the advantages of the MPSS tire upgrade on his FR-S. |
| The Following User Says Thank You to DAEMANO For This Useful Post: | Entroper (11-03-2015) |
#92 | |
Regardless, if you can find three tire tests showing the Twins see no improvement (or even better, get slower) switching to MP tires, we can weigh the evidence and figure out which set of tests is more convincing. Until then, it's all a bit moot. To date, I haven't seen a single test that concludes the Twins don't improve on MP tires, but there are three that say they do. Four, if you include the Nurburgring test (which I threw out).
2022 BRZ Build 2013 FR-S Build |
#93 |
Spring rates don't really matter for cars that are designed to corner on the bump stops
Drive upgrades. Don't buy them.
#94 | |
Time Traveller
http://honda-tech.com/suspension-bra...uning-3058735/ http://eibach.com/america/en/motorsp...ries/bumpstops |
#95 | |
#96 |
Drives: Red
I don't really like the podcast that these guys put out. At first it seemed good, but their material is weak, they talk about the same cars repeatedly in references, very annoying.
I take most car reviews with a grain of salt. I have loved cars that others have hated and hated cars that others rave about. I expect the obvious outcome with them having an FRS as a long term review.. they will drive it, like it to an extent, reference it non stop as a comparison to similar and different cars, grow tired of it, complain and build gripes and eventually dump it within 2-3 years... Last edited by Dr Speed; 11-13-2015 at 11:05 AM. |
| The Following User Says Thank You to Dr Speed For This Useful Post: | raven1231 (11-13-2015) |
#97 |
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Did you guys know that the CoG of the 2016 Mx5 is 18.5 inches? So it's is .4 inches higher than the 86 despite the fact that the Mx5's height is 2 inches lower than the 86.
| The Following User Says Thank You to SUB-FT86 For This Useful Post: | Dr Speed (11-13-2015) |
#98 |
| BRZ and the WRX everyday driver video | mokinbird87 | FR-S / BRZ vs.... | 51 | 07-09-2014 11:56 AM |
| Everyday Driver: BRZ vs WRX | l0aded | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 11 | 07-04-2014 06:03 AM |
| FR-S vs RX-8 vs S2000 Review - Everyday Driver | switchlanez | FR-S / BRZ vs.... | 222 | 07-03-2013 06:45 PM |
| FRS VS BRZ - EVERYDAY DRIVER | Motopythons | BRZ Photos, Videos, Wallpapers, Gallery Forum | 19 | 07-03-2012 05:59 PM |
