View Poll Results: Do you have the described AT issues?
Yes, but I've ignored them 41 34.17%
Yes, TSB fixed it 14 11.67%
Yes, dealer fix did not help 12 10.00%
No everything is fine 53 44.17%
Voters: 120. You may not vote on this poll
Old 11-09-2015, 06:20 PM   #15
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
I commented in another thread, but I had the TSB done for the idle hunt issue that seemed to accompany hard shifting for me. So far so good. BUT I want to give this time before I make a conclusion.
V_86 is offline   Reply With Quote
Old 11-09-2015, 08:22 PM   #16
OpteronO3
Drives: 2013 Scion FRS
Originally Posted by MechEGR View Post
My dealer and I are sure it's a software issue, mainly due to the fact that the issues completely go away after restarting the car.
See this is so frustrating. My dealership totally denies the whole thing. I've learned how to drive my car without triggering this problem. But now I can't get the full experience out of my car.
I'm going to try a few other dealerships before I call it quits and get rid of this car.
OpteronO3 is offline   Reply With Quote
Old 11-09-2015, 08:28 PM   #17
V_86
V_86's Avatar
Try different dealers. The one I went to gave no fight whatsoever about doing the TSB. I went there after reproducing the idle hunt issue that accompanies it (for me) and the service guys even said "it makes it sound like it has a cam in it." BUT I also printed out the TSB for them and showed it to them. They attached it to the pre-service invoice.
Old 11-09-2015, 11:20 PM   #18
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Has anybody with the hard shifting issue tried the TSB for idle hunting yet?? I tried to get it done but they had problems flashing my TCM.
Originally Posted by V_86 View Post
I've had two FRS autos. Both have had the issue. Both have it nearly always when I go back and forth from D to M following driving at highway speeds. Both have accompanying rev hunting issue when put in park after hard shifting starts. The only "fix" is to immediately start in M when going on a spirited drive, OR reset the computer by restarting car at a light or stop sign. At the next service I will point out the TSB for the rev hunting and see if it does anything.
UPDATE: had the TSB done, so far so good, but I will give it a week and report back.
V_86 Has done the TSB to good effect so far, I have to wait two weeks before I'll have a chance to get it done
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
MechEGR (11-11-2015)
Old 11-10-2015, 11:58 AM   #19
OpteronO3
If my VIN is not in the TSB range would the still accept it?
Old 11-10-2015, 01:30 PM   #20
V_86
V_86's Avatar
Idk, but does not hurt to ask. IF you have idle hunt issues they should try it I would think.
The Following User Says Thank You to V_86 For This Useful Post:
OpteronO3 (11-10-2015)
Old 11-13-2015, 05:28 PM   #21
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
wasn't aware of this thread and it seems to describe perfectly the issues i have been having with weird idling especially putting it in park.
TSB will be a nice reason to go to the dealership to have them fill up the coolant as it they didn't last time and now it is low.
EDIT: Since this seems to only need adjusting to the TCU and from my quick read won't involve the ECU, has anyone gone in with an OFT tune still on the car or did you flash back to stock before bringing it in?
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 11-13-2015, 06:45 PM   #22
V_86
V_86's Avatar
Tomorrow will be one week since I had the TSB done. Again I want more time to say anything definitive, but the TSB for idle hunting seems to have fixed my hard shifting issues as well.
The Following 2 Users Say Thank You to V_86 For This Useful Post:
93Targa (11-13-2015), MechEGR (11-16-2015)
Old 11-16-2015, 09:38 AM   #23
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I'm taking mine in this afternoon for the update and i'll update if this seems to help. I should be able to notice as soon as I get home if it is fixed or not.
I was told that my VIN was outside of the recall but I 100% have this issue(early MY15 AT). I'm wishing I had recorded it happening because knowing my luck it will not show up when I bring it to the dealership....
The Following User Says Thank You to Tectoniic For This Useful Post:
KalbiCool88 (04-25-2016)
Old 11-16-2015, 11:50 AM   #24
V_86
V_86's Avatar
My understanding is that you should flash back to stock tune. However, if they check they can still tell you ran OFT. I would try a dealer that is more mod friendly.
Old 11-16-2015, 12:07 PM   #25
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I've been to the dealership with tune, headers, and e85 and they are fine with it. I was just wondering if they will be doing any updating to the ECU or purely the TCU as I don't want my OFT to become unmarried. I think i'm just going to leave the tune at this point since it is an hour away. I guess I can let people know if the TCU update will be safe with OFT....fingers crossed
Old 11-16-2015, 02:11 PM   #26
V_86
V_86's Avatar
The TSB is only to the TCM, not the ECU. Different computers. Manual FRS don't even have the wire harness on the back of the plastic engine cover, so its a separate system.
Old 11-17-2015, 09:59 AM   #27
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I had the TCU updated per the TSB and now my 1 -> 2 and 2 -> 3 shifts feel a lot smoother. I haven't done any testing yet in sport mode to see if it blips the throttle on downshifts again but that was honestly the least of my worries. It also doesn't have the idle dip anymore when it is put in park after driving.
I think they may have flashed the ECU as well back to the stock tune. This could definitely be placebo effect but the the exhaust note sounds different especially at 4k+ rpm which I know OFT has some changes that actually effect that and the engine is also having very slight knock correction, ~-0.29 for FLKC, at ~1500 RPM with 15-20% throttle.
MechEGR (11-17-2015)
Old 11-17-2015, 10:06 AM   #28
Cole
Not a troll
Cole's Avatar
You could just plug your OFT in and check...
Cole is offline   Reply With Quote
AT Transmission Hard Shifting MechEGR Issues | Warranty | Recalls / TSB 95 05-21-2017 11:54 AM
AT transmission hard shifting issues calic Issues | Warranty | Recalls / TSB 44 11-09-2015 06:17 PM
3 min fix for 2nd gear hard shifting Black Tire Engine, Exhaust, Transmission 22 03-23-2014 12:13 PM
Transmission noise when up shifting after hard rev 1Cor10:23 Engine, Exhaust, Transmission 2 09-03-2013 03:22 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 02:22 PM
