Old 11-06-2015, 10:27 AM   #1
theoriginalkyler
Drives: 2018 86
Noisy transmission 3 months after fluid change with motul
So 3 months ago I decided to change the rear diff and transmission fluid to Motul 300. My fluid levels are good. But when cold there's a loud whining sound in reverse, i understand cars are going to make noise in reverse but the noise is really excessive and just started happening. Is this a characteristic of this fluid. does anybody else have this issue. I definitely hear it when its cold. It's a hit or miss when its hot. Thanks
theoriginalkyler is offline   Reply With Quote
Old 11-06-2015, 10:35 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Any stiffer mounts or bushings? This usually happens when stiffening up the drivetrain.
Does not have to do with the fluid, unless you have a leak and your fluid is running low.
Old 11-06-2015, 11:42 AM   #3
theoriginalkyler
Drives: 2018 86
No dont the have any stiffer mounts or bushings. Only Cusco rear Lcas but that is irrelevant. Checked my fluid and it's perfect. Guess its internal transmission. Just wanted to check with Motul 300 users to see if they had this issue
Old 11-07-2015, 09:57 AM   #4
Tekno Virus
Drives: 2015 Subaru BRZ Limited
No issues here with Motul 300. Now that I think about it, I don't remember hearing the reverse gear ever in this car. Usually there is a small gear whine in other cars.
Tekno Virus is offline   Reply With Quote
Old 11-07-2015, 11:05 AM   #5
theoriginalkyler
Drives: 2018 86
Yea I have almost 20k on the car and have never heard noise in reverse before. Guess I gotta take it in.
Old 11-07-2015, 01:14 PM   #6
stugray
Drives: 2013 GBS BRZ Limited
I have 35k with Motul 300 in the trans and the diff.
No issues here.
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 08:55 PM
Change your manual transmission fluid ASAP!!! Kostamojen Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 383 12-12-2016 10:29 AM
Transmission fluid change from dealership? Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 10-15-2014 01:52 AM
Transmission fluid blending Redline MTL and Motul Gear 300 okay? imom Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 11-01-2013 09:03 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 07:01 PM
