Old 06-06-2012, 09:08 AM   #43
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
The civic is anything but lightweight anymore. :p
Memphis is offline   Reply With Quote
Old 06-06-2012, 10:31 AM   #44
R36 almost
Drives: 2006 VW Passat 3.6 4Motion
Originally Posted by moniz View Post
5.8 to 100? What car do you drive? The 1.8T I get, cause it has a little more torque than the FR-S that comes on pretty early, but pretty sure it doesn't handle as well as the FR-S, which is one of it's biggest reasons for being.
I drive a 06 Passat 3.6 4Motion (chipped) - 310hp and 290lbft. It gives 5.8sec to 100
The jetta is stage-2 Unitronic, exhaust and tiny upgrades which gives around 250hp. It faster in straight line and sounds better, but obviously doesn't handle like FRS.
FRS feels light ton its feet.
R36 almost is offline   Reply With Quote
Old 06-06-2012, 10:34 AM   #45
R36 almost
Originally Posted by vtmike View Post
I traded my neon srt-4 in on a manual FRS and was pleasantly surprised with the low end torque. Moves this light car quickly with instant throttle response. Still not past the break in period so haven't been past 4k rpms yet though. It feels plenty quick to me. If you are worried about straight line speed take an on ramp at 70 mph and feel the car squeeze out every ounce of grip from the prius tires, the zero body role, and perfect steering and you forget about any sluggish straight line speed.
You don't go above 4000rpm...lol
I guy at toyota dealership who went for test drive with me told me to rev the shit of the car (1 day old car), turn off traction control and give it a slide..hahahaha
Old 06-06-2012, 10:36 AM   #46
pr086
Drives: fast
compared to other cars of TODAY it is. my 07 si is 2850lbs. the frs is only about 100lbs lighter.
pr086 is offline   Reply With Quote
The Following User Says Thank You to pr086 For This Useful Post:
ngabdala (06-06-2012)
Old 06-06-2012, 11:25 AM   #47
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I don't think it will compare to that nice VTECH feel and the civic has so many options for additional performance. The question is, what is the BRZ/FR-S performance options going to be down the road. And, do you want your front two tires smoking with torque steer or your two rear tires, better CoG, lower ride, etc. Give it a test drive first.
Originally Posted by pr086 View Post
i'll be coming from an 8th gen too and i'm worried about this car not feeling as fast. they both have the same idea when it comes to what the car is about. high reving, light weight, handling focused machines. and on paper the frs SHOULD be a little faster. about 150 lbs lighter, and a little more torque.
however it doesn't rev as high or as fast, so i'm a little worried about it not feeling as quick.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 06-06-2012, 11:26 AM   #48
ngabdala
+1 as is mine and my 2011 Si is fairly neutral, no understeer.
Old 06-06-2012, 11:43 AM   #49
thill
I would think the FR-S and BRZ would feel as fast as an 8th Civic SI. Tested results through various sites like Motortrend and Edmunds show acceleration being very close if not in favor of the FR-S. Like the Vtec engines, max torque is not reached until the higher rev areas so it should feel similar I would think. A drive will let you know pretty fast.
Old 06-06-2012, 02:29 PM   #50
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by Bristecom View Post
I actually feel that a lot of newer sports cars have too much power for the road. They are more serious and typically aren't fun unless you push them to unsafe levels where you might get caught by the police. Of course, I'm probably going to be drifting this thing around every corner so if some d-bag hater cop sees me, he'll probably throw my ass in jail for "reckless driving."
This is why I believe in the Goldilock ways when it comes to everything including power and torque.My favorite engines is 6 cylinders since they typically aren't torqueless or overpowered. I still think the FRS deserved a 2.3-2.5 flat four.
SUB-FT86 is offline   Reply With Quote
Old 06-06-2012, 02:30 PM   #51
vtmike
vtmike's Avatar
Drives: Scion FR-S
I got the car before anyone else got to drive it, so it wan't run hard. I like to go by what the manual suggests for the break in being I plan on keeping this car for a long time.
vtmike is offline   Reply With Quote
Old 06-06-2012, 03:09 PM   #52
Capt Canuck
Drives: BMW E36 323is
On other hand, if u need power form frs, you HAVE t rev it all the way to 6000. So in daily commute it will be slow, unless u rev it. But them fuel eco will be worse. Seats were very tight, I'm 185lb and 6".
See this I have never understood. How will it be 'slow' in your daily commute? You are governed by speed limit and traffic flow and since this car can attain at least 120km/h there should be no roads it can travel on in Canada for which it is too slow.
Your daily commute doesn't include Calabogie race circuit, does it?
Capt Canuck is offline   Reply With Quote
Old 06-06-2012, 03:25 PM   #53
R36 almost
I love it when you say my commute has a race trace..lolol
sometimes you want to overtake cars or need to speed up quickly, power helps!!! with this low torque, i needs to be revved to 6000.
Personally, i like to have lot of power. Im sure FRS owners will be happy if they looking for nimble car.
On other hand, if you drive that car in winter while wearing a jacket, good luck fitting in those bucket seats (unless you are skinny) They are very snug.
Many buyers will look for exhaust upgrade as well, because it doesn't sound any sporty
Old 06-06-2012, 03:28 PM   #54
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Yeah, same. NA 6 cylinders are the sweet spot. And yeah, I still think they would have been better off with a higher displacement but at least it didn't disappoint me on first impression.
BTW, did you ever get to drive it? If so, what did you think?
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 06-06-2012, 03:49 PM   #55
...sometimes you want to overtake cars or need to speed up quickly, power helps!!! with this low torque, i needs to be revved to 6000....
The nice thing is that the 86 gets above 4K quickly and loves living there. Honestly, that is part of the reason I so excited about the FR-S and its mates. You GET to run it at the edge in traffic without immediately endangering your license to drive. It's why I loved the MK1 MR2 so much.
I love speed/power/torque too, the second car on my shopping list was a Camaro ZL1. I would NEVER have gotten to drive the ZL1 like I drive the FR-S.
Just food for thought, everybody has different wants/desires/needs. That's why all cars are not built equal.
Old 06-06-2012, 03:58 PM   #56
R8
Spinning Triangles
R8's Avatar
Drives: RX-8
One advantage though, for me anyway, is that low-torque cars can be easier to navigate around in tight, slow spaces like parking lots. Keep the revs low, and the car is very docile, easier (for me anyway) to manuever around.
With high-torque cars I'm always on edge, worried that the slightest tap of the pedal will cause it to go forward too fast.
Handy during snow driving too, as keeping the revs low reduces the chances of accidental wheel spin from all that torque.
So I actually like that split-personality of low-torque, high-revving cars
R8 is offline   Reply With Quote
Test drove a FRS! Walked away.. Enigmus Scion FR-S / Toyota 86 GT86 General Forum 43 06-23-2012 10:34 PM
Test Drove an FR-S! Gaiakai Scion FR-S / Toyota 86 GT86 General Forum 2 05-30-2012 01:20 AM
Test drove FR-S A/T last night LUV2TURN Scion FR-S / Toyota 86 GT86 General Forum 6 05-24-2012 12:04 PM
I Test drove the BRZ today! Sexy Beast! Mango22 BRZ First-Gen (2012+) — General Topics 81 04-07-2012 10:56 PM
