| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#155 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
LMAO
#156 | |
Re-member
Drives: Toyota camry
Nothing decays like progress, and nothing preserves like neglect.
#157 |
Drives: SSM LT MT BRZ
#158 |
Drives: 2018 Golf R
Heres my break in procedure:
-No constant speeds -No cruise control -No WOT shifts (youre breaking in a clutch at the same time....) -Slowly increase you revs as you put on the miles. Im at 7xx miles on my FR-S right now and Im revving it up to ~6k rpm every now and then, just to build some heat in the motor. Im also giving it ~80% throttle here and threre to put some load on the engine. I didnt rev past 4k rpm for the first 200 miles or so. But I would apply load to the engine, about 50% throttle. From ~200 miles up to 400, I would rev to 4500, 400-500miles was 5k, 5-600 was 5500rpm, and so on. Im slowly increasing the throttle input as the miles add up as well. By 1000miles, I should be bringing it to or at least near redline. Thats my break in, not overly harsh nor "grandma-ish"
Parting out HERE
#159 | |
Techmology.
Drives: Scrapped project EH2
#160 |
Drives: Honda Fit
@ ahausheer + mrtodd:
Good points. A few related items: --Some engines seem to perform better than others. At least, that's what my dyno operator guy says. Is it because of how the engine was broken in? Hard to say. --Some break-in discussions include talk of heat cycling. Again, given an engine with any miles already on it, this may be irrelevant. I frankly cannot recall if we have discussed this in the thread already. |
#161 |
Attack By Demons
Drives: 2022 BRZ (pre ordered)
i'm taking it easy...not passing over 4,000rpm just waiting for the 1,000 mark then i'll go over the 4k mark then at my 3,000 i'll do a oil change and I'll have fun at the track
#attackbydemons #imcomingbackbish
#162 |
Drives: 2013 Whiteout 6sp
From what I understand, Toyota was worried about the well known issue of Subaru running oil and blowing the bottom ring lands out of their pistons. This is mostly on their turbo cars. Nonetheless Toyota suggested a thicker mineral-enriched oil to be left in the engine for 5k miles. Something Toyota has not done in recent years. While I was in Torrance at Toyota/Scion they told me it was the only restriction they have put on a break in period on their entire Scion lineup.
So here is what I was told..... 1000 miles don't go over 4k rpm. Don't use the cruise control. Don't drop the clutch. I don't even have 200 miles on the car. It's killing me to be so so careful. But I've waited for this car for way too long. I will drive like I'm being watched and data logged. |
| The Following User Says Thank You to TheChopShop For This Useful Post: | Marrk (06-05-2012) |
#163 |
Drives: Scion FRS Ht Lva(AT)
The reason they don;t want you to use cruise control is so that the engine does not run at a fixed rpm for a long time. You want as much variation in rpm as possible for the breakin period. I usually run at different engine rpms in different gears on the highway to get that breakin. so run at 100kph for a while, then at 90 kph then at 80 kph then 90kph then 80 kph then 100 kph mix it up and change the order. That way the engine sees a variety of rpm's.
That has always worked for me and I have had cars for 20+ years. |
| The Following User Says Thank You to smbrm For This Useful Post: | Marrk (06-05-2012) |
#164 | |
Drives: Honda Fit
x 2. |
#165 | |
#166 |
Lex Luger
Drives: 2004 GS430
car is @ 500 miles, seems to be loosening up nicely!
| The Following User Says Thank You to YukiHachiRoku For This Useful Post: | blu_ (06-05-2012) |
#167 |
Drives: 2013 Whiteout FR-S
Drove it under 4k rpms for the first 885 miles.
Then took it to 6k rpms It def loves the top end for power! |
#168 |
Scrape Master
Drives: Goal: Oldest FRS State Side
I broke at 220mi, went to a empty parking lot in the mountains by me and took it sideways in second (wet pavement) and then i gave it a tiny launch (did not dump the clutch but released it kinda fast) so i hope i did not do any damage to the car :P
| Tags |
| break-in |
