Old 11-17-2014, 01:36 PM   #99
qoncept
qoncept's Avatar
My lights are running without external power without any "showstopper" issues, but it's definitely not ideal. Once the headlights/driving lights turn on it goes in to some sort of limp mode that lights my gauges up like a Christmas tree and disables ABS and cruise. Trailer lights are incandescent and I would guess LED would be fine, but I'll be replacing it with a powered part whenever I get off my lazy ass. It's been over a year
qoncept is offline   Reply With Quote
Old 12-01-2014, 04:57 PM   #100
philooo
Drives: 13' Scion FRS Track car
I am selling a tire trailer if someone is interested make me an offer if you are local south florida, trailer is in fort lauderdale
http://rennlist.com/forums/parts-mar...e-trailer.html
philooo is offline   Reply With Quote
Old 12-02-2014, 08:25 PM   #101
MTeator
First 86
I'm not sure but I was under the impression the power was due to having separate turn/stop signalling on the FRS (and many other cars) so the powered part converts them to a single wire for a trailer light via relays to the straight vehicle power. Or some similar combination of electrical sounding words.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 12-03-2014, 10:30 AM   #102
qoncept
qoncept's Avatar
Well, that's the point of the adapter I have in the car now, but it's not externally powered. It combines/splits/whatever so the power for the car lights hits the right circuits in the trailer lights but there isn't enough power to handle driving lights plus brakes.
Old 12-06-2014, 08:32 PM   #103
MTeator
First 86
Gotcha. Well I can at least say that the powered one I have worked fine with both the regular and LED lights. It certainly takes more work to install though.
Old 05-06-2015, 11:21 PM   #104
Jack Black
Drives: 2015 FR-S
Towed the bike about 1500 miles with no issues. You might say it went off without a hitch.
Jack Black is offline   Reply With Quote
The Following 4 Users Say Thank You to Jack Black For This Useful Post:
hmong337 (03-14-2017), Hyper4mance2k (07-03-2015), qoncept (05-07-2015), Slambert (05-07-2015)
Old 08-25-2015, 04:07 PM   #105
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
Picked up my twin hitch the other day, curious if you guys are towing on a tune or stock setup? I'd feel pretty confident stock but not sure on tune.. Mods are grimmspeed intake, open flash header, evo gt catback, e85 tune. Don't mind running the 91 tune just whatever would be the safest setup on the car. MAXIMUM weight would a very small trailer (5x8ish), in car luggage small passanger, and 2 honda groms (200lbs each). Distance would be ranging from 10 miles or Missouri to California and back.
cameronjones239 is offline   Reply With Quote
Old 10-23-2015, 12:50 PM   #106
Slambert
Drives: Fast
Cool tire trailer video from Speed Academy up in Canada
[ame="https://www.youtube.com/watch?v=_DFJG24EAWo"]We Get Hitched! - Scion FR-S Track Build - EP11 - Final Episode - YouTube[/ame]
Slambert is offline   Reply With Quote
The Following 2 Users Say Thank You to Slambert For This Useful Post:
Blu-by-U (05-09-2016), Scooby South (10-23-2015)
Old 10-30-2015, 08:44 AM   #107
Lebby83
Drives: 2019 BRZ, 2016 Touareg
I will be adding one of these to my BRZ in the Spring.
For anyone who has a trailer, how and where did you hook the wiring up for lights?
Thanks for any insight.
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
Old 10-30-2015, 10:47 AM   #108
Slambert
Drives: Fast
Thanks for nay insight.
Here's the one I recommend. Plug and Play and less than $50.
https://www.curtmfg.com/masterlibrar..._56212_INS.PDF
Old 10-30-2015, 01:11 PM   #109
Lebby83
Thanks!
Rob
2016 VW Touareg TDI
Old 11-06-2015, 12:49 PM   #110
Jack Black
Drives: 2015 FR-S
I think that's the one I used (if not the same then essentially identical). The main pain point is running a wire from the trunk up to the battery. I wouldn't exactly call it "plug and play" because of that, but it wasn't too bad. You can run the wire under/behind interior trim along the passenger's side pretty easily.
Old 05-09-2016, 02:17 AM   #111
number_Un0
Drives: 2013 FRS 10 series #0001
I was wondering if this type of motorcycle hitch would work or would this have too much tongue weight?
number_Un0 is offline   Reply With Quote
Old 05-09-2016, 01:11 PM   #112
qoncept
qoncept's Avatar
Yikes.. I wouldn't do it. The hitches do fine pulling things laterally but those racks put a lot of torque on them, and the load is going to be about 200lbs. I saw someone with a hitch that attached to the rear tow hook points with a threaded rod - maybe triangulating to them could make it work.
WTB: 1 OEM FRS/BRZ Tire RedFR-s Canada Classifieds 3 11-08-2013 11:43 AM
Tire Noise? Admiral Ballsy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 07-04-2013 09:02 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
WTB One (1) OEM Tire Trojan_SC Wheels and Tires 2 05-07-2013 03:59 PM
What tire PSI are you using SEC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-30-2012 09:09 AM
