Old 10-24-2015, 03:54 PM   #1
OgCruzing
Jdm noob
Drives: 2016 Frs Stock
Frs bolt pattern
Anyone know the bolt pattern on a 2016 Frs, is it a 5x100?
If so is there any conversion kits for a 114.3?
OgCruzing is offline   Reply With Quote
Old 10-24-2015, 03:56 PM   #2
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
5x100
You can buy a spacer which converts it there's a few vendors that sell them.
Old 10-24-2015, 06:09 PM   #3
irax
irax's Avatar
Drives: 2015 Subaru BRZ WRB
So there used to be kits available, but then people figured out how to do it using OEM subaru parts.
But really, getting hub centric and wheel centric spacers will be like 1/10th the cost.
irax is offline   Reply With Quote
Old 10-26-2015, 12:28 PM   #4
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Do you know which OEM subaru parts are used to swap it from 5x100 to 5x114.3? Just curious.
Bach415 is offline   Reply With Quote
Old 10-26-2015, 02:43 PM   #5
irax
irax's Avatar
The megan kit
https://www.meganracing.com/products...=1580&catid=97
or you can use
bug eye front spindles
and sti rear hubs
there is a lot of info out there. but in the end really for about $100 you can get some bolt on hub adapters and you will be much happier.
Old 10-26-2015, 04:25 PM   #6
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
We run ISC conversion spacers on our shop car for the Volks we run and wide fender flares. Pretty simple option, as others have stated.
http://www.ft86speedfactory.com/isc-...l#.Vi5-NvlVhBc
FT-86 SpeedFactory is offline   Reply With Quote
Old 01-03-2017, 10:21 PM   #7
eztygr
Drives: Toyota
The megan kit
or you can use
and sti rear hubs
Old thread, but Irax do you have any more info on, or can you point me to info on the bug eye front spindle use? I haven't seen anything about this and Bug Eyes were 5x100
eztygr is offline   Reply With Quote
Old 01-06-2017, 10:35 AM   #8
irax
irax's Avatar
I don't really remember any more.
I know there was a couple threads about it on NASIOC
But MeganRacing has their conversion hubs back in stock
bolt pattern probs markm7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-19-2014 06:39 PM
Bolt Pattern Adapters Flat Black VW Tracking / Autocross / HPDE / Drifting 7 04-13-2013 02:06 PM
Bolt Pattern Woes TSLRich Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-30-2012 12:30 AM
bolt pattern is 5x100? derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-30-2012 03:58 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 07:04 PM
