Southern California SoCal
Old 10-25-2015, 09:49 PM   #15
ExxelDistributions
ExxelDistributions's Avatar
Drives: 2014 FR-S 6MT Monogram Series
Originally Posted by ryoma View Post
what about catless headers, assuming it passes the visual? if there is a code relating to the cat that comes up, but a tune "hides" it as labeling it unready/not warmed up (or however a tune hides the cat CEL). I know some states only allow around 1 or 2 unready codes before they fail you or tell you to come back later. I am not sure if CA allows that.
Catless headers are not allowed. Reason being is because under the visual inspection we need to input modified for the visual catalytic converter test. So its not about emissions its about the visual.
For readiness monitors.
2000-newer cars only EVAP monitor can be incomplete for car to pass.
1999-older only 1 monitor can be incomplete for car to pass. either monitor is fine.
Some counties dont require dyno test which are areas that have only basic testing and not advance testing. Major cities are advance testing which we use dynos. But since the Smog program changed in the summer its completely different.
How do I know this.
I am a smog tech that has a shop. thats all
ExxelDistributions is offline   Reply With Quote
The Following 2 Users Say Thank You to ExxelDistributions For This Useful Post:
LXXXV1 (10-26-2015), ryoma (10-25-2015)
Old 10-25-2015, 09:50 PM   #16
ExxelDistributions
Originally Posted by mav1178 View Post
Entirely depends on where you live. Some counties in CA are completely exempt from smog testing... but people in other parts of the country just hate on CA as a whole.
http://www.smogcheck.ca.gov/pubwebqu...ZipLookup.aspx
http://www.smogcheck.ca.gov/FormsPub...k_Program.html
Map of different smog requirements in California:
http://www.smogcheck.ca.gov/pdf/Program_Map.pdf
the map of different smog requirements is really old actually.
Old 10-25-2015, 09:51 PM   #17
ExxelDistributions
Originally Posted by LANI86 View Post
*Deep breath*....Thank you RevolutioN.
The thing is I just bought a new CATBACK exhaust and was just about to install it and came across this thread and scared the crap out of me.
Catback is fine so dont worry
Catless header will pass a sniffer test?
Good luck with that...
we dont do emissions testing on 2000-newer cars anymore.
Old 10-25-2015, 11:06 PM   #18
LANI86
Drives: 2015 Scion FR-S
Wow, no wonder you're resourceful. That's cool that you own smog shop.
LANI86 is offline   Reply With Quote
The Following User Says Thank You to LANI86 For This Useful Post:
ExxelDistributions (10-26-2015)
Old 10-26-2015, 12:27 AM   #19
ExxelDistributions
Anything smog related just ask!
Old 10-26-2015, 12:52 AM   #20
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
What about aftermarket secondary cats, ie the one found in the mid-pipe? Will that fail visual inspection?
Sent from my XT1060 using Tapatalk
Old 10-26-2015, 01:06 AM   #21
DannyQ86
Drives: 2013 frs
Aren't newer cars smog exempt for like 5 years? So like a 2013 would be good until 18/19 just pay registration and abatement fee?
DannyQ86 is offline   Reply With Quote
Old 10-26-2015, 01:40 AM   #22
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Lemme clarify this....well, see if I understood right.
On our twins we no longer have emission (tube in car exhaust) part for smog?
Old 10-26-2015, 09:46 AM   #23
ExxelDistributions
If it has a aftermarket secondary cat in CA it must have a CARB label on it. If you change it with a cat that isnt carb legal and has a carb label on it then no its wont pass the visual.
new cars off the dealer lot when bought brand new are smog exempt for 6 years. But if you bring a car from out of state doesnt matter what year or mileage you need to get it smogged.
thats correct. 2000 and newer cars dont require emission testing
BigFatFlip (10-26-2015), DannyQ86 (10-26-2015)
Old 10-26-2015, 12:33 PM   #24
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
So everything posted on http://smogcheck.ca.gov/ is false?
Edit: I am not doubting what you are saying. The last two times I've had to smog any car, both have involved tailpipe testing on a roller dyno. Both were within the last 4 years.
-alex
Old 10-26-2015, 01:41 PM   #25
DannyQ86
Drives: 2013 frs
I believe the way they do smog has changed within the last year
Old 10-26-2015, 02:10 PM   #26
ExxelDistributions
-alex
State changes rules yearly. They came up with the DAD System (new smog machine all shops had to buy) in June 2015 and ever since then it has been that way.
Old 10-27-2015, 12:04 AM   #27
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
I recently smogged our 09 mazda3 and it was able to pass with a non-CARB aftermarket second cat. Maybe its because it looked stock or the place I went to didn't do visual check.
Wondering if the Berk Hi-flow cat on the BRZ will pass? Anyone try yet?
ronboogieon is offline   Reply With Quote
Old 10-27-2015, 03:36 AM   #28
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
So let's say I gutted my stock header and front pipe... and run my e85 tune it will still pass? :O
jaorocks1 is offline   Reply With Quote
Smog check for out of state people? goshem Southern California 4 09-25-2015 07:20 PM
CA Smog Check?? JG Southern California 22 06-08-2015 12:05 PM
WARNING!!!! Monday 1/26 CHP SMOG check in Orange County-Cross streets-Lambert/Idaho continuecrushing Southern California 13 01-27-2015 12:19 AM
Need advice on passing smog in California rmak321 Northern California 7 07-12-2014 01:52 AM
Smog check and visual inspection help Corradooo Northern California 24 05-20-2014 12:57 AM
