Old 10-23-2015, 05:50 PM   #2577
EzyBrzy
Drives: 2015 WRB BRZ
Its possible they won't find any codes, but it will definitely fail visual inspection.
Is it noticeable from the engine bay? Or would they actually go as far as getting under the car to look?
EzyBrzy is offline
Old 10-23-2015, 06:10 PM   #2578
phrosty
You can see it from the engine bay.
phrosty is offline
Old 10-23-2015, 06:13 PM   #2579
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Super Wabbit View Post
So if I can condense the past few pages (check my "math"): This header is specifically does the following:
  1. Can reduce/eliminate the torque dip without tuning or further modifications.
  2. Adds a little bit of rumble without significantly increasing the sound level of the exhaust.
It is a standalone part, minimizing the amount of work that needs to be done to eliminate the torque dip. If you're using this in combination with other mods, you may have to get a custom tune...as we've come to expect.
So it seems like a lot of the negative comments, specifically those centered around CEL codes, are coming from a misunderstanding of what this product is intended to do.
You are pretty much correct. I think a handful of the negative comments are a mix of confusion and miscommunication. A handful of owners bought the header and "tuned" it with an OFT, thinking that it would get rid of the CEL, which it doesn't since its the tunes are an off the shelf UEL tune.
If you look through the thread, you'll find views of the header from the engine bay like this:
This one in particular was ceramic coated by the owner, but the new versions will have a "FT86SpeedFactory" tacked on one of the runners. So if you have an inspector who knows what they are looking for, its a pretty big giveaway. Doesn't mean you can't swap your stock headers in during inspection...
BigFatFlip is offline
The Following User Says Thank You to BigFatFlip For This Useful Post:
EzyBrzy (10-23-2015)
Old 10-23-2015, 06:47 PM   #2580
churchx
churchx's Avatar
Drives: 2014 GT86
I'd rather think of making some simple fake cover above it first before swapping back to stock
churchx is offline
Old 11-05-2015, 09:19 AM   #2581
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Originally Posted by Mr.Impreza View Post
Really Cel still came on with OFT? weird....
This is the thing that has steered me away from this header. I liked the sound and that it was quiet...but i see a lot of people have issues with the tune. Like you get CEL....stage 2 runs poorly on it unless you do a custom tune....just better off going catless oft stage 2
Get a ECUTEK tune from a reputable tuner, easiest way. I'm currently running my own street tune and disabled the check engine light after it popped up after 3 months, and since then I have completely uncatted my header.
You will get a cel regardless of cat, so I would suggest just diving into a catless header like the tomei or Gruppe-S, and get a ECUTEK tune, and it might end up cheaper than the ft86 header plus OFT tune.
Cartman is offline
Old 12-13-2015, 04:24 AM   #2582
Fishbed77
Fishbed77's Avatar
Drives: 2013 FR-S 6MT Whiteout
Has anyone tried this with a Perrin 3" resonated cat-back? Any CELs?
Fishbed77 is offline
Old 12-13-2015, 04:35 AM   #2583
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You won't get a cel with a catback.
Andrew025 is offline
Old 12-13-2015, 08:27 AM   #2584
FTemplar
Drives: BRZ Sport-tech 2013
Yes you will. (Or may) Ive had it 3 times over 6 months now but nothing that Torque cant handle. I have a catback + K&N air filter that's it...
Sent from my MotoG3 using Tapatalk
FTemplar is offline
Old 12-13-2015, 11:35 AM   #2585
steve99
Drives: FT86
Originally Posted by FT-86 SpeedFactory View Post
There is no OFT tune for our header so of course it will issue a CEL. An Ecutek or custom OFT map will be needed.
Luckly the OFT tunes are open so just disable the P0420 cel code in the stage 1 tune (for catted header) = no more CEL code. About 5 minutes, if you having a beer while doing it :-)
steve99 is offline
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Cole (12-13-2015), tato.valverde (12-16-2015)
Old 12-13-2015, 11:41 AM   #2586
steve99
Drives: FT86
No you wont get a CEL from a Catback , you either have other issues like an exhaust leak near o2 sensors or sensor problem
CEL code for CAT efficiency is P0420
It very likely your cel is due to your intake throwing off fuel trims/or AFR causing rich/lean CEL codes.
next time it come up read the code.
steve99 is offline
Old 12-13-2015, 11:47 AM   #2587
FTemplar
No you wont get a CEL from a Catback unless you have other issues like an exhaust leak near o2 sensors or sensor problem
I bet money your cel is due to your intake throwing off fuel trims/or AFR causing rich/lean CEL codes.
Sir, you CAN get a CEL running this header + catback. Like I said, I have gotten it 3 times over a period of 6 months... don't mind the other codes, they are related to my remote starter that I am testing right now. I wouldn't be surprised if just variations in ambient temperature and mositure % can make the CEL show up...
FTemplar is offline
Old 12-13-2015, 11:57 AM   #2588
steve99
Drives: FT86
The catback is so far away from the 02 sensors that monitor the primary cat in the header it would be virtually impossible for it to have any effect on the reading of those sensors.
you either have an exhaust leak, stuffed o2 sensor or your primary CAT is actually stuffed, if you track cars or drive them hard enough its possible to overheat and disintegrate the primary cat in header. It the only one monitored by ECU.
It also possible that your intake (assume its untuned as you would have disable CEL in tune) is throwing of the fueling enough to be causing the cat efficiency cel as well.
The ECU derives that cel from comparing the reading from the primary and secondary o2 sensors either side of the primary cat in the header, abnormal reading caused by missing or damaged cat, fueling way off exhaust leaks etc will cause it.
never heard of anyone getting that cel from a catback.
YES its possible to get this cel with ANY aftermarket CATTED header as the readings are different from stock cat.
A CATBACK by itself will not cause that P0420 cel
steve99 is offline
Old 12-13-2015, 11:59 AM   #2589
FTemplar
I'm not versed as well as you are in mecanics, all I know is that my car is stock except for my catback and air filter, but if you're right then i'm gonna have to have my header's cat checked out then. Not that it's a huge annoyance right now but still.
FTemplar is offline
The Following User Says Thank You to FTemplar For This Useful Post:
steve99 (12-13-2015)
Old 12-13-2015, 12:06 PM   #2590
steve99
Drives: FT86
mis-read your post thought you had K&N intake if its just a filter that wont be a problem unless its an oiled filter and its been over oiled and oil has got on maf sensor.
A number of guys with tracked cars have completly blown out primary cat in header.
With stock catted header you should not get the P0420 cel code unless something is wrong.
If its an aftermarket catted header then yes P0420 is possible, as the aftermarket cat may not match the charasteristics of the stock cat in header. some people will never get the cel some will occasionally.
steve99 is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 11:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 01:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 01:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 01:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 11:12 PM
