| Member's Car Journals Car journals by our members. |
Drives: 2013 WRB BRZ
HKS GT Supercharger v2 |BRZ DD & Track
Current as of February 2017
October 2015 Modification list Interior Suede dash mat TRD Shift knob Weather Tech floor mat HKS OB link Beat Sonic 7" Tablet Mount Exterior CCW D240 18x9.5 Michelin Pilot Supersports OEM style rear diffuser STI Gurney Flap Velox Adjustable Race Splitter Velox Front Splitter End Plates Driveway Labs Side Splitters Suspension Cusco front tower brace w/ brake stop Cusco rear lower control arms (LCA) Cusco rear toe arms HKS Hipermax SP coil overs Brakes DBA rotors Stop tech SS brake lines Motul high temp brake fluid Exhaust HKS EL header w/ Catted front pipe HKS Legamax axle back muffler Engine ECUTek re-flash by Delicious Tuning Flash & Go Delicious Tuning 11 PSI Map Sensor HKS hybrid intake filter HKS SC oil cooler HKS high flow oil filter GrimmSpeed light weight crank pulley Nameless Performance cam plate GReddy oil plug HKS GT Supercharger v2 - as of August 23, 2015 Exhaust clip (just in-case anyone was considering a similar setup). No CEL nor torque dip. [ame="https://www.youtube.com/watch?v=-Mx0d4nUibE"]BRZ FRS GT86 HKS Catted Header & Legamax Muffler - YouTube[/ame] The idea of this build is to enhance what's already there however, parts must be purposeful and somewhat proven at the track. Brake fade was handled by installing DBA rotors, SS brake lines, and high temp brake fluid. FYSA, the stock pads will melt a bit at the track (had to get some life out them before I installed the Hawk pads). Credit goes to FT86SpeedFactory.com for a legit brake setup. Lateral G's increased by HKS Hipermax SPs. These coilovers out perform their looks. Well everything wasn't exactly for performance unless looks count? The oil cooler kept things relatively cool. After four 20min of wide open throttle there was nothing to worry about. Fender liner modification for oil cooler. Bumper modification to let air get to the cooler. I need to make a bigger hole. . . Checked temperature using HKS Carscope. Installed this after rounding off the stock bolt. Up next, the GT Supercharger To be continued . . . Last edited by craigpitts7; 02-26-2017 at 06:09 PM. |
| The Following User Says Thank You to craigpitts7 For This Useful Post: | shifter907 (08-19-2015) |
#2 |
HKS GT Supercharger installed
After about 14 hours of labor, I was able to complete the install of the GT Supercharger. Keep in mind that I am by no means a grease monkey. So someone with experience can probably get this done in half the time.
Here's a picture of the engine bay Radiator cut out. I didn't cut enough of the radiator support. Put a piece of rubber pipe to keep off metal on metal contact. Larger engine bay view Picture of MAP sensor. I'm currently waiting on a good sensor so I drive the car. I think I received a dud. Brake vacuum hose modification Oil dip stick bracket Oil dip stick relocation This canister purge solenoid was kicking my behind. Below is a picture of it located under the intake manifold in the back of the engine. Its the hex bolt peeking out. The charger from the left Last edited by craigpitts7; 02-26-2017 at 05:37 PM. |
#3 |
HKS GT Supercharger installed cont . . .
Right side of engine bay
Here is a picture of the inlet pipe bracket. This is a well engineered kit. Traction fluid tank for the charger and airbox modification. The engine bay incomplete I plan to do another exhaust clip with the supercharger installed. As of now I have to wait for a MAP sensor to come in. Hence I left the cover off. I want to reiterate that this is a well engineered kit. It bolted up as if it was a factory part besides of the modifications to prep for the installation (that's another story). I am impressed with the fit and finish of the kit. It is superb! If only I could get a good drive . . . to be continued Last edited by craigpitts7; 02-26-2017 at 05:26 PM. |
#4 |
Here is a short clip of the HKS GT Supercharger v2. The car runs great and the power is incredible. Delicious Tuning delivered a spectacular tune.
[ame="https://www.youtube.com/watch?v=b0_n0H8R5lk"]HKS GT Supercharger v2 BRZ - YouTube[/ame] Driving about testing RaceRom. Warning low quality video. [ame="https://www.youtube.com/watch?v=z28Gqk4dbV4"]BRZ HKS GT Supercharger Test Drive - YouTube[/ame] Beat-Sonic provided the tablet mount. I'm using the Samsung Galaxy TAB 4 which was too small but a cover gave it more height to fit. Last edited by craigpitts7; 02-26-2017 at 05:39 PM. |
| The Following User Says Thank You to craigpitts7 For This Useful Post: | 10Stars (10-03-2015) |
#5 |
Drives: 14 Subaru BRZ Limited WRB
Nice build. Any recent videos?
I plan on getting the V3 sometime in the future. Not sure if I should go with the HKS included Flash Editor or with Delicious Tuning(e-tune). |
#6 | |
Sent from my HTC6435LVW using Tapatalk
#7 | |
Seeing the HKS owners thread with all the failures as well kinda turned me off but im still very interested in the kit now with the revised V3. Looking forward to your build |
| The Following User Says Thank You to 10Stars For This Useful Post: | craigpitts7 (10-03-2015) |
#8 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Talk about HKS fanboy! :p
Just kidding. Nice build. I have that same brake kit, and it works great.
#9 |
#10 |
Unboxing of ccw's
#12 |
Pictures!
| The Following 2 Users Say Thank You to craigpitts7 For This Useful Post: | CxG (03-17-2016), Summerwolf (10-21-2016) |
#13 |
Dash Mat Suede Mat
I was impressed how well the Suede Mat fit. I think it adds to a retro feel.
#14 |
Road Atlanta June 11-12 2016
This was my first track event with the Supercharger. The car held up through two days of abuse without a problem.
Road Atlanta is a high-speed track and the FT86SpeedFactory brake upgrade kit held up multiple laps without any noticeable fade. [ame="https://www.youtube.com/watch?v=9WROY1nD2Vs"]Road Atlanta - HKS Supercharged BRZ - YouTube[/ame]
| The Following User Says Thank You to craigpitts7 For This Useful Post: | ajaxthebetter (06-18-2016) |
| Tags |
| daily driven, hks brz exhaust, hks coilovers, oil cooler, track build |
| Pixel67's Daily Driver Build - Journal | pixel67 | Member's Car Journals | 44 | 06-16-2016 10:48 PM |
| Build Document: Autocross & Daily Driver (FR-S, Argento, M/T, Base) | bimmer635csi | Member's Car Journals | 32 | 02-07-2015 12:19 PM |
| Daily Driver + Autocross/Track Car build on a Budget | ToyoburuBRZ | Member's Car Journals | 29 | 12-19-2014 09:32 AM |
| Mr. Sociable's BRZ Daily Driver (slow) Build | Mr. Sociable | Member's Car Journals | 23 | 11-01-2012 09:46 AM |
