#85 |
Drives:
Mines just went today also. Luckily I found another motor so no downtime while I repair this one. I am going to call element tuning on Monday to see what they can do for me. I don't understand the whole swedge thing. Note that I had misfire issues and P0301 codes before this happened. I would make a pull and the car would hesitate at high RPMS and the CEL would flash momentarily. Well this morning when I went to my trusted mechanic we changed the coil packs and the spark plugs out hoping it would cure the misfiring (not knowing about this rocker failure), after he put the new plug in we took it on track and big puff of white smoke came from the car. I thought it was a piston melted. When we put it up on the lift we saw the hole in the valve cover. So more researching and I found this recent thread. This sucks that some of us are unlucky like this. I hope my recently bought motor doesn't do this either.
#86 |
@DaiTT500: sorry to hear about your motor. Was this on your JRSC stock pulley on e85? Do you or others think we should 'preventively' fix these rocker arms when FI'ed?
#87 | |
Drives:
Yes it was on my stock pulley e85 but I think this could have happen to my motor if it was NA. I think it's poor quality control on them. I think this is a small case but not sure.
| The Following User Says Thank You to DaiTT500 For This Useful Post: | dj2020 (08-29-2015) |
#88 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Seems there might be a market for quality rockers. Wish someone would jump on that.
#89 |
Corner Junkie
The engine is out.
![]() The Carnage: Some Disassembly Acquired ![]() It took a big bite out of the head along with nibbles here and there. The lifter hiding in shame ![]() I'm blaming this guy, and you'll see why later. There was scarring along the side of the lifter, but I can't be sure if it was the cause or result of the failure. The home of the lifter ![]() ![]() It's difficult to see, but there is damage around the lip of the hole. Dun-dun-DAA! The Rocker ![]() ![]() Note the pin, while starting to walk, is still in place. The roller spins freely too. I have two theories. 1. The lifter failed somehow. Either it somehow wasn't supplied oil (there are no other signs of oil starvation in the head) or it somehow bound up in its seat. This let it retract into the head far enough to let the rocker come free. 2. The walking pin in the rocker allowed the roller to bind up and overheat, locking the roller. But the roller isn't discolored like it would be if it overheated, and the cam doesn't show signs of that it was grinding against a stuck roller. I'm leaning towards #1, a lifter failure of some sort, as the cause. The question now becomes. How do we prevent this from happening again? And is it worth doing, or would it be more practical to just get a replacement head and hope it doesn't happen again? I love this car, and the last weekend I had it it was brilliant. But I wonder if an outside observer would think it unwise to stick with this car... |
#90 |
Drives:
Similar destruction but not as bad as yours. My lifter shot out of the valve cover I think. I could not find it.
![]() ![]() ![]() ![]() ![]() Since its not so bad, I am rebuilding the whole motor with stronger parts.
| The Following User Says Thank You to DaiTT500 For This Useful Post: | Draco-REX (10-16-2015) |
#91 |
Corner Junkie
#92 |
Drives:
Pop goes the BRZ. Advice please.
I've talk to the big engine builders for FA20 and they said stock does fine. It's the springs that aren't tensioner enough that lets this all happen. Replacing it with a set of better valve springs will prevent this.
| The Following 3 Users Say Thank You to DaiTT500 For This Useful Post: |
#93 |
Corner Junkie
Interesting. If that's the case, then a good set of springs and new set of rockers (to cherry-pick the best set) are in order.
#94 |
Drives: Late 2014 Subaru BRZ
When you have the springs out for upgrades, can you take a pictures of the springs tension weight? 55? Thinking we're seeing valve float and piston kissing. After the piston kissed the valve the valve divorces the rocker.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#95 |
Drives: SAS supercharged 4Runner
Has these springs been updated in the 2016 version of the FRS?
#96 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#97 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Just springs should be enough. If you're going that route go for the beehive version of GSC. They are lighter and stronger and should help keep those rockers from getting banged up to 8k+.
| The Following User Says Thank You to Xero-Limit For This Useful Post: | Draco-REX (10-16-2015) |
#98 | |
Corner Junkie
Also, I'm still at the stock redvline. Any downsides I should be knowledgeable about? Thanks. |
| The Following User Says Thank You to Draco-REX For This Useful Post: | strat61caster (10-16-2015) |
| I Need Advice About An Fr-s! | DViper0020 | Issues | Warranty | Recalls / TSB | 13 | 05-09-2014 11:15 AM |
| Some advice | zoomzoomers | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 04-22-2013 06:16 PM |
| Advice | EDCOVEY | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 12-10-2012 09:16 AM |
| Need advice | Ikmv | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-23-2012 01:17 AM |
| Need advice | FRSMAK86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 08-06-2012 06:39 PM |
