go_a_way1
Old 10-07-2015, 04:30 PM   #2997
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
@CSG Mike I'm pretty damn lazy, especially at 7 AM. You definitely answered my question! LOL
LOLS2K is offline   Reply With Quote
Old 10-12-2015, 11:24 PM   #2998
GeorgeJFrick
GeorgeJFrick's Avatar
Drives: 2013 Subaru BRZ Limited LR
Just finished second season of track days/autox. Car is stock (zII* spec). Learned a lot.
Considering coilovers for next season, and while not really looking for a specific coil-over recommendation; I'm looking for information relevant to my goals.
Will I learn more by spending quality time with something like the KW variant 3's, where there is a lot I can adjust; or do you recommend a more entry level set where I'm dialing less and they are 'set' stiffer? I'm told the KW's are worth it for the warranty; but the Tein street flex are considerably more affordable. I've read a million threads about this and I don't have a clear answer when trying to balance durability, learning and investment.
If it helps, I started this season nose diving into corners, jacking the front about 3 psi higher than the rear. By the end of the season I was keeping all 4 tires at the same psi through the course.
I don't want to fall behind on learning to work directly with the suspension; while still focusing on earning seconds instead of buying them. I realize a set of springs may be a start, but again I'd like to start adjusting (even badly) and get that experience.
Would it be beneficial to get, for example; a set of RCE's and camber plates? Then I'd be lower and be able to work with the camber adjustment? How much is there to learn there when the money could be in the KWs?
tldr; What's the best suspension change to learn from; and if coil-overs are worth it; what coil-over do you recommend? My current choices are Feal 441, Tein SF, and KW V3.
GeorgeJFrick is offline   Reply With Quote
The Following 2 Users Say Thank You to GeorgeJFrick For This Useful Post:
Cop (10-13-2015), CSG Mike (10-13-2015)
Old 10-13-2015, 01:28 AM   #2999
CSG Mike
CSG Mike's Avatar
It sounds like you want to learn.
I'm gonna say KW V3 with some stiffer rear springs, and/or a rear sway bar.
Let us know when you're ready.
GeorgeJFrick (10-13-2015)
Old 10-13-2015, 11:18 AM   #3000
ka-t_240
Well, my racing season has came to an end. I am one of those people that likes to spend time and experience observing the things my car does on track that I don't like and planning the best action to fix/improve those issues. I know have about 10 track days and 15 autox events under my belt in the car.
I have noticed at the last couple track days that I seem to be able to get my ABS to activate under straight line threshold breaking on the road course. It feels like front wheels only, but not sure how to tell for sure.
I read many many posts about the brake bias being horrible on these cars, is that the cause of my issue? Or do I have a setup/driver improvement oppertunity? I never really noticed this with the HP+ in my car, but I have also started to become much more comfortable with the car and starting to push it a bit further.
Suspension: RCE T2, RCE Sways, RLCA, subframe/diff bushings, perrin steering lockdown, and Grimmspeed Strut Bar.
Alignment: -2.6 Camber/0 Toe Front and -2.0 Camber/Slight Toe in rear
Brakes: DTC60 Pads(F/R) Centric Blank Rotors(F/R), Grimmspeed Master Cylinder Brace, Stainless Lines, RBF600 Fluid.
Wheels/Tires: 17x9 RPF1 and 245 RE-71R
What is everyone's thoughts?
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
Old 10-13-2015, 12:22 PM   #3001
GeorgeJFrick
Ok, so...
1) KW V3
2) Cusco Catch Can
3) Motul Maintenance Package (sport) (found on csg website).
4) SS Brake lines.
Is the catch can the best preventive/longevity change I can do? (I already have an ATI harmonic balancer going in). Or is there something more important to do in terms of preventing Catastrophic Hobby Termination?
Old 10-13-2015, 12:25 PM   #3002
Racecomp Engineering
With the bold part in mind, I'd recommend investing in a datalogging system over the winter. You'll be able to see exactly what's happening with your braking issue for example.
- Andrew
Old 10-13-2015, 12:27 PM   #3003
Ok, so...
1) KW V3
2) Cusco Catch Can
4) SS Brake lines.
Just curious...why do you have KW V3 in your list and not RCE Tarmac 2 coilovers? You seem like you're familiar with RCE products and a track day guy.
You can PM me if you have any questions about them.
- Andrew
Old 10-13-2015, 01:10 PM   #3004
CSG Mike
CSG Mike's Avatar
Are you pedal dancing? How long are your brake pads lasting yuo?
Old 10-13-2015, 01:18 PM   #3005
GeorgeJFrick
- Andrew
Unfortunately I don't have a good answer for you. It looks like with adjustable top hats I'm spending $2800.00 either way. That's the majority of an entire years' race budget for me (I'm no baller). You make a good point in regards to doing further research (I looked at RCE springs and your RCE Lite package, but not your coil-overs).
Looking back, I shouldn't have mentioned RCE, I should have just said "springs and top hats", as the brand mentioning may have affected CSG Mike's recommendation.
I don't have enough information to make a decision to even get the KWs at this point. I'd probably have to go with no top hats (which makes me lean back towards the Teins, but then I have all experts telling me KW v3).
My apologies; this wasn't meant to really be about brands, but an approach to learning suspension tuning. It sounds like its on me to make these decisions, but it feels like there is a chasm between beginner and intermediate. The original question was about choosing an upgrade for systematically exploring ways across.
Old 10-13-2015, 01:51 PM   #3006
Gotcha...no worries at all and thanks for the feedback!
I think you're going about things the right way. Going from beginner to intermediate is a great time to stop and think about pathways and the direction you want to go with your car. Research time for sure. Take your time. There's lots of knowledgeable suspension and track guys and girls on here who'd be glad to help.
- andrew
Old 10-13-2015, 01:57 PM   #3007
ka-t_240
-Not Doing the Dance.
- Pad Life -
HP+: 10k Street, I am guessing 15 days of autox, and 6.5 hpde days. Fronts have 30% left and rears had about half.
DTC60: Will be removed this week. They have 3.5 HPDE Days, 2k street miles, 6 autox events. Not sure on how much pad is left, haven't had them out since 2 events ago when they looked to be almost new.
I will see the "nanny" turn on once or twice a session.
Old 10-13-2015, 01:59 PM   #3008
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Can pulling a fuse disable the ABS without making the car go into some kind of limp mode? If so, which one? I tried pulling the ABS fuse once before, and the car did not like it at all. Even the steering had issues.
Old 10-13-2015, 02:01 PM   #3009
ka-t_240
- Andrew
What system are you thinking? Most of my friends use Traqmates. Working with Myles on the suspension setup over the last 2 years has done nothing but improve the car. Now I just need to buy some scales.
Old 10-13-2015, 02:14 PM   #3010
CSG Mike
CSG Mike's Avatar
We like the AIM Solo DL; the OBD2 interface on newer cars is KEY to dissecting what's going on.
They're in-stock and ready to go.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
