Fart-noise maker
Drives: 2014 Scion FR-S
Let's talk about lift kits...
Most people it seems have been lowering their GT86, but I've only seen a couple of them lifted - ever so slightly. With this in mind, what are my options for lifting my FR-S?
Naturally you're probably wondering what my ultimate goal is? Not sure. I'd love to have one of those muscle-car-converted-to-off-roader type of cars, but with the modern styling of an Asian import. Not a mudder or rock crawler, just something that can handle non-pavement and look the part. Bigger tires are a must, which would necessitate smaller wheels. Beyond that, I'm not sure. So what are my options or where should I look/talk with? |
#2 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
![]() I dont think this is the right car for that TBH. There are rally kits out there though. I will see if I can find one for you. Here is the JDM TRD rally coils http://www.trdparts.jp/release/2014_...uspension.html |
#3 |
Drives: White out Scion Frs
Sorry my friend I think you bought the wrong car.
Sent from my SAMSUNG-SM-G900AZ using Tapatalk |
#4 |
A rally type FRS would be dope though.
| The Following User Says Thank You to Chrisgalactic For This Useful Post: | JazzleSAURUS (10-12-2015) |
#5 |
Drives: 2013 Ultramarine FR-S
Talk with nameless performance. Their GT86/FRS/BRZ rally car seems to be pretty competitive. They can probably help you set up something that meet your needs.
The world needs more 86 rally builds. |
| The Following 5 Users Say Thank You to Freeman For This Useful Post: | djliquidsteele (10-09-2015), JazzleSAURUS (10-12-2015), lamawithonel (10-18-2015), why? (10-09-2015), WRB-DZA-BRZ (10-12-2015) |
#6 |
Drives: Scion FR-S
^^^^^^^^^^What that guy said. To each their own guys. Its his car. Educate and let him make his own decision.
I would start with nameless. They can set you down the right path. |
#7 |
Drives: Sterling BRZ Ltd
Lift spacers are easy enough, I lifted my STI and loved it. If I use this car in the winter I would do lift this too
#8 |
Drives: 2014 GT86
Lift spacers are easy & cheap .. but they do nothing to shock travel, just rise initial ground clearance. I'd rather try to get coilovers with more travel for rallying purposes. That TRD one sounds interesting. Nameless .. yes, they made nice rally car .. but wasn't it with completely custom designed rally suspension not so much attributable to car for common folks/common budget levels? As for myself .. i found my GT86 fun & drivable enough on reasonable quality gravel roads even on stock suspension. Of course given my lack of skills and not going competitively fast. Just faster then normal driving and sideways on turns
#9 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
I was also in the weird awkward group of folks who wanted a lift. Granted, I just needed about an inch or so, so it wasn't as extreme as you. I was able to get my lift with a combination of my Ohlins (ride height adjustable) and slightly taller tires (moving from 215/45 to 225/45).
If you search around, you are not the only one: http://www.ft86club.com/forums/showthread.php?t=14131 http://www.ft86club.com/forums/showthread.php?t=52010 http://www.ft86club.com/forums/showthread.php?t=67283 http://www.ft86club.com/forums/showthread.php?t=7201 Keep searching around the forums and you'll get more inspiration. Its actually surprisingly easy to get some off road/rally suspension for this car since th fronts are WRX and the rears are legacy, but it would most likely cost you a pretty penny (the limiting factor would be the control arms, be ready for lots of custom fabrication work). I would suggest the Subtle solutions spacers http://www.subtle-solutions.com/prod...roducts_id=284 along with a smaller wheel and taller tires. Have fun and good luck |
| The Following User Says Thank You to BigFatFlip For This Useful Post: | TofuJoe (10-10-2015) |
#10 |
Ohne Titel
Drives: 2017 BRZ PP ISM
I wonder how DirtFish has their BRZ rally cars set up? Maybe they could give you some info:
http://www.dirtfish.com/rally-school...r-wheel-drive/ |
#11 | |
#12 |
Because compromise ®
Drives: Red Herring
I don't know if Nameless are still on the same dampers as when they started their rally build but they started off with MCA Golds which is a weird choice given that MCA are a small (3 people) Australian damper designer/builder with, to the best of my knowledge, no overseas support.
#13 | |
Not weird if you've ever talked to Jason. He's got a love for all things Australian. |
#14 |
Drives: Red Herring
That would explain the weird and somewhat inappropriate emails I get from him.
| The Following 3 Users Say Thank You to Captain Snooze For This Useful Post: |
| Where to Lift with Two Post Lift? | Don Ivey | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 08-18-2022 08:51 AM |
| EZCarLift Easy car lift portable super easy car lift | bren5279 | Mechanical Maintenance and Tools | 16 | 09-11-2015 01:57 PM |
| Car talk | calis5nest | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 05-02-2013 02:04 PM |
| TSI offers HIDGUY HID kits and LED lighing! $95 kits SHIPPED! We won't be beat! | Lisa@TrueStreetIndustries | Exterior Parts - Lighting | 129 | 01-18-2013 08:57 PM |
