Koji_Online
Old 09-09-2015, 12:10 AM   #631
bizintine
bizintine's Avatar
Drives: 2013 whiteout frs
Adjusted mine today to just below the brake pedal. I absolutely love the quick engagement. I have yet again fallen in love with this car! One thing I did notice was what looks like a rubber washer coming loose. Should I be concerned?
bizintine is offline   Reply With Quote
Old 09-09-2015, 04:35 AM   #632
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I could be wrong, but that looks like some kind of a retaining spring, and is supposed to look like that to keep the plunger shaft from coming out of the master cylinder body.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
The Following User Says Thank You to Target70 For This Useful Post:
bizintine (09-09-2015)
Old 09-09-2015, 01:21 PM   #633
Nope. You're good.
You are correct, sir.
Old 09-09-2015, 05:06 PM   #634
bizintine
bizintine's Avatar
Nope. You're good.
whew okay. I was a bit worried it wasn't fully extended and might be riding itself. thanks!
Old 09-09-2015, 05:27 PM   #635
If you get down in there and watch while just a little by hand you push-release the pedal, you will notice the little spherical part of the plunger bottom into the washer which is held in place with the circlip.
There's no substitute for just observing it first hand.
Old 09-09-2015, 06:01 PM   #636
bizintine
bizintine's Avatar
so as long as the spherical part is pressed up against the washer then it is fully retracted correct?
The Following User Says Thank You to bizintine For This Useful Post:
sato (09-09-2015)
Old 09-09-2015, 06:04 PM   #637
Yes. BINGO!
Old 09-14-2015, 10:19 AM   #638
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
Originally Posted by Koji_Online View Post
I've messed with different points all week & let me save you R&D; the most comfortable point for intuitive starts/ rolls off the clutch, & heel-toe downshifting; screw in until the clutch pedal sits ever so slightly lower than your brake pedal.
The DIY was super helpful and this part about the clutch height compared to the brake pedal was just what I needed. Also did the clutch spring removal while I was down there and there's a big improvement in the feel of the clutch.
rookie is offline   Reply With Quote
Old 10-09-2015, 02:03 PM   #639
yaguphire
Drives: white-out FR-S
I want to bring bite point higher seemed over time it lowered. To do this do I turn the rod clockwise?
yaguphire is offline   Reply With Quote
The Following User Says Thank You to yaguphire For This Useful Post:
Ultramaroon (10-09-2015)
Old 10-09-2015, 02:18 PM   #640
edit :clockwise from the viewpoint of the driver
Old 10-09-2015, 02:21 PM   #641
yaguphire
counterclockwise from the viewpoint of the driver. Rod goes deeper into the clevis.
Viewpoint of the driver meaning if I could see the rod looking down at it sitting on the seats?
Old 10-09-2015, 02:24 PM   #642
yaguphire
Oh so u mean turning the rod deeper?
Old 10-09-2015, 02:26 PM   #643
Effectively lengthen the rod.
Old 10-09-2015, 02:30 PM   #644
Sorry, I was backwards. You were correct in the first place. You want to raise it. Uggh. <facepalm>
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 02:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 01:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
