Hi Guys,
So I was installing the winjet DRL always on mod kit and cut the wires correctly and it worked perfectly on one side, on the other my friend pulled too much slack out of the connector and the red wire for the leds got disconnected somewhere within the light and the red wire terminates at the end of some sort of two pin connector. The other male side of that small connector is (what I' guessing) not accessible from the rear of the light. So I need to either bake the headlights or find someone who is selling a single passenger side winjet or both and replace them. Need to know the best course of action Here Thanks !
#2 |
Really 73 ppl and no responses?
#3 |
Drives: 2015 FR-S (Halo)
I assume the other 73, like I, have no good advice.
I'm sure the cheapest option would be to bake and be ready to solder the connection back together, because in my experience with electronics, LEDs are usually not designed to be pulled like bulbs and will have all of their connections soldered. I'd probably try and find a thread where someone baked their winjets if for no other reason than to see the inside of the unit and where things might have been damaged. Sent from my SAMSUNG-SM-G925A using Tapatalk
| The Following User Says Thank You to fatalelement For This Useful Post: | FRSBRZGT86FAN (10-05-2015) |
#4 | |
Thank you. If someone else stumbles across the post the answer is to heat them @200 degrees fahrenheit for 10 minutes and they essentially can be pulled apart quite easily. To reseal them remove the old sealant and use this to replace that sealant: [ame="http://www.amazon.com/gp/product/B0039752R2/"]Amazon.com: 3M 08620 Window-Weld 1/4" x 15' Round Ribbon Sealer Roll: Automotive[/ame] Then reheat the headlight and use clamps and small clip clamps to apply pressure to the lenses.
#5 |
Drives: 2014 Scion FR-S
Not really related to the topic but winjet related and didn't want to start a new thread
I recently bought Winjet headlights and the guy I bought them from had a H7 55w HID kit installed so I used them. But I found that the bulbs were very dim (6000k) , I've had 6000k previously and they weren't this dim Would I be better off changing the whole kit to a 35W hid kit or just change the bulbs? I tried to use my previous H11 35W ballast to fire up the H7 bulbs, they worked but the LED strip didn't light all the way up to max brightness. any suggestions? Thanks |
#6 | |
Personally I use a 35 Watt H7 hid kit, 55 Watt risks melting or burning things and electrical issues within the headlight (i,e over draw). Honestly swap over two a 5000K 35 Watt H7 HID kit, the kelvin color will match the LEDs that way and it's less of a pain to aim the cutoff to not bother other drivers. As for LED not reaching max brightness, could you show pics? Including pics of the wiring inside the headlight?
#7 |
Thanks for the help, I have fixed the problem. I replaced the whole hid kit and it solved the issue
I think it was just simply a crappy hid kit that was given to me to begin with |
#8 | |
Drives: 86
#9 |
A Demon
Drives: Raven GT86
Why not reach out to a shop who does retrofits get your headlights fixed and upgraded at the same time!
#10 | |
Lol nearest retro fitter is in new york I believe
#11 | |
for the drivers side I simply reconnected the wires cut for the mod and butt connected them back together. My originals came from eBay used anyway and have scratches near the hood area. Thanks for the offer though.
#12 |
Was this the under $50 ones from amazon or eBay? I have the OLM kit which is really good quality for $110, but if it ever fails in the future I am so going for the Diode Dynamics or Morimoto elite kit I've heard literally zero problems with them and they have an awesome pedigree. With HIDs you get what you pay for and the cheap ones honestly are hit or miss.
| Winjet LED strip problem | wopsang | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 12-02-2017 11:56 AM |
| Winjet eBay DRL mod problem | Fang | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 11-22-2015 10:44 PM |
| Winjet foglight switch problem/discussion | Chimera | Electronics | Audio | NAV | Infotainment | 11 | 09-09-2015 07:18 PM |
| Winjet Tail Light Problem | dad&sonFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 01-16-2015 04:59 AM |
| Custom Purple Winjet and Black Winjet Headlights | xclusive_brett | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 12-17-2013 09:28 AM |
