Old 09-29-2015, 09:28 AM   #57
gl2filmerguy
gl2filmerguy's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by FRSBRZGT86FAN View Post
@Uplink @gl2filmerguy & @PoorMansRacing :
How's the kit been for you guys long term now? Is it still worth the buy?
I love it! The only problem I have had was one of the push pins breaking, but thats all. I think it makes the back look very clean!
gl2filmerguy is offline   Reply With Quote
Old 09-29-2015, 04:47 PM   #58
mid_life_crisis
Drives: FR-S 10 #103 AT
I put stereo electronics underneath. So far, no problems with overheating, and they don't take up trunk space.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
civicdrivr (09-30-2015)
Old 10-05-2015, 12:07 PM   #59
Uplink
Uplink's Avatar
Drives: anything you let me
Even if it doesn't cut weight, I'll add it to the mod list for next summer, it really does look OEM, it would be cool if it had some sort of cross or x brace too for chassis stiffening or something.
It does cut weight. Mine dropped 19.375lbs. A cross brace would add weight so they leave that up to you to buy separately.
Uplink is offline   Reply With Quote
Old 10-05-2015, 12:09 PM   #60
Uplink
Uplink's Avatar
Yep. More apt to happen in the cold. I would have paid a few more dollars for the kit to include black annodized Aluminum fasteners instead. Wouldn't have added more than a few ounces and would have made the kit perfect.
Old 11-02-2015, 01:13 PM   #61
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Sorry for the delayed reply. I really like it. Couldn't stand having backseats, and it looks really clean.
2003 Honda S2000, SCCA Club Racing T3
2013 Subaru BRZ Limited, SCCA Solo II STX
2008 Honda S2000 CR, SCCA Solo II STR
PoorMansRacing is offline   Reply With Quote
Old 02-13-2016, 11:06 AM   #62
Seth Hawkins
Seth Hawkins's Avatar
Drives: 2015 BRZ Limited
Could you leave the OEM seat bottom cushions in place, and still use the rest of the kit? The OEM bottom cushions don't weigh much (maybe about the same as the replacement pieces?), and would allow you to put something behind the seats that weighs more than the plastic replacement parts could support. Plus, you could kneel on the OEM cushions when getting back there to clean the rear window. It sounds like the plastic replacement pieces won't support the weight of a person kneeling on them. It also sounds like most of the weight savings comes from the removal of the seat back, and the rest of the hardware - seat belts, brackets, etc..
Just wonderin'...
Seth Hawkins is offline   Reply With Quote
The Following User Says Thank You to Seth Hawkins For This Useful Post:
jcw99 (02-13-2016)
Old 02-13-2016, 03:14 PM   #63
Uplink
Uplink's Avatar
Just wonderin'...
I don't think you can. IIRC, you remove the metal brackets that would hold the seat plus there's a cross piece (that the bottom flaps fasten to) that gets bolted in the seat bracket locations. If you don't use that piece, the panel that separates the trunk/cabin wouldn't have anything to rest on.
With enough tinkering you might be able to rig something up but probably not worth it for the price of the kit to only use 1 piece.
The Following 2 Users Say Thank You to Uplink For This Useful Post:
jcw99 (02-13-2016), Seth Hawkins (02-14-2016)
Old 03-19-2016, 07:23 PM   #64
Panda1
Thanks so much. I just started ripping the interior out and replacing things and this how to could not have been more helpful. I have about zero wrench turning experience and had no problem knocking this project out. If I hadn't taken so many pictures it would have taken me the 2 hours or so you said. Thanks again!!!
Panda1 is offline   Reply With Quote
The Following User Says Thank You to Panda1 For This Useful Post:
Uplink (03-20-2016)
Old 07-14-2016, 07:41 PM   #65
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Pathetic I know, but I'm having trouble with the first step. Can't undo those 10mm bolts. I turn it hard and the socket just slips out of place. I feel like I need those tools where you hammer one side and that force makes the socket turn lol can't remember what they're called. Any suggestions what to do?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Jajanken86 is offline   Reply With Quote
Old 07-14-2016, 08:55 PM   #66
nunonuna
nunonuna's Avatar
Please update OP regarding seat belt assembly that the belt has to be held by clip or something prior to removing the assembly otherwise, seat belt will roll up extra few inches then you will end up with locked retractor.
Also, I have an idea about supporting the bottom panels by using "Instapak quick". It will not support super heavy weight, but it seems good enough to support wheels and tires.
nunonuna is offline   Reply With Quote
Old 07-15-2016, 12:05 AM   #67
jcw99
Drives: swp mt '14 brz premium
Are the bolts hex heads or external Torx?
jcw99 is offline   Reply With Quote
Old 07-15-2016, 12:34 AM   #68
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
Hex
Old 07-15-2016, 01:03 AM   #69
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Hex
You need a better quality impact type socket head, and a breaker bar.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Jajanken86 (07-15-2016)
Old 07-15-2016, 04:14 PM   #70
Jajanken86
Jajanken86's Avatar
Drives: Silver FR-S
the upper corners are a bit stripped on the other bolt, what should I do about that?
diy, rear seat delete, weight, weight loss
Rear Seat Delete kit ender2664 Cosmetic Modification (Interior/Exterior/Lighting) 53 10-04-2017 03:10 PM
REAR SEAT DELETE SUB BOX NYCsubaruBRZ NY / NJ / CT / PA 19 01-28-2014 03:38 AM
Company in NC wants to make a rear seat delete Lonewolf Southeast 33 12-23-2013 06:44 PM
Rear seat removal? Shizuma BRZ First-Gen (2012+) — General Topics 34 04-01-2013 04:36 AM
