Old 06-01-2012, 01:45 AM   #1
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Sway Bar Upgrades
Does anyone know the part number for the stock rear sway bar for a 2010 Forester XT? It's 17mm and apparently is a direct swap. Not a crazy upgrade but cheap! I want to give it a shot before I go crazy for aftermarket bars (which I know I will)
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 06-01-2012, 10:38 AM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The rear bar in the BRZ/FR-S is 14mm. Going to 17mm is a big bump in roll stiffness. The Cusco aftermarket bar is only 16mm. You'll end up pretty tail happy.
Old 06-01-2012, 10:52 AM   #3
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
that stuff can be tuned out. for low speed autocross, I'd want a looser rear and then tune it out with toe settings...
but someone needs to try to see if it works.
Matt Andrews is offline   Reply With Quote
Old 06-01-2012, 10:59 AM   #4
Racecomp Engineering
We're planning on testing 16, 17, 18, and 19mm rears. And then again when we have a front to test as well. Also need to do some math when I have more time.
- drew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Fly Guy (06-01-2012), Jedi1 (06-16-2012), Scooby South (06-01-2012)
Old 06-01-2012, 01:28 PM   #5
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Is there any stock bar that will fit that is 16mm?
Old 06-01-2012, 01:48 PM   #6
Yes, the current WRX rear I think is 16mm.
- andrew
blu_ (06-04-2012), NYC BRZ (06-01-2012)
Old 06-01-2012, 03:25 PM   #7
Dimman
Kuruma Otaku
Dimman's Avatar
Am I doing this right? If lever arm length, attachment point, bar total length and hollow/solid remain the same, and only the diameter increases, will the stiffness increase be (NewDiameter^4)/(OldDiameter^4), so ~ 70% more roll stiffness for a 16mm bar?
Because titanium.
Old 06-01-2012, 03:36 PM   #8
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Am I doing this right?... so ~ 70% more roll stiffness for a 16mm bar?
For a solid bar, yes. For hollow it would be (od2^4-id2^4)/(od1^4-id1^4). But it's not 70% more roll stiffness, just 70% more bar stiffness.
Actually it will probably end up being a tiny bit more than that, due to reduced deflection in the lever arms.
old greg is offline   Reply With Quote
Old 06-01-2012, 07:43 PM   #9
Dimman
Kuruma Otaku
Dimman's Avatar
Ok. Then would roll stiffness gain be (springs + new bar) / (springs + old bar) ?
This weekend I'm going to try to see if I can understand David Gould's roll/weight transfer stuff.
Because titanium.
Old 06-01-2012, 09:22 PM   #10
old greg
Rocket Surgeon
Drives: PSM GGA OMG
More or less. Don't forget the motion ratios.
Old 06-01-2012, 09:32 PM   #11
Dimman
Kuruma Otaku
Dimman's Avatar
I'm going to try and figure out the front first. 1:1 for both... I was using .8 in the back before, but RCE says ~ .75. So my eyeball wasn't too far off. Will have to see about the rear bar's motion ratio next.
Because titanium.
Old 06-04-2012, 12:38 PM   #12
Archer1.8
Drives: 2005 Subaru Legacy GT Stage 1
Those looking for A VERY CHEAP 16mm rear swaybar upgrade. Check out the 10+ Legacy GT rear sway bars. They are the same as the STi which shares the BRZ platform. Guy on my forum selling them for $25
http://legacygt.com/forums/showthrea...la-179658.html
Archer1.8 is offline   Reply With Quote
Old 06-04-2012, 12:46 PM   #13
Asterisked Accolade
Pedals over Paddles.
Asterisked Accolade's Avatar
Drives: Celica GT-S | 89 Supra | 07' Accent
Does anyone think that maybe the stock rear sway bar should be left as is, and only the front should be stiffened up? I ask because i would think a stiffer rear sway bar would increase an already present oversteer.
Asterisked Accolade is offline   Reply With Quote
Old 06-04-2012, 12:53 PM   #14
Archer1.8
You would think so, but its drivers preference. I have always driven nothing but subarus. EVERY subaru understeers like a pig. So the rule of thumb was always bigger rear bar, but thats my preference. I think a bigger bar upfront as well as a 17mm adjustable rear bar to dial in preferance would be good.
Cosworth Internal Upgrades Confirmed DanPO Engine, Exhaust, Transmission 60 05-26-2015 05:45 PM
adjustable sway bars!!! carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-04-2012 08:42 AM
STI rear sway bar carbonBLUE Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-25-2012 12:58 PM
