Old 09-26-2015, 04:50 AM   #1
Diz86x
Drives: GT86 Nur spec
Helppppp bolt pattern adapter
Hey there i just got my new wheels and the bolt pattern is 5x114 i had to get conversion spacers adapters (25mm) just to make it fit and i dont really like how they stick out because im planning to lower my vehicle and now its impossible to do that.
Any idea how can i change the bolt pattern or where can i get slimmer spacers?
I couldnt find them on the internet
Diz86x is offline   Reply With Quote
Old 09-26-2015, 06:13 AM   #2
Dihudaxia
Drives: 86
Project Kics has 15mm PCD conversion spacers
Not sure if they are able to ship internationally though.
http://www.kyoei-ind.co.jp/sangyo/pr...S_HubUnit.html
Dihudaxia is offline   Reply With Quote
The Following User Says Thank You to Dihudaxia For This Useful Post:
Diz86x (09-26-2015)
Old 09-26-2015, 06:15 AM   #3
Diz86x
@Dihudaxia thanks bro i need less then that though
Old 09-26-2015, 10:37 AM   #4
Dihudaxia
Drives: 86
Oh, that mightbe tough, have not been able to find a smaller size than 15mm.
Diz86x (09-29-2015)
Old 09-28-2015, 03:14 PM   #5
Varelco
Drives: '15 GT86 & '22 GR86
You won't get adapters smaller than 15 mm. Your only option would be a hub conversion, which won't be particularly cheap.
Varelco is offline   Reply With Quote
The Following User Says Thank You to Varelco For This Useful Post:
Diz86x (09-29-2015)
Old 09-28-2015, 03:46 PM   #6
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
You bought the wrong wheels. Adapters aren't the greatest, though a lot of people seem to use them with decent success. You should consider new wheels or a hub conversion.
JazzleSAURUS is offline   Reply With Quote
The Following 2 Users Say Thank You to JazzleSAURUS For This Useful Post:
Diz86x (09-29-2015), fx35s (10-03-2015)
Old 09-28-2015, 04:37 PM   #7
8R6
8R6's Avatar
Drives: FRS
if even tiny ass 15mm adapters are too big for you, then you DEFINITELY got the wrong wheels. or you can just keep it, throw on the adapters and cut up your car and go wide body lol. because stance bro.
8R6 is offline   Reply With Quote
The Following User Says Thank You to 8R6 For This Useful Post:
Diz86x (09-29-2015)
Old 09-28-2015, 04:54 PM   #8
Diz86x
8R6 that idea has been in my head for a while but its a dailyuse and pigs are all around in my country
Old 09-28-2015, 05:07 PM   #9
adamg
Drives: brz
sounds like you dont know what your doing. 25mm adapter is a standard size that will clear the stock studs. Even if you did 15mm now you have to make sure the back of your wheels have holes (aka pockets) were the extra length of stud will go into. if the back of the wheels are flat, nothing less than a 25mm adapter will work. also when you lower the car you get natural camber in the rear and most coilover comes with top hats for the front which then you can add a little negative camber to help the wheels clear, you can also get a smaller width of tire, and/or roll and slight pull the fenders to make them fit.
adamg is offline   Reply With Quote
The Following 2 Users Say Thank You to adamg For This Useful Post:
Cole (09-28-2015), fx35s (10-03-2015)
Old 09-28-2015, 05:08 PM   #10
Diz86x
Can you show me a picture of a back of a wheel that has holes if you dont mind
Old 09-28-2015, 05:13 PM   #11
Vten
Drives: Too heavy
11mm is the thinnest you can get.
http://www.tf-works.com/kics-project...rsion-bolt-on/
Vten is offline   Reply With Quote
The Following User Says Thank You to Vten For This Useful Post:
Diz86x (09-29-2015)
Old 10-03-2015, 06:36 AM   #12
Varelco
OP give you gives us some more details, what wheels are they? Whats the width and offset? Have you considered having them re-drilled? (this is obviously dependant in wheel design).
Old 10-03-2015, 09:48 AM   #13
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Too much headache dude.
Sell your wheels, buy the same ones in the right bolt pattern. Problem solved.
Old 10-03-2015, 10:34 AM   #14
fx35s
Drives: 2013 Subaru BRZ
Did you not think of our car's bolt pattern when you first bought wheels? lol
GL
fx35s is offline   Reply With Quote
bolt pattern probs markm7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 08-19-2014 06:39 PM
Bolt Pattern Adapters Flat Black VW Tracking / Autocross / HPDE / Drifting 7 04-13-2013 02:06 PM
Bolt Pattern Woes TSLRich Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 07-30-2012 12:30 AM
bolt pattern is 5x100? derka-derka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-30-2012 03:58 AM
The wheel bolt pattern is... quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 193 02-29-2012 07:04 PM
