Old 09-25-2015, 11:48 PM   #1737
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by e1_griego View Post
that's basically my list so far.
I still need the header, tune and front bar, but otherwise, yeah....
Do most of you STX folk run like 1/16"-1/8" rear toe in? I assume yes since that's standard issue RWD setup. I run at least -1/8" in my SM 240, but curious what the preferred street tire setup is.
I guess I'll start with -1/16" and see how it goes.
Zero toe all around. Also stock swaybars, but I think the spring rates I'm running are also not as common, so learning this before throwing more parts at it...
I haven't found the car tracks badly on road trips, but I think that's often why toe is added. Maybe it just doesn't bother me. I don't drive most weeks though.
The Following User Says Thank You to cjd For This Useful Post:
strat61caster (09-26-2015)
Old 09-26-2015, 05:48 PM   #1738
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
So for wheels, the +45mm offset 17x9 should be fine right? I think I heard that you need a 5mm spacer in the rear with the +45mm's...Or go with the +35mm offset wheels and be good?
Also, brakes. I've heard you can swap rotors with a WRX rotor that is a pound or two lighter on each corner. Anyone have info on that or lightweight brake kits?
justinco is offline   Reply With Quote
Old 09-26-2015, 06:23 PM   #1739
48Spoons
Drives: Ultramarine FR-S
I believe the AP racing kit is legal for STX and is around 10lbs lighter a corner than stock. Not exactly cheap though.
48Spoons is offline   Reply With Quote
The Following User Says Thank You to 48Spoons For This Useful Post:
justinco (09-27-2015)
Old 09-26-2015, 07:23 PM   #1740
cjd
cjd's Avatar
Drives: 2017 BRZ
It's legal. It also limits wheel choices (as do many BBK's, but perhaps not all quite so much) so be aware if you go shopping.
The Following 2 Users Say Thank You to cjd For This Useful Post:
CSG David (09-29-2015), justinco (09-27-2015)
Old 09-26-2015, 08:42 PM   #1741
RedBRZ80
Drives: 2013 Red BRZ
I don't think the rotors can be lighter than stock. The weight saving is in the calipers.
RedBRZ80 is offline   Reply With Quote
Old 09-27-2015, 12:24 AM   #1742
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Ouch, not cheap indeed. ~40lbs is a lot of weight though....
How about the wheels? Specifically looking at the RPF1's of course, just want to get the right offset (+35mm or +45mm).
Old 09-27-2015, 03:15 AM   #1743
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I would recommend et35. Those will fit the AP kit of you ever get there too. I'm running 35.
The Following 2 Users Say Thank You to BlaineWasHere For This Useful Post:
Old 09-27-2015, 07:23 AM   #1744
cjd
cjd's Avatar
Drives: 2017 BRZ
Check the list on the Essex site.
Front only for the weight savings. I'm sure you can find something for the back that's lighter, but not much.... And not nearly the upgrade either.
Old 09-27-2015, 09:10 PM   #1745
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Thanks guys, the BBK would probably be one of the last things to do...Nice to know though.
Old 09-28-2015, 03:26 PM   #1746
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
If you don't have a front sway bar you are NOT dialed in for autoX. Front bar is a simple mod even a C-Street twin needs to be competitive. I would look into dampers as a top priority mod as well seeing what you have.
Strano front bar and stock rear is a good place to start for sure. Also I'm pretty sure E85 isn't legal for STX anymore.
@Calum
said post about sways
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Calum (09-28-2015)
Old 09-28-2015, 03:48 PM   #1747
Calum
That Guy
Drives: 2013 asphalt FRS MT
Hey, I just got linked into this thread.
With the addition of a larger front sway bar what are you changing about how the car behaves?
Old 09-28-2015, 04:29 PM   #1748
rx3
Less oversteer (but more understeer). (Too much oversteer is slowing you down. On the other hand oversteer is usually an advantage in slow and tight turns. But then again if it's too stiff in the rear, the differential may struggle out of u-turn, especially if you are on race tires (not the case in STX).)
rx3 is offline   Reply With Quote
The Following User Says Thank You to rx3 For This Useful Post:
Calum (09-28-2015)
Old 09-28-2015, 05:50 PM   #1749
Calum
That Guy
My experience is that the car understeers in a steady state corner, while squeezing throttle only enough to maintain speed. Ham fisted maneuvers will easily cause the car to transition into oversteer though. Do the quick transitions in an autox change that, or is it just not possible to be sufficiently smooth and fast for the stock setup?
The benefits of a larger front bar, that I can see, would be quicker turn in and possibly reducing wheel spin. Is the goal really just shifting the balance toward increased understeers? If that's the only goal, why not just do it with alignment and/or tires?
Old 09-28-2015, 06:34 PM   #1750
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
You really want to negative camber and a front sway bar. I don't think we will need anything in the rear.
Front sway and negative camber took out a most of the understeer for me, that you were describing Calum
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
The Following User Says Thank You to jbailey8748 For This Useful Post:
Calum (09-28-2015)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
