#645 |
Drives: 2013 Ultramarine FR-S
In to see more of this. I know where one is. My old Supra got sent to the yard by the new owner.
#646 |
Drives: Sterling BRZ Ltd
![]() As it sits this LSD has a breakaway torque of about 53lbs on my bench rig, with a heavier spring installed it should see closer to 100 lbs. In this test the stock Torsen LSD would score 0 lbs.
| The Following 3 Users Say Thank You to mrk1 For This Useful Post: |
#648 |
53 is more then I expected with the bad rep these things get. I would like to try it both with and with out the spring but I'm running out of driving season so I'm just going with the upgrade.
| The Following User Says Thank You to mrk1 For This Useful Post: | fika84 (09-23-2015) |
#649 |
Sounds good. I guess if it's too "hoppy" you can always try it with the 53 next season!
#650 | |
When I purchased the upgrade spring from Weir I described my car and usage and this is what we ended up with.
#651 |
Googling around I am seeing the stock LSD seem to be 45-60 lbs, gravel rally cars set 150-175, and drifters shimming them up around 250. So using that as a scale 45-250 I think 100 is a fair start.
Link to Weir page, I have the #1 kit http://www.weirperformance.com/maxgriplsdkits.html
#652 |
Drives: 2014 Pearl White BRZ
Really fun thread
| The Following User Says Thank You to Fastbrew For This Useful Post: | mrk1 (09-23-2015) |
#653 |
Popped the LSD apart on lunch
![]() Pretty straight forward.
#654 |
With the new spring and all shimmed up to spec I'm seeing just over 100 lbs of break away. That's also a fairly dry lsd. When it's all installed I will test again.
I'm also curious to test the break away with just the shimming as mine was pretty loose.
#655 |
Tested a few different combinations. These are averaged numbers.
Untouched with no shims, 53 lbs Shimmed to Weir spec, 90 lbs (Dry) Weir Spring with no shims, 100 lbs (Dry) Weir Spring and shimmed to Weir spec, 108 lbs (Dry) (Shimming is not really intended to raise the torque but to set the backlash on the spider gears. Weir gives a spec of .004-.005 while the shop manual says .002-.0079) Sticking with the Weir Spring and shimmed to Weir spec I then lubed everything and re-tested, 100 lbs on the nose. I'm very curious to try this thing out.
| The Following 4 Users Say Thank You to mrk1 For This Useful Post: |
#656 |
![]() Had to shave down the inner end of the axle a 1/4" or so to fit in the LSD. Weir gave me a heads up this may happen so its easy to work out while its still on the bench. Trimmed is on the Left, untouched stock on the Right. Only the splines to the outside of the C clip are driven so trimming where I did shouldn't effect the axle at all.
| The Following 2 Users Say Thank You to mrk1 For This Useful Post: | civicdrivr (09-29-2015), frsvr4 (09-30-2015) |
#657 |
First short ride with the LSD, holy braking stability! Previously the rear was a little twitchy on heavy braking but now it's planted as can be. Feels like there are some 315 meats back there.
#658 |
stable, stable, stable. Decel and braking into a corner are completely transformed. There is a pleasant weighted feel to rear end now. Before I felt like the back end was tip toeing into a corner but now its composed. There is the slightest essence of push from the back end as turn in isn't as crisp from the front but its certainly not causing understeer (only noticeable when engine braking). I do think if I still had stock tires the diff would be too aggressive but with my 255 sticky street tires I feel the grip of the tires keep the diff in check.
Corner exit is largely the same accept I feel confident to get on the power sooner with the back end staying composed.
| The Following 2 Users Say Thank You to mrk1 For This Useful Post: | civicdrivr (09-29-2015), Kotu100 (09-29-2015) |
| AMR Performance: How to remove the factory bumper (walk-through images inside) | AMR | Engine, Exhaust, Transmission | 9 | 04-10-2013 08:45 PM |
| 86 Modelista walk around and GT Limited | SoCal_86 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-24-2012 12:53 PM |
