#687 |
Only happy when it rains.
Drives: series.blue
Or super conservative just to make sure someone doesn't do something dumb and then blame the cosworth supercharger.
| The Following 5 Users Say Thank You to why? For This Useful Post: | CSG Mike (09-21-2015), Freeman (09-21-2015), Phantobe (09-21-2015), wparsons (09-24-2015), Xuningshen (09-22-2015) |
#688 | ||
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
![]() My tuner (Sharif @ Forged Performance) spoke with Cosworth UK at length about the kit. They told him the same thing...tested for many many hours, kit was detuned to maximum safe power for the stock internals. 250whp. When they refer to the HP limit, they are referring to their kit, which coincides with a fairly specific TQ spec tied to that HP spec. Since most people measure power output by HP, they just defaulted to that value for simplicity. I run the Cosworth kit on my FRS with stock internals, and I can also attest to the fact that this kit will not heat soak. What I do where I drive is like doing constant dyno pulls for 10 minutes solid....accel from low RPM to redline, brake, repeat...at fairly low speeds. Cooling efficiency on this unit is impressive.
| The Following 2 Users Say Thank You to killboy For This Useful Post: | johan (10-23-2015), stockysnail (09-22-2015) |
#689 |
Was that a PD supercharger setup or turbo?
#690 | |
Drives: GT86 Cosworth
Yes for low cylce fatigue you get plastic deforation very quickly and failure but high cycle fatigue is harder to predict without some materials science, which requires analysis of the rod material and putting it into some very fancy software to analyse. Sounds easy but takes alot of effort. Even then the point to faliure will vary as it depends how people drive the car. I look forward to hear what Edlebrock have to say when you tell them "350WHP blew a rod out the side of my block but it worked for the first 20k miles". I'm not a gambling man but I bet it will be along the lines of: "we only guarentee 242WHP so sod off" Some further reading: https://en.wikipedia.org/wiki/Fatigu...-cycle_fatigue |
| The Following User Says Thank You to ajc209 For This Useful Post: | SkiRideDrive (09-22-2015) |
#691 | |
Everyone going for more power should know that more power means exponentially higher chances of failure. I briefly did a lot of metallurgical analysis and failure mode analysis when I interned at Boeing back in college...
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | sato (09-22-2015), Sportsguy83 (09-22-2015) |
#692 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
I love how I'm reading more about the cosworth SC in the Edelbrock thread than the cosworth owners thread.
#694 |
Drives: 13 GBS BRZ
| The Following 4 Users Say Thank You to Porcupint For This Useful Post: |
#696 |
Sorry if it seems like I am trying to shit on the Edlebrock chaps. I Reference the work Cosworth have done becuase I what I have been told and the shear amount of R&D they have done.
The Edlebrock cirtainly looks like a nice bit of kit and with the warranty and lower price point, I can certainly see how it would be nice option for you guys state side. Here in the uk the price difference is not so big and we don't get the warranty. |
#697 | |
I myself have considered the cosworth, but being in the US, and even worse, California, my choices are very limited if I want to stay CARB legal. I don't doubt that such a large engineering firm like Cosworth has "done their homework" to provide a kit that delivers, and the price tag definitely reflects that. Granted, even though Edelbrock did not do any engine dyno testing or any fancy simulations, they are no small operation (all development and testing was done on their handful of test cars on real world environments), after speaking to their SC engineers, seeing their facility and knowing their history on the USDM aftermarket, I'm still looking forward to what they have in store. If you are still here @Edelbrock LLC sill waiting on your updates regarding the fuel economy fix and any track testing
| The Following 2 Users Say Thank You to BigFatFlip For This Useful Post: | ravisraval (09-22-2015), why? (09-22-2015) |
#698 |
Drives: toyota mr2/ Toyota GT86
so what we're basically saying here is Cosworth should release some smaller / faster pulleys for thier kit?
Just for the tune it yourself market so no gaurentees and don't come crying to us when your stock block puts a leg out of bed here's a load more boost and good luck.... |
#699 | |
Drives: Supercharged Car
| The Following User Says Thank You to itsibarra For This Useful Post: | CSG Mike (09-22-2015) |
#700 |
Drives: series.blue
I just don't think that is Cosworth's thing though. They seem to want to be an all in one solution, not a parts vendor. I assume they will release this next rumored stage at some point including everything you could possibly need to make sure it will run perfectly as long as you want it to.
| Tags |
| boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger |
| Trunk needs a bit of force to close..... | Hachiroku14 | Issues | Warranty | Recalls / TSB | 30 | 06-19-2018 06:09 PM |
| X-Force 3" Exhaust | mwjcyber | Engine, Exhaust, Transmission | 19 | 03-13-2017 02:55 PM |
| The force is strong with this one (2015 STi) | blackhawkdown | FR-S / BRZ vs.... | 39 | 08-01-2014 01:26 AM |
| X force or Invidia N1 | JakeG | AUSTRALIA | 8 | 01-18-2014 05:16 AM |
| G-force meter | mikepaul21 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 03-17-2013 02:24 PM |
