Old 09-02-2015, 10:01 PM   #575
nelsmar
Originally Posted by Luckrider View Post
I mean, if you feel like tossing money around at a block for testing, I have a car with a clunky running motor
Lol I actually have two engines already... One that is built and another that someone made go clunky clunky that's getting stroked and sleeved. So I don't need a donor atm. And with how I treat my car I should really keep a spare... Haha!
My flickr - Canibeat
Local magazine scout
Old 09-03-2015, 09:01 AM   #576
celek
Resident Gear Head
celek's Avatar
Originally Posted by nelsmar View Post
I'm where you are... You know how quickly this shit adds up to an excessively expensive build. I planned on tossing this in my other block and hopefully someone gets some testing done before then but somehow I feel like I'll end up just having to buy one lol.
Yeah I am just under $8500 in the short block when its done... Should have LS swapped
celek is offline   Reply With Quote
Old 09-03-2015, 09:25 AM   #577
Tim Radley
Drives: None
See the same here. They aren't the cleanest.
Originally Posted by sam69 View Post
A guy I know builds lots of Subaru ej engines and he is in the process of doing a fa motor atm and he has told me that the amount of silicone inside the motor is just unbelievable.
Tim Radley is offline   Reply With Quote
Old 09-03-2015, 09:38 AM   #578
Tim Radley
Drives: None
On the subject of bearings and pressure.
Here is a stock motor i pulled apart with less than 500 miles on it.
Also here is an oil pressure log from the road and i have my limiter set at 8000rpm. Stock oil pump, blueprinted engine with flowed oil paths.
The Following 2 Users Say Thank You to Tim Radley For This Useful Post:
Alpha86 (08-22-2019), BatStig (09-19-2015)
Old 09-03-2015, 10:06 AM   #579
celek
Resident Gear Head
celek's Avatar
Block resealed by Subaru tech after rebuild..... Customer complained of noise then engine stopped running. Suspected Silicone in Oil Passages
Silicone all over
Old 09-03-2015, 10:14 AM   #580
OkieSnuffBox
Drives: '23 BRZ Limited
Jesus this thread makes me want to sell everything, go back to stock, sell the car and just buy something else for a DD/HPDE car.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
RavioliG (09-01-2017)
Old 09-03-2015, 11:50 AM   #581
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Silicone all over
So what you're saying is don' t let Subaru Techs near the engine, suck it up and rebuilt yourself? (or a quality shop)
The Following 2 Users Say Thank You to DustinS For This Useful Post:
celek (09-03-2015), civicdrivr (09-03-2015)
Old 09-03-2015, 12:29 PM   #582
jvincent
jvincent's Avatar
The amount of bits on the oil pickup strainer was huge and he found the oil galleries to the VCT has strainers built into the block and these were almost totally blocked with bits of silicone .
Also a lot of bolts / screws weren't very tight at all and even some of the fixings retaining the oil pump weren't tight and he said you could see where the pump was starting to float/rub on the housing.
This thread is one of those ones that you wish you had never opened. Ignorance was bliss.
I'm assuming that accessing the strainers would require a tear down.
Would there be any way to "flush" oil through the engine to get some of the gunk out?
Old 09-03-2015, 12:33 PM   #583
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
These posts make me fear that this is what we will find when we get into the block. If that's the case, I don't know if I'll be able to push Subaru to fix it.
Luckrider is offline   Reply With Quote
Old 09-18-2015, 10:53 AM   #584
ajc209
Drives: GT86 Cosworth
So I had the Moroso Oil Pan fitted today by my local shop.
Now it appears under long hard acceleration, say doing 20-90mph through the gears, I am getting a sudden and oscillating pressure drop from 80PSI down to 40PSI. As soon as I let off the pedal, oil pressure stabilises.
I've checked my oil level and its on the low side but higher than lower hole in the drip stick. I reckon this is oil starvation! WTF
I will check/top up oil levels and retest.
ajc209 is offline   Reply With Quote
Old 09-18-2015, 02:19 PM   #585
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I don't have a oil pressure monitor installed but after having my engine serviced for a leak at about 16-17K my average oil temps had gone up 5-10 degrees. Hopefully this thing last me another year without major repair then time to trade in for another car, me thinks.
Intent > Content
Old 09-18-2015, 07:40 PM   #586
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Well, if you read the threads for other "choice" track car candidates, you're going to see similar horror stories. It's really hard to tell what is common and what is a rare failure since the people with no problems don't post. In my case, I've had the car for almost 2 years, 20K miles, 35 hard track days and it runs like a charm and uses not oil.
JRSC is going on next week
Sleepless is offline   Reply With Quote
The Following 2 Users Say Thank You to Sleepless For This Useful Post:
OkieSnuffBox (09-21-2015), strat61caster (09-18-2015)
Old 09-18-2015, 08:38 PM   #587
celek
Resident Gear Head
celek's Avatar
That almost looks like sand casting thats left over in the block
Old 09-19-2015, 02:57 AM   #588
Kodename47
Kodename47's Avatar
Drives: UK GT86
Who did it? It's usual practice to fill with slightly more oil with a baffled plate as oil return to the sump can also be restricted.
.: Stealth 86 :.
Kodename 47 DJ:
FA20 Engine component photos Crawford FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 89 02-22-2016 02:31 AM
FA20 Engine component photos Crawford Engine, Exhaust, Transmission 46 01-26-2015 05:19 AM
Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. FRSport.com Engine, Exhaust, Bolt-Ons 0 01-10-2014 12:33 PM
FA20 Le Mans Race Engine SilverSkyline210 Engine, Exhaust, Transmission 11 11-17-2013 11:24 PM
