Old 09-17-2015, 05:22 PM   #645
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by mrk1 View Post
Also in the works, more differential meddling. I picked up a MK3 Supra LSD. These got a bad rep after being set pretty loose from the factory, however Weir Performance has the upgrade to cure this.
In to see more of this. I know where one is. My old Supra got sent to the yard by the new owner.
Old 09-23-2015, 01:08 PM   #646
mrk1
Drives: Sterling BRZ Ltd
As it sits this LSD has a breakaway torque of about 53lbs on my bench rig, with a heavier spring installed it should see closer to 100 lbs. In this test the stock Torsen LSD would score 0 lbs.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 3 Users Say Thank You to mrk1 For This Useful Post:
civicdrivr (09-23-2015), fika84 (09-23-2015), Kotu100 (09-23-2015)
Old 09-23-2015, 01:41 PM   #647
fika84
fika84's Avatar
The break away torque might not be that bad with the factory Supra setting with the lighter weight car!
fika84 is offline   Reply With Quote
Old 09-23-2015, 01:49 PM   #648
mrk1
53 is more then I expected with the bad rep these things get. I would like to try it both with and with out the spring but I'm running out of driving season so I'm just going with the upgrade.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
fika84 (09-23-2015)
Old 09-23-2015, 02:02 PM   #649
fika84
fika84's Avatar
Sounds good. I guess if it's too "hoppy" you can always try it with the 53 next season!
Old 09-23-2015, 02:38 PM   #650
mrk1
Its hard to say what the down side of top stiff would be as these aren't really categorized as 1.5 or 2 way. Mechanically it sure looks like a 2 way but being simple in design and a OE part I have a hard time believing it will be as aggressive as a aftermarket 2 way even with the spring.
When I purchased the upgrade spring from Weir I described my car and usage and this is what we ended up with.
The Build Thread
DustinS (09-23-2015), fika84 (09-23-2015), Kotu100 (09-23-2015)
Old 09-23-2015, 03:24 PM   #651
mrk1
Googling around I am seeing the stock LSD seem to be 45-60 lbs, gravel rally cars set 150-175, and drifters shimming them up around 250. So using that as a scale 45-250 I think 100 is a fair start.
Link to Weir page, I have the #1 kit
http://www.weirperformance.com/maxgriplsdkits.html
The Build Thread
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
Carlos_M (09-26-2015), Kotu100 (09-23-2015)
Old 09-23-2015, 04:46 PM   #652
Fastbrew
Drives: 2014 Pearl White BRZ
Really fun thread
Fastbrew is offline   Reply With Quote
The Following User Says Thank You to Fastbrew For This Useful Post:
mrk1 (09-23-2015)
Old 09-23-2015, 05:48 PM   #653
mrk1
Popped the LSD apart on lunch
Pretty straight forward.
The Build Thread
Old 09-23-2015, 08:26 PM   #654
mrk1
With the new spring and all shimmed up to spec I'm seeing just over 100 lbs of break away. That's also a fairly dry lsd. When it's all installed I will test again.
I'm also curious to test the break away with just the shimming as mine was pretty loose.
The Build Thread
Old 09-24-2015, 02:11 PM   #655
mrk1
Tested a few different combinations. These are averaged numbers.
Untouched with no shims, 53 lbs
Shimmed to Weir spec, 90 lbs (Dry)
Weir Spring with no shims, 100 lbs (Dry)
Weir Spring and shimmed to Weir spec, 108 lbs (Dry)
(Shimming is not really intended to raise the torque but to set the backlash on the spider gears. Weir gives a spec of .004-.005 while the shop manual says .002-.0079)
Sticking with the Weir Spring and shimmed to Weir spec I then lubed everything and re-tested, 100 lbs on the nose. I'm very curious to try this thing out.
The Build Thread
The Following 4 Users Say Thank You to mrk1 For This Useful Post:
civicdrivr (09-25-2015), fika84 (09-24-2015), frsvr4 (09-25-2015), Porcupint (09-24-2015)
Old 09-25-2015, 10:06 PM   #656
mrk1
Had to shave down the inner end of the axle a 1/4" or so to fit in the LSD. Weir gave me a heads up this may happen so its easy to work out while its still on the bench. Trimmed is on the Left, untouched stock on the Right.
Only the splines to the outside of the C clip are driven so trimming where I did shouldn't effect the axle at all.
The Build Thread
civicdrivr (09-29-2015), frsvr4 (09-30-2015)
Old 09-28-2015, 08:37 PM   #657
mrk1
First short ride with the LSD, holy braking stability! Previously the rear was a little twitchy on heavy braking but now it's planted as can be. Feels like there are some 315 meats back there.
The Build Thread
civicdrivr (09-29-2015), DustinS (07-13-2016), Kotu100 (09-29-2015)
Old 09-29-2015, 11:08 AM   #658
mrk1
stable, stable, stable. Decel and braking into a corner are completely transformed. There is a pleasant weighted feel to rear end now. Before I felt like the back end was tip toeing into a corner but now its composed. There is the slightest essence of push from the back end as turn in isn't as crisp from the front but its certainly not causing understeer (only noticeable when engine braking). I do think if I still had stock tires the diff would be too aggressive but with my 255 sticky street tires I feel the grip of the tires keep the diff in check.
Corner exit is largely the same accept I feel confident to get on the power sooner with the back end staying composed.
The Build Thread
civicdrivr (09-29-2015), Kotu100 (09-29-2015)
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 08:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 12:53 PM
