#491 |
Drives: 2013 Hot Lava
#492 |
Drives: 13 FRS
If you have our kit just let us know when you order and we will include brackets.
#493 |
#494 | |
Drives: red frs
#495 |
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Read through all 23 pages and didn't see an answer to my question. So what will be the difference between EL and UEL with this kit? Will it only be noise? Any difference in spool time, or power band?
Any sound clips comparing the two? Thinking about pulling the trigger on the JDL kit despite our crappy Canadian Dollar right now
#496 | |
Drives: 2013 FRS
To keep things on the simpler side without the technical bits , here are some of the differences between the two. For unequal length , their is the subie rumble that is known with subarus and there is some better turbo response in the low end and some slight benefit to low end power. The unequal length is a more harmonious sound without the subie rumble but also has its benefits. The engine volumetric efficiency is improved while top end power is improved. There is way more technical stuff such as lower cylinder temperature variations with equal length and what effects it has on rings and all that but to make it simple , there ya have it. Sent from my iPhone using Tapatalk |
#497 |
As mentioned about just a very slightly different spool time. The UEL is still a rather long manifold so you won't get too quick of a spool as you would by having two runners right at the collector and right at the turbo. But you will get a slight sound difference. Due to the timing of the pulses ideally you would get a higher pressure pulse due to pulses from different runners colliding at the collector. This gives a slightly more responsible turbo but lowers the volumetric efficiency as when you have higher flow and become flow restricted the pulse collisions start adding even more restriction. Mind you this isn't a crazy efficiency change.
If I were to order a kit again I would probably do the UEL as I don't like the sound this engine makes. :p. Even though I do like how my car sounds it would probably just sound that much better!
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#498 |
Drives: 2013 FRS
I installed my JDL kit about a month ago and it is running strong. JDL rocks!
![]() Sorry no pics yet, but I will get to it at some point. |
#499 |
Drives: Subaru BRZ Series.Blue
Bought my kit Friday of last week!
Huge thanks to Ronnie @JDLAutoDesign for the heads up on the sale. I got a killer deal that I know I won't regret. I bought most everything I'll need for my conversion to FI. I finally pulled the trigger, guys. My wallet is now screaming in pain, but luckily it's pinned under my ass. Take that, wallet!
#500 |
Drives: 13 FRS
Just wrapped up a local car with all our goodies. GTX2867 UEL Kit, Fan Shroud, Catch Can, and Oil Cooler. This thing is great at 9psi
#501 | |
Even after I buy all the stuff I need you taunt me with this? You're an enabler. You feed other's addictions. So how does the fan shroud look?
#502 | |
Drives: 13 FRS
#503 |
Drives: 13 FRS
#504 |
Looking forward to it.
A new radiator might also be in my future, so hopefully they'd work together.
| HKS Supercharger owners thread | wbradley | Forced Induction | 1054 | 10-26-2024 01:18 PM |
| P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
| To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 07:33 PM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
| P&L Turbo Owners Topic Thread | GTB/ZR-1 | Forced Induction | 4 | 09-01-2013 06:27 PM |
