Old 09-15-2015, 08:02 PM   #1
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
late 2013 MY oil burning smell
all,
I've been getting the occasional faint oil burning smell as I pull up to stop lights or into my garage ever since I went full bolt-ons and E85 (been about 1500 miles since then). I've inspected all the common oil leak points (like the cam seal plate) and I don't see any evidence of oil leakage. I also have noticed no change in oil level on the dipstick.
Is this blow-by being burned? Should I do a compression test?
I'm going FI in a couple months so I just want all my ducks in a row before then.
FYI My car was made in the last month of the 2013 production.
xsnapshot is offline   Reply With Quote
Old 09-15-2015, 08:13 PM   #2
swarb
List of parts. Cats?
Were new gaskets used everywhere?
Old 09-15-2015, 08:44 PM   #3
xsnapshot
Fast enough
Catless resonated front pipe, overpipe, and OFH. Perrin 2.5 resonated catback. OFT E85 tune customized by myself.
New gaskets everywhere. All bolts torqued down tight, no obvious leaks. The car runs very well and feels strong. So strong I stomped my buddies 2006 BMW z4 3.0i manual pretty bad.
I have the AT just FYI
Old 09-15-2015, 09:02 PM   #4
swarb
I wouldn't worry. If anything it is probably from running no cats and e85. Just keep an eye on your oil level, oil temps, fuel trims, kc, iam, afr and you should be good.
I would worry if you aren't experienced in tuning.
Old 09-16-2015, 10:21 AM   #5
xsnapshot
Fast enough
well I ran no cats and E85 on my WRX and never smelled burning oil. It just seems odd.
I have a good bit of experience tuning, so that's not a factor. It smelled that way before I tuned it and was just OTS stage 2 E85.
Old 09-16-2015, 10:36 AM   #6
raven1231
yeah I ran no cats and E85 on my frs and never smelled oil burning.
Old 09-16-2015, 11:16 AM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I smell burning oil when driving my FRS hard. No leaks even have dye in the oil can't find nothing. I also have a catch can (sh*t one but better then nothing) I am also catless but on 94 octane. Oil level never drops so I don't worry about it anymore.
Old 09-16-2015, 11:33 AM   #8
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Originally Posted by xsnapshot View Post
all,
You may consider investing in an oil catch can since you are going FI anyway. It will catch blow-by should there be any (excess). Also take a peak into the intake tract and throttle body to see if you have any oil residue. I know that some are going to tell you that a compression test isn't necessary, but why not take that extra step before going FI? At the very least for peace of mind. Good luck, and keep us posted.
LOLS2K is offline   Reply With Quote
Weird Burning Smell? t00n3wb Issues | Warranty | Recalls / TSB 27 05-21-2018 04:58 PM
Anyone smell burning outside the car? DarrenDriven Scion FR-S / Toyota 86 GT86 General Forum 115 01-13-2015 02:31 AM
burning smell when in reverse fito68 Southern California 8 12-30-2014 07:21 PM
Did I smell my clutch burning...? Ultra marine Scion FR-S / Toyota 86 GT86 General Forum 13 10-08-2013 09:27 PM
Burning smell Boofneenee Issues | Warranty | Recalls / TSB 6 09-30-2013 07:28 PM
