#15 | |
It's still a 1.5 way, it's just not locking as strongly as before, and doesn't require as much torque to get the wheels to operate at different speeds. Glad to hear it didn't break in the crash! I can't wait to get mine in with the 4.88.. still need to get the plates WPC treated and order bearings and seals. |
| The Following User Says Thank You to fika84 For This Useful Post: | GT86_PRAGUE (09-08-2015) |
#16 | |
Drives: GT86
#17 |
Drives: GT86
MFactory also have a 2.992 1st, 2.08 2nd and 0.861 6th gear available for the GT86
| The Following User Says Thank You to MFactory For This Useful Post: | Turdinator (09-11-2015) |
#18 | |
Drives: GT86
Edit: These seems pretty useless, both of them are VERY CLOSE to OEM setup. Not worth the money and effort. Last edited by GT86_PRAGUE; 10-08-2015 at 11:21 AM. |
#19 |
Drives: 2013 Asphalt FRS
Why don't you push the motor a little and get into the power band around 6500 to 7500 rpm? I have 35k miles on mine with 7500 rpm every time it goes down the street. Still running strong. The engines are tough and can handle it if you do proper services.
If I was doing it I would run a E85 Stg 2 tune Header and exhaust push it with 4.88 gears or 4.56 and zing the motor 7500 rpm. Going close ratio trans gearing would not help near as much as adding power and would cost you at least twice as much. Good luck, keep me posted on your results..
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#20 | |
Drives: GT86
I will get E85 tune soon eitherway. |
#21 |
Drives: '23 BRZ Limited
Devil's Advocate, too much shifting can hurt your progress as well because you reduce the time in the fat part of the powerband.
Granted we were testing on my old motorcycle, so it's not completey the same. But the difference between shortening the gearing ~13% and then bumping back doown to around ~7%...............only the small bump in gearing was actually faster down the 1/4 mile and at the racetrack. In the 1/4 mile it prevent another shift and at the track it put me better in the power for the corners (of course this is track specific). Not disagreeing with your plans, just throwing out the experience I had. |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | FRS Justin (09-11-2015) |
#22 | |
Drives: GT86
#23 |
if 3-4-5-6 stay the same, you'll be shifting through those MUCH quicker with that steep FD. Unless you're only concerned with 1-2.
To be honest, it seems like you need to do a lot more analysis before you make this move. EDIT: Re-read your first post, if you're 2nd gear is to short as it, why not go numerically lower on your FD? Going higher on the FD, then changing your 1-2 gear ratios in the trans to match seems........well......daft to say the least. |
#24 | |
#25 | |
Drives: GT86
I have 4.67 on a car and 4.88 waiting on install, 4.67 was not that short as I expected, so thats why I jump to 4% more. With that, I will probably shift more, so I could keep 4.67 and go with lightest wheels, cf driveshaft etc, but thats more expensive than doing geabox and still dont match my expectations. I am doing my analysis, thats why I asked if anyone has it and put some numbers above. |
#26 |
Drives: GT86
I see. I am guessing I am in this range except some straight where I shift to third just above 7000rpm. But believe me, I upshift as late as I can, I am limited by track layout and cant be in higher rpms due to tight layout. Thas why I will upgrade from 4.67 to 4.88, to have more power/torque. I cant get 5.1 cause I do highways too.
Edit: Now I have 7600rpm limiter and it dont fall hard like OEM, so I might be even faster. So better brakes next time. Never ending story. Last edited by GT86_PRAGUE; 10-08-2015 at 11:24 AM. |
| Rear end ratio and ECU changes? | mid_life_crisis | Software Tuning | 12 | 01-21-2015 03:14 PM |
| Anybody change rear gears or trans gears yet? | ramosryan | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-13-2014 01:48 AM |
| FR-S to BRZ Ratio | MannyO | New England | 11 | 03-08-2012 03:23 AM |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 03:40 AM |
