Old 09-08-2015, 12:55 PM   #15
fika84
fika84's Avatar
Originally Posted by GT86_PRAGUE View Post
I have Mfactory 1.5/2W (it was not affected by the crash, the guys was very suprised with that behaviour and as every other mech thought it is broken, but it was just very tight/heavy - not for 200hp), currently on much lighter setup with 3 lamels. I dont know more details now, but I will get them.
I am very happy with current setup, I only thing guys set it up more to 1.0 than 1.5, because there is zero kick/slide on downshift while braking. This is the only thing I will change with 4.88.
Nice! That's close to what I'm doing before installing it. Reducing the initial torque/pre-load and also reducing the locking capacity help tremendously with street setups!
It's still a 1.5 way, it's just not locking as strongly as before, and doesn't require as much torque to get the wheels to operate at different speeds.
Glad to hear it didn't break in the crash! I can't wait to get mine in with the 4.88.. still need to get the plates WPC treated and order bearings and seals.
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
GT86_PRAGUE (09-08-2015)
Old 09-08-2015, 01:44 PM   #16
GT86_PRAGUE
Drives: GT86
I have no option to do that WPC here. But I switch from Millers Nano Oil to Motul Blue (I have to - mech order). And it is quite silent. I did 2300km trip last week and it was quite comfortable at +-4000rpm whole way.
GT86_PRAGUE is offline   Reply With Quote
Old 09-10-2015, 09:46 PM   #17
MFactory
Drives: GT86
MFactory also have a 2.992 1st, 2.08 2nd and 0.861 6th gear available for the GT86
MFactory is offline   Reply With Quote
The Following User Says Thank You to MFactory For This Useful Post:
Turdinator (09-11-2015)
Old 09-11-2015, 03:30 AM   #18
GT86_PRAGUE
Drives: GT86
Thanks, I knew I saw them somewhere. I will ask EU distributor when time comes, but I probably get Cusco if price dif is not big.
Edit: These seems pretty useless, both of them are VERY CLOSE to OEM setup. Not worth the money and effort.
Old 09-11-2015, 05:11 AM   #19
FRS Justin
Drives: 2013 Asphalt FRS
Why don't you push the motor a little and get into the power band around 6500 to 7500 rpm? I have 35k miles on mine with 7500 rpm every time it goes down the street. Still running strong. The engines are tough and can handle it if you do proper services.
If I was doing it I would run a E85 Stg 2 tune Header and exhaust push it with 4.88 gears or 4.56 and zing the motor 7500 rpm.
Going close ratio trans gearing would not help near as much as adding power and would cost you at least twice as much.
Good luck, keep me posted on your results..
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 09-11-2015, 06:47 AM   #20
GT86_PRAGUE
Drives: GT86
I already have headers and 7450 rev limit, so extra 50 rpm wont solve anything. So this is not a choice between headers or close gears. I expect from close gear to get usable shifting range/length on 2nd, because with 4.88 FD it will be too short. E85, headers or anything else wont fix this.
I will get E85 tune soon eitherway.
Old 09-11-2015, 08:37 AM   #21
OkieSnuffBox
Drives: '23 BRZ Limited
Devil's Advocate, too much shifting can hurt your progress as well because you reduce the time in the fat part of the powerband.
Granted we were testing on my old motorcycle, so it's not completey the same. But the difference between shortening the gearing ~13% and then bumping back doown to around ~7%...............only the small bump in gearing was actually faster down the 1/4 mile and at the racetrack.
In the 1/4 mile it prevent another shift and at the track it put me better in the power for the corners (of course this is track specific).
Not disagreeing with your plans, just throwing out the experience I had.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
FRS Justin (09-11-2015)
Old 09-11-2015, 11:24 AM   #22
GT86_PRAGUE
Drives: GT86
Exactly. Thats why I am interested in these, because i would shift LESS with this gear set on (at least theoretically).
Old 09-11-2015, 11:57 AM   #23
OkieSnuffBox
if 3-4-5-6 stay the same, you'll be shifting through those MUCH quicker with that steep FD. Unless you're only concerned with 1-2.
To be honest, it seems like you need to do a lot more analysis before you make this move.
EDIT: Re-read your first post, if you're 2nd gear is to short as it, why not go numerically lower on your FD?
Going higher on the FD, then changing your 1-2 gear ratios in the trans to match seems........well......daft to say the least.
Old 09-11-2015, 01:33 PM   #24
FRS Justin
I thought you were in the 5k to 6k rpm range??
710whp
Old 09-11-2015, 06:08 PM   #25
GT86_PRAGUE
Drives: GT86
I am N/A and always be, I wont go lower with FD, car feels slow there.
I have 4.67 on a car and 4.88 waiting on install, 4.67 was not that short as I expected, so thats why I jump to 4% more. With that, I will probably shift more, so I could keep 4.67 and go with lightest wheels, cf driveshaft etc, but thats more expensive than doing geabox and still dont match my expectations.
I am doing my analysis, thats why I asked if anyone has it and put some numbers above.
Old 09-11-2015, 06:14 PM   #26
GT86_PRAGUE
Drives: GT86
I see. I am guessing I am in this range except some straight where I shift to third just above 7000rpm. But believe me, I upshift as late as I can, I am limited by track layout and cant be in higher rpms due to tight layout. Thas why I will upgrade from 4.67 to 4.88, to have more power/torque. I cant get 5.1 cause I do highways too.
Edit: Now I have 7600rpm limiter and it dont fall hard like OEM, so I might be even faster. So better brakes next time. Never ending story.
Rear end ratio and ECU changes? mid_life_crisis Software Tuning 12 01-21-2015 03:14 PM
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 01:48 AM
FR-S to BRZ Ratio MannyO New England 11 03-08-2012 03:23 AM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 03:40 AM
