#15 |
Drives: 2015 FRS
One thing to try... make sure torque is not running when you start the car. That will cause it to throw codes. But I think those codes are communication issues... not the ones you mentioned above. Good luck.
2015 FRS Ultramarine.
#16 |
Drives: '13 Subaru BRZ Limited
I normally only plug in the adapter when I intend to check things out and I have the car on and around operating temperature. The past few days have been the exception due to frustrations of trying to wrap my head around the problem.
#17 | |
Drives: Raven FR-S 6M
You may have a vacuum leak if there was anything that came loose or wasn't re-installed correctly.
“The World is Flat”
[||•]=(86)=[•||] |
#18 |
I've triple checked everything leading into the intake manifold at this point. I've spent quite a few years as a mechanic, so can we get off the "something installed incorrectly" theme? I'm not meaning to sound unappreciative of the advice, but I've stated a few times that I've ruled it out.
#19 | |
You shouldn't ask for advice from non-mechanics and figure it yourself.
“The World is Flat”
[||•]=(86)=[•||] |
#20 | |
Second: In my OP, I didn't state that I was looking for advice and was merely doing this as a public record for others that may have similar issues. Third: Any helpful advice is appreciated, though I'm confident I'll get it sorted some way. That all being said, I'm assuming you didn't read a majority of the thread and I'm sorry if you did and just didn't pick up on what's already been discussed. |
#21 |
I did read the entire thread. You never mentioned that you removed the intake entirely until a couple posts ago. Problems usually stem from the last thing was changed. P0171 usually pops up with a vacuum leak or exhaust leak. Sometimes putting ego aside on these forums helps.
“The World is Flat”
[||•]=(86)=[•||] |
| The Following User Says Thank You to Apoc For This Useful Post: | Dallen (09-02-2015) |
#22 | |
#23 |
Drives: 2013 Subaru BRZ
Long shot, maybe unplug the battery to let the car "reset" itself. Weird things with this car and brand new too.
#24 |
#25 |
Took some freeze frames at idle, I'll post them when I get home. Can't seem to post them properly from my phone.
[IMG][ /IMG][IMG] [/IMG][IMG] [/IMG]
#26 | |
Drives: FT86
afr generally arround 14.7 once warmed up at idle ltft will vary a bit depending on intake air temps fuel ethhanol percent ect but should be less than 10% usually arround +\-5% in most cases ,if long termm fuel trim is high like 15 to 20% usually an indication something is wrong short term fuel trim will vary widly with throttle application this is normal commanded afr and afr should follow each other under load see logging link below |
#27 |
Drives: 13 carbon accents Blk
had the same issue at 29k
Took it too dealer and they flashed the ecu with the latest revision.
#28 |
| And So It Begins | nivek111070 | Electronics | Audio | NAV | Infotainment | 22 | 04-22-2015 09:08 AM |
| And the fun begins! | FR-S Matt | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 12-25-2012 09:37 PM |
| iBRZ: it begins. | iBRZ | Member's Car Journals | 17 | 12-18-2012 11:21 PM |
| FR-S search begins | mkiisupra | Southern California | 6 | 11-22-2012 01:40 AM |
| The Wait Begins | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 09-06-2012 05:50 PM |
