#85 |
Drives: FR-S TRD RS1#1488
I was planning to buy their kit plus injectors and pump but they're pissing me off now. They were great at the beginning. but now they won't even reply to any of my messages or emails. Another forum member messaged them this morning and got a reply back in around 20 mins which means they're obviously checking their inbox. So messaged them right after and it's been a couple hrs with no response. Mind you, the last message i sent them was almost a month ago and still hasn't been responded to. And that message was only to ask how to switch maps with the traction control. If i don't hear back from them by end of day i'm buying the moto east kit with injectors/pump.
#86 |
Hope you figure out the issue. Do you think it's tune related or something mechanical? I'm seriously looking at the FnG Tune with Flex Fuel upgrade. Thanks.
#87 |
be careful with investing money on the Flash and Go. Just look at my graphs that i posted. curve is pretty choppy. I personally think it's a great map to start with. But just from the results alone along with seeing the results of the others that day...you might wanna reconsider. Not one single person that had the Flash and Go tune was very happy at all and that's coming from two people with turbos (different brands) and one with a supercharger.
| The Following User Says Thank You to Crazypinoy9 For This Useful Post: | FRS Johnny (08-31-2015) |
#88 |
Drives: JR FR-S,
Thanks everyone for coming out!
![]() 21 cars on the dyno plus spectators. No Krispy Kreme left. ![]() ![]() ![]() ![]() ![]() ![]()
| The Following 8 Users Say Thank You to Jackson Racing For This Useful Post: | aegisdrgn (08-31-2015), Crazypinoy9 (08-31-2015), DAEMANO (08-31-2015), danthedirt (09-01-2015), jc0522 (08-31-2015), JDMChris (08-31-2015), juliog (08-31-2015), MJones_RB (09-01-2015) |
#89 |
Drives: 2013 FR-S Whiteout MT
![]() So this is my dyno chart. Mods are: injen intake (probably robbing power) tomei uel headers stock front pipe with aftermarket/custom catback open flash tablet running e85 Hopefully I can get a new intake? Or just wait and get forced induction probably. From this dyno, to me, it shows that off the shelf tunes or 'canned tunes' are pretty conservative and don't necessarily get all the potential out of the car. I'm sure they have to take into consideration of different fuel, mods, sea level, air, location, and temp. But overall any tune is better than stock. A custom tune is probably the best if you want to squeeze the most power out of your car. Thanks for putting on the dyno day! It was great experience and info.
When in doubt, throttle out!
| The Following 5 Users Say Thank You to FRS Johnny For This Useful Post: | aaguirre123 (08-31-2015), DAEMANO (08-31-2015), JS + BRZ (09-01-2015), juliog (08-31-2015), tracerit (09-01-2015) |
#90 | |
Drives: sti 2012 sedan
Great results. I can't believe an NA can go over 210 whp. Which mods do you think made it possible to go over 210 whp?
#91 | |
Drives: JR FR-S,
Your car showed the first two runs low compared to the 3 normal runs. Daniel at Church Auto said he turned the heater on to help cool the car down, then did the 3 normal level runs. He said it is pretty common for stock FR-S/BRZ to read low when hot. This makes sense, as the timing will be adjusted by the ECU for higher engine temps. My guess is you still had some heat soak from the drive down and then jumped straight on the dyno with a little too much engine temp. He did three pulls at the normal number back to back to back to make sure the car did reach a consistent number. -Oscar Jr. |
| The Following 2 Users Say Thank You to Jackson Racing For This Useful Post: | Crazypinoy9 (09-01-2015), DAEMANO (08-31-2015) |
#92 | |
another amazing result from a NA. can you tell us the E85 percentage? E70? E75? E60?
#93 | |
Drives: Scion FR-S 10 Series #2263
Maybe three.
| The Following User Says Thank You to aegisdrgn For This Useful Post: | Jackson Racing (08-31-2015) |
#94 |
Depending on the dyno 210+ is completely rational. Ive done 220 SAE corrected on a mustang dyno in a friends car. Doing a custom tune vs a canned tune can help get those last few ponies =)
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| The Following User Says Thank You to nelsmar For This Useful Post: | DAEMANO (09-02-2015) |
#95 | |
I have about the same mods. Just no crank pulley, flywheel, spark plugs if that makes a power difference I'm not sure. I know my injen intake isnt the best and is probably losing power.
#96 | |
Drives: 2010 MS3
#97 | |
Drives: '13 SSM BRZ Limited 6MT
Are you using an off the shelf OFT E85 map or one that's been tuned for E85? Because when I ran the Stage2 EL E85 map, my fuel trims were +20% on straight E85. After mixing my E85 into E70-E75, it finally came down to 5% and under. Things would be so much easier if I scaled to 85% though instead of mixing. |
#98 | |
I actually go to the one on beach and warner. But I mean they are close to each other, so I would assume they came from the same tanker? I was running the oft stage 2 e85 map supplied by oft.
| Tags |
| church, dyno day, e85, jackson racing, supercharger |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Dyno Day Hosted by PRT Performance | pleong | Southwest | 11 | 07-16-2015 08:29 AM |
| Testing Our New Vortech Cold Air Intake @ Pure Automotive Performance! Dyno's Inside! | Pure Automotive | Forced Induction | 24 | 10-20-2013 11:29 PM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
| Mach V's Dyno Testing | tjoy | Engine, Exhaust, Transmission | 20 | 08-06-2012 10:52 PM |
