Cpt. Slow
Drives: 2015 series.Blue
P0128 CEL
I was driving down the highway with cruise control on yesterday and then the car kicked out of cruise and threw a CEL. Read the code with my OFT and got P0128 " Coolant temp too low".
Anyone have this before. Both fans were running and cutting on and off just fine, coolant levels are good, engine temps didnt seem to change any either. |
| The Following User Says Thank You to Slow_86 For This Useful Post: | BackFlip (12-19-2024) |
#2 |
I'd guess either your car's thermostat stuck open or it "hiccupped" and tossed you a code.
I'd suggest you erase the code and see if it comes back. If it does, you may wish to read the coolant temperature with an instrument. humfrz |
#3 | |
Cpt. Slow
So pretty sure it's a stuck open thermostat. |
#4 | |
![]() You may consider that NEW "turbo" thermostat ..... it will add 6 HP and if you put the sticker on ..... an additional 2 HP ........ ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Slow_86 (08-31-2015) |
