#29 | |
crew chief
Drives: Race car FR-S
excellent, thanks a lot. Stupid exchange rate, should have bought that a year ago. |
| The Following User Says Thank You to puma For This Useful Post: | Calum (08-25-2015) |
#30 | |
It's similar to getting tuned at sea level, and then visiting high elevation where the car will have less air to compress and ingest. |
#31 | |
Drives: JR FR-S,
Couple of notes: • Remove the throttle body tube to get to the pulley easier. • I'd recommend tightening down the pulley before releasing belt tension onto the pulley. You want to make sure the pulley is properly seated onto the Rotrex unit. Then after the belt is on there, do a final torque check. Do not over tighten. -Oscar Jr. |
#32 |
@CSG Mike @Jackson Racing
With the required supporting mods, i.e. bigger injectors, fuel pump and custom tune, can this smaller pulley be run with 91 octane on occasion? Like on road trips where e85 is not available. The custom tune should be able to pull enough timing when on 91 octane? Or do I have to change my driving habits when on 91. No WOT or redline shifts? I think I understand that there is no point in running 91 with the HBP because so much timing has to be pulled but I'm just wondering would it be safe when I'm not near a e85 station? |
| The Following User Says Thank You to dj2020 For This Useful Post: | clayrush (08-25-2015) |
#33 | |
Think of it as being similar to running 87 octane in a stock FRS. You technically *can*, but it's not ideal at all. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | dj2020 (08-25-2015) |
#34 | |
Drives: JR FR-S,
I would not blanket trust all tuners to put in the necessary safety that allows a 93+ octane tune to be ran on 91. I also don't trust myself to not go WOT. ![]() In the end, the way your custom tuning setup is between you and your tuner. The safety of the high boost pulley on your car is in your tuner's hands. |
#35 |
Lol. I also wouldn't trust myself NOT to go WOT come to think of it.
Long story short, get a good flex fuel 91/e85 tune from a reputable tuner if running HBP with required supporting mods. Thanks @CSG Mike and @Jackson Racing |
| The Following User Says Thank You to dj2020 For This Useful Post: | CSG Mike (08-25-2015) |
#36 |
Any chance of an updated tune from Jackson Racing for this pulley?
(for those of us that have the carb tune and don't live in CA) Pat |
#37 | |
![]() Finally...I get to post something before @Jackson Racing and @CSG Mike. YESSSS! |
| The Following 3 Users Say Thank You to CSG David For This Useful Post: |
#38 |
Drives: '23 BRZ Limited
Will the motor really survive for a long time running this type of HP and being beat on? The trans? The Diff? Half shafts?
Will the JR oil cooler keep this oil temps under control on track at this HP level? We have E85 locally, but only 91 and in most of the surrounding states only 91. Suggestions on a tuner who could produce a safe 91 octance tune for hard use? |
#39 | |
The power game is such a lustful region to be in. 2. It has so far. 3. 91 is marginal at best. How comfortable do you feel about running 87 octane on a full bolt-on NA setup FA20? Not everybody can be like Austin Powers and have "Danger" as their middle name.
| The Following User Says Thank You to CSG David For This Useful Post: | OkieSnuffBox (08-26-2015) |
#40 | |
1. I know that's why I'm afraid to go down the FI rabbit hole. Something that will hold up to an HPDE weekend and not window the block after 5000 miles is paramount. But the extra power would be nice on the track and on the street. I suspect staying with base pulley would be the best idea for me if I decide to go this route.2. What kind of ambient temps? I just ask because it stays HOT here most of the year. And keeping 375whp cool will be much more difficult than 200whp NA. 3. No sir, I don't like it. I imagine the amount of timing you'd have to pull would skyrocket EGTs. (Since I don't know the voodoo behind the flat torque curve tunes like Emilio used to do for NASA) |
#41 | |
2. Fairly dependent on usage and tune. The oil cooler will hold up fine, but this is also conditional as some may want a larger core and some are totally fine with the 15-row core. For example, @sw20kosh uses a 25-row Setrab unit in his near stock BRZ. I don't think anybody else does that setup for that particular application. ![]() 3. Refer to Jackson Racing's statement: 93+ or E85. It's not a guideline, it's essentially mandatory. Oh yea...Emilio's tuner.
| The Following User Says Thank You to CSG David For This Useful Post: | mkivsoopra (08-27-2015) |
#42 |
Drives: toyota mr2/ Toyota GT86
these are numbers are exciting but I seriously doubt that the stock engine is going to last day in day out at this level
we saw the same thing on the EJ25 (subaru WRX) when it 1st came out everybody jumped on the bandwagon, piling in the boost on the stock engine, the dyno queen power figure jumped from 280 to 350 to 450 to 500 and then the 'BANG' started happening to these guys who had been running around on their 'safe' tune at 500bhp after several thousand miles with cracked blocks etc these days the ambition is more realistic with 350-400 seen as the sensible max for a stock block I wonder where the Fa20 will settle out at? as I feel we're still in the exciting area before it all starts going 'BANG' |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing BRZ | Parikh1234 | Member's Car Journals | 31 | 12-29-2015 10:26 AM |
| Why no high rpm boost for Phantom ESC? | stevo585 | Forced Induction | 11 | 02-11-2014 08:51 PM |
| Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 03:29 PM |
