| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#57 |
Drives: 2004 Subaru Forester 2.5XT
#58 | |
Drives: 2022 BRZ Limited
![]() see below chart and you'll notice 5w-30 already makes more than enough on 220F mark .. you can ignore the lowest and highest values since that sporadic jump is probably due to the incorrect readings.. you will also notice that the pressure changes are actually pretty steady between 240-260F, then again the correct way to read that data is to look at the median values (not the average values) .. you will also notice that between 10w-30 and 10w-40 there is not a big difference in terms of pressures in Dezoris' chart so why risk running the car with the viscosity out of the recommended range (less than 12 @100C as far as I can remember)
#59 | |
![]() the thing what you get with UOAs is a snapshot of the OIL and see if there's any abnormal wear and tear (like metal shavings) in it.. it still doesn't tell us anything about the long term effect of the oil to our engines, that's when the tech specs of the specific oil and the datalogging at the track comes in handy.. and in the above graph it clearly shows how it can keep the pressure way above the 0w-20 .. and that 0w-20 is Motul V300 btw, not some el cheapo oil
#60 |
Drives: Nevermorange FRS
Well if you're comfortable with <50psi @ 7000rpm then knock yourself out. Your UOAs, as you claim, support your decision while simultaneously nullifying your claim of 10psi/1000rpm which your car, with 5w-30, is nowhere near..
But I can dig it. You're doing the analysis and data doesn't lie. However, when it comes time to tear down, I'm looking forward to peak at those bearings.
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | glamcem (08-25-2015) |
#61 |
Drives: 2010 MS3
I'm planning to pick up some Motul8100 5w-30 for my next oil change. Done with the freebies at Subaru.
#62 |
Drives: 2013 FRS
Was using 8100 Ecolite but have switched to 300v.
#63 |
Drives: 2015 Steel FR-S MT
Not for daily use, right? The 300v doesn't have the additive packs that Eco does. My plan is to use 8100 (or greater) for the street and then switch to 300v for the track and some miles after.
The only thing I haven't seen in this thread is about switching up viscosities when using an oil cooler. You have to remember, there will still be a quart of your low grade in there when you do the swap. This then thins the higher viscosity oil and could cause pressure issues when the temps rise. Also for serious tracking: You can monitor temp all you want, but if you aren't monitoring pressure as well all of your oil decisions are probably wrong and if you are using too thin of an oil you are royally f**king your motor.
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
#64 |
The 300v actually has been showing having plenty of additive left even after 2500 track and 2500 street miles in our Project BRZ using Blackstone Labs testing.
I'm not a fan of using the Motul "Eco" anything. They are setup for milage not wear protection. For a daily driver and track car I suggest the 8100 "X" series (X-clean, X-cess) even if you have to move to a 5w30 (0w20 doesn't come in X). -mike |
#65 |
Drives: '23 BRZ Limited
^Pump gas or E85?
Having a hard time deciding what to buy, I like the Miller but it's damn pricey. I'm thinking I should just go Redline since it's local and still a quality oil. I run E85 more often than not (only street miles so far), and throw in a tank or two of 91 every 4-5 tanks. |
#66 |
I switched to mobil 1 5w-30 from 0w-20 about 2 weeks ago before my first track session. I will just keep an ear out for valve noise during cold weather but It should be fine.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| The Following User Says Thank You to stevesnj For This Useful Post: | Chad86 (04-01-2018) |
#67 |
USMC
Drives: 2013 FR-S 6-MT Raven
Okay, so I have a fully built short block from Crawford with the one off Borg Warner turbo setup from JDL. Quirt Crawford himself said to use 0W-40 Motul. I haven't had any issues with pressure or Temps as long as I have my Perrin oil cooler installed. I haven't tracked it yet but I've been driving it hard on the streets out here in Yuma. Most of the time I don't see oil Temps go over 210. I recently put the oil cooler back on because the Temps when I was cruising on the highway saw 233. I saw some posts that mentioned Temps going to 280. I was freaking out when my oil Temps got to 240. Can someone please post the temp ranges for both coolant and oil? I was told that it's not good to run our cars below 212 oil temp. Need some clarification please. Thanks.
Sent from my SAMSUNG-SM-N920A using Tapatalk Last edited by texasbound972; 10-05-2015 at 03:38 PM. |
#68 | |
Drives: FT86
Definitely run an oil cooler with any FI build, its just plain nuts to run FI in a warn/hot climate and track it or drive it hard for extended periods without an oil cooler. Ideally the oil cooler should have a thermostat so it does not overcool the oil in low ambient temperatures and will let the oil heat up faster from cold start, im pretty sure the perrin cooler would have a thermostat. modern synthetic oils will handle temps of 280 usually without breaking down, but the problem in these cars is the oil thins out as temps increase (some oils thin more than others) and the oil pressure drops these cars dont make good pressure at high rpm. (you need more pressure as rpms increase) best to keep your oil below about 240, to keep the pressures up. In texas where is hot your oil is always going to get hot enough to evaporate off any moisture, its just guys in cold countries that run non thermostaticly controlled oil coolers that may run into issues with oil being to cold, like never gets over 170F or so. normal driving your going to see coolant temps around the 190-200f and oil arround the same maybe slightly hotter, depends on thermostat in oil cooler and if your running an oil cooler. track or hard driving the coolant may get over 200F but you would not want it getting over 210F or so. Oil you probably dont want to get much over 240F but with a good appropriately sized cooler it should never get that high. Last edited by steve99; 10-06-2015 at 08:16 PM. |
| The Following User Says Thank You to steve99 For This Useful Post: | texasbound972 (10-05-2015) |
#69 | |
Drives: 2017 Subaru BRZ
Ice Silver 2017 BRZ w/PP 6MT | Driver Mod |
#70 | |
Drives: N/A
| track driven car - Engine noise - click on driver side - vid | philooo | Tracking / Autocross / HPDE / Drifting | 1 | 04-27-2015 09:09 PM |
| LSx engine swap for track use, thread | foodman | Tracking / Autocross / HPDE / Drifting | 77 | 03-16-2015 04:23 PM |
| Engine 11 Track Bike (Socal) | Cop | Miscellaneous | 0 | 09-24-2014 10:49 PM |
| Check engine light at the track | Thongpocket | Issues | Warranty | Recalls / TSB | 7 | 05-12-2014 09:54 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 07:50 AM |
